2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Whisling noise on low revs
      04-10-2024, 12:44 PM   #1
Nicolene
Nicolene's Avatar
South Africa
Drives: BMW F10 523i 2011
Hi everyone I need advice plse.
My 2011 523i F10 is making a loud whistling noise when I drive, specifically momentarily when I take my foot off the accelerator, and a continuous high pitch whine (screech or whistle) when I stop, for instance at a traffic light. It happens more often in the mornings on the first drive, and goes away when the car is either switched off and on again or when I drive it later in the day when warmer. It comes and goes. I have changed oil before, then it goes away. Not sure if oil related though. I use BMW LL01 oil and the car has 197000 km. Any help would be highly appreciated. I have a video I just dont know how to post and it is quite big since it is 3 min long.
Regards
Nicolene
      04-11-2024, 12:10 AM   #2
Carbon535i
Carbon535i's Avatar
Drives: 2015 BMW 535i xDrive M sport
It may be the oil filter that could be the cause of the whining noise. Sometimes the filter can have a tear, be collapsed or the oring can be torn which can be the reason why it goes away after an oil change at times. I hope this helps.
      04-11-2024, 07:49 AM   #3
DementedF10
DementedF10's Avatar
Drives: 2012 BMW 535ix
Id say it is more than likely a PCV valve issue
      04-11-2024, 08:44 AM   #4
StradaRedlands
StradaRedlands's Avatar
Drives: 2006 BMW 330i MT
2006 BMW 330i  [8.21]
2009 BMW 328i Touri ...  [7.90]
2013 BMW X5 35i  [7.63]
2011 BMW 528i  [8.75]
2006 Mazda3  [5.50]
Yeah, I'd start there.
      04-12-2024, 03:14 AM   #5
Nicolene
Nicolene's Avatar
South Africa
Thanks for the advice I will investigate that (PCV), oil filter and also the transmission oil. Please advise, can PCV whislte, with no accompanying up/down/up/down rpm?
