2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes weird noise coming from the front passenger corner
      04-02-2018, 09:26 PM   #1
NYC535iowner
Drives: 2013 535i X-drive
so this weekend i changed the stock springs and installed my H&R springs on my 2013 535i X-drive. Everything was fine until 24hrs after the installation, I started to hear a clicking noise in the front. it was a small clicking noise that i was thinking that maybe it was my aftermarket wheels touching since the new springs on the car are starting to go down.(it wasn't that). I kept driving in the local streets and the noise will come and go until it started to do it louder as i drive straight and as i turn to the left only. It even started to make the noise if I drove on an uneven surface.{it reminded me like when i had my old car and the shocks came off the springs}. I pulled over and check again but i dont see nothing loose, nothing leaking etc.
I took the car today back to the guy who installed my springs and he tells me that it might be the wheel bearing/HUB is nothing to do with the new spring installation since he double check everything and it seems to be fine and tight.
Any suggestion of what it could be???? PLEASE HELP
13'- F10--> Work in progress: V-Style front lip, HAMANN roof spoiler, M5 grill, high kick trunk spoiler, H&R sport springs, C-quence Drilled front rotors, VRSF Catless DP, VRSF charge pipe.
      04-03-2018, 04:43 AM   #2
NYC535iowner
please help.
      04-03-2018, 08:59 PM   #3
NYC535iowner
bump.
Taking the shop to another mechanic and check out what is the problem. hopefully is covered by my warranty that i bought with the car.
      04-04-2018, 09:12 AM   #4
TJBentley
TJBentley's Avatar
Drives: '12 528xdrive
Do you have aftermarket wheels?
      04-04-2018, 11:49 AM   #5
NYC535iowner
Found the problem:
The shop that installed my springs didn't tight the main bolt that is in the center of the wheel hub. That was the noise that was acting up.
The new shop noticed it and now I am replacing the wheel bearing and a new passenger side axel. I called my warranty and placed a claim and I just have to pay $200 for labor cost.
TJBentley135.00
      05-24-2018, 04:51 AM   #6
NYC535iowner
clicking noise
I have question to all running H&R springs on their F10 xdrive.
Ever since i installed them i feel that the car is heavy and changes the angle on the front axles. Now today i started to hear a minor clicking noise now coming from the driver side of the car as I turn the wheel all the way. at the moment is not as bad as my passenger side noise from before. I am thinking before i replaced my passenger side axle and now I think i have to replace my driver side axle.
Is any one else is experiencing this problem???
      05-24-2018, 02:49 PM   #7
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
you have to remember your stock shocks weren't designed and engineered for those springs. sounds like you're having all kinds of issues now?
      05-24-2018, 05:53 PM   #8
DARKKN1GHT
Drives: 535XI
What is the part number of the springs you installed on your xDrive?? I ordered Eibach springs for my xdrive but they only come with the front springs which is weird but i guess they assume the car has airbags in the rear so they dont make a full set of springs for our xdrive cars. Eitherway the shop shouldnt have been messing with the axles or center axle bolt at all to install the springs.. The best way for front of the xdrive cars is to remove the upper control arms bolts and swing it out of the way to remove strut assembly.
      05-24-2018, 05:55 PM   #9
DARKKN1GHT
Drives: 535XI
A bit offtopic but copied this from Eibach's website "PRO-KIT Performance Springs (Set of 2 Springs) E10-20-022-04-20 Front springs only, rear air suspension is adjustable. ; Tested with factory dampers." H&R has more of a drop front and rear and i doubt they tested it to work with stock shocks so thats why im sticking with less drop and eibachs.
