2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes BMW F10 20x11 ET40 rub ?
      03-27-2018, 03:43 AM   #1
Corven
Corven's Avatar
Drives: BMW F10 525d (2016)
Question BMW F10 20x11 ET40 rub ?
I have a question about offset for F10 non-m
Front 20x9 ET20 ( 245/35/20 or 255/35/20 )
Rear 20x11 ET40 ( 295/30/20 )
1. Rub ?
2. Front 245/35/20 or 255/35/20 ?
Thank you
      03-30-2018, 12:35 PM   #2
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
I've got 20x9 ET26 with 255/35/20 and 20x11 ET46 with 295/30/20. I've got no rubbing with this and I'm on Michelin tires that runs large. But with 6mm less clearance I think there be rubbing at some point under heavy suspension compression.
      03-30-2018, 03:23 PM   #3
Teddylongtooth
ZEROdoubleZERO
Teddylongtooth's Avatar
228
Drives: 2011 550i m sport
Yes it will 100% rub, even if you run a 285-30 and dont plan on lowering or putting any passengers in the back while you own the car it will still rub. Can you get a 20x10.5 in a +40? That will fit a 295/30 and be more square with no rubbing or get a 285 on the 10.5 if you want a slight stretch. The fronts are questionable too, they might be too agressive as well, can you get a +25-28 offset?
      03-30-2018, 03:50 PM   #4
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
this is a 21x11 et40 for reference to show how tight the fitment is with the vehicle sitting pretty low. This is all within BMW specs for alignment slight and i mean slight camber as i didn't want any camber wear.
tire is 295/30/21
and here i raised the car about .75" last year
