2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum V1 Hardwire Question
      05-19-2014, 08:55 AM   #1
jdfish06
Johnny F
Drives: '11 F10 535i
Last night I decided I hardwire my V1. I used a YouTube video where the install was done on a F10 M5.. The video said to use the Green/Brown wire, which didn't work for me. Instead I used the Green/Red wire, and had no problems. My question is this, what voltage is the wire I tapped, what does it control, and should I tap a different wire instead?
— Johnny F —
      05-19-2014, 11:04 AM   #2
nvy
nvy's Avatar
Drives: 11' F10, 07' E90, 04' E46
Simple. get yourself a multimeter and test it. You just need a ignition 12v power source. Meaning you only get 12v when ignition is ON and 0 volts when that car is off. Doesnt matter what wire you use because (i hope) your power tap has a individual fuse in it. Also, make sure you use a good ground. Thats it.
What mount did you use? rear view mirror or window cup mount?
      05-19-2014, 11:49 AM   #3
jdfish06
Johnny F
Windshield mount placed right under the rear view mirror. It does turn on and off with the ignition so that should be fine... And I couldn't get the ground to hold the bolt, so I just superglued the wire in place
— Johnny F —
      05-20-2014, 08:39 AM   #4
nvy
nvy's Avatar
you superglued the ground wire?! lol take the time to BOLT the ground C-Clip to a near location. vibration will eventually loosen that up and can cause a short.
      05-21-2014, 09:16 AM   #5
jdfish06
Johnny F
Yea that happened the day I wrote it lol but the tapped wire came loose too... I ended up just tapping the green/brown wire and bent the ends of the ground connection around a ground wire that I found (like a makeshift splice).
Worst case scenario is that it comes loose again and I take it to the shop to have it installed professionally
— Johnny F —
