2010 2011 BMW 5 Series Forum F10 F10 N63 RaceChip TB Ultimate Dyno Results |
01-05-2016, 03:55 PM | #1 |
Rep 99
Finally had a chance to get the dyno on my F10 550i. The only mod I have on the car besides the chip, is a Dinan axle back exhaust, which shouldn't change much.
Anyways, the results are a little disappointing. The HP is killed with "boost control, level, or whatever". I noticed the engine jerky at higher speeds/rpms and is the reason why I did the Dyno. You can see the "jerkiness" in the graph. I did a few pulls with the chip in first, and than a few pulls with the chip disconnected. Stock With RaceChip Can someone explain why the HP numbers are only like +7? |
01-05-2016, 05:04 PM | #2 |
Rep 862
Interesting. Thanks for sharing.
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
01-05-2016, 11:21 PM | #3 |
Rep 18,685
paul_sarky what setting are you at? Also, what is your gas octane?
01-06-2016, 03:18 AM | #4 |
Rep 99
01-06-2016, 10:34 AM | #5 |
Rep 479
Drives: 11 F10 550xi
It looks as if it only makes Torque and no real horsepower gains. Disappointing to say the least. JB4 appears to still be the only real plug and play tune available to the N63 that actually adds real power.
01-06-2016, 06:50 PM | #6 |
Rep 862
Seems like something is wrong. Would be interesting to install a JB4 and see what happens.
01-07-2016, 01:29 AM | #7 | |
Rep 99
Im sending the unit back tomorrow and they will send me another one with different software. Will see if that changes anything. I don't know how the JB4 works, or even how turbos really work, but it seems like the engine is smarter than the chip, it wont make more power over a certain point, as seen in the dyno graph. Its hard to believe that im the only one that's having this issue, or maybe other people just don't drive like I do. Would be nice to see someone else dyno their n63 and compare results. |
01-07-2016, 01:42 AM | #8 |
Rep 862
My N63 with BMS Stage 2 in aggressive mode was really sick. If this RaceChip thing doesn't work out for you I highly recommend the BMS.
01-07-2016, 05:53 PM | #9 |
Dream crusher
984
Rep 2,421
Is racechip willing to reimburse for the dyno too? Contingent on the updated software yields no results.
IG: @bmwdoubles |
01-08-2016, 12:08 PM | #10 |
Rep 414
Man looks like the car has Parkinson's. What is that?
Mike F
01-09-2016, 02:54 PM | #11 |
Dream crusher
984
Rep 2,421
Looks choppy even stock. Are you sure you're not having hpfp or injector issues. Have you cleaned the maf? Check your spark plugs.
IG: @bmwdoubles |
01-14-2016, 02:29 AM | #13 |
Rep 99
01-14-2016, 02:31 AM | #14 |
Rep 99
I received my new updated chip today, and it worked fine. the weird thing is, the more long pulls I did, the worse it got, after doing a few 30-100mph runs, I started noticing the issue again. at first it was flawless. than the issue was present in 3rd gear doing 50mph.. so im not really sure whats going on
01-14-2016, 09:14 AM | #15 |
Rep 414
Looks a connection issue like a corrupted tune. IMHO.
Mike F
01-14-2016, 03:07 PM | #16 | |
Dream crusher
984
Rep 2,421
1. Tried colder stepped plugs, no fix. 2. This one is weird, but worked. Fill radiator fluid above max. 3. Try 4-5 gallons of e85 Could be the butterfly closing or worse knock sensors going off. BMW engines are not bulletproof, but pretty close.
IG: @bmwdoubles |
01-14-2016, 05:44 PM | #17 |
Rep 1,402
Save yourself the headache and get the BMS Stage 1 if you want the simple install/un-install. Cheap with proven gains.
Haven't seen one dyno for the n63 what was positive worth the RaceChip. Last edited by Simple5; 01-16-2016 at 01:54 AM.. |
01-15-2016, 09:26 AM | #19 |
Dream crusher
984
Rep 2,421
Truth is jb4 is the most proven so unless you got a deal on some other tune then BMS reigns supreme.
IG: @bmwdoubles |
01-18-2016, 01:45 PM | #20 |
IG @bmwF9xG80
3813
Rep 7,592
His graph is crazy even stock so its not a tune issue, he's using 91-92 octane which is already bad.. For RaceChip and Even JB4 on more aggressive maps requires 93+ octane.
That or you need to go to someone with AWD Dynojet, I've had my car dyno'ed stock and race chip tuned on Mustang (never again) and dynojet, even brought my friend with his dinan stage1 to tag along. OP, first recommendation is run the stock setting for at least a tank.. Find yourself a dynojet and do the following as I did.. - First run test on your current stock setting (please) - 2nd run; turn off car, lock it, and increase setting 1 notch only if you have 93+ octane) since - 3rd run ; increase 1 setting - 4th run ; put the dummy plug and do a stock run Let us know what setting you were running on? did you increase or not? stock setting is ok with 91-92 octane, but anything above 2 increase is going to want 93+ otherwise not good even with JB4.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
01-18-2016, 02:07 PM | #21 |
Joint Chiefs of Staff
24095
Rep 190,633
Something is wrong, result is very disappointing. Not sure if it is a tune issue or a car issue
Another great feature of the JB4 is the ability to log you car so we dont have to play the guessing game in order to figure out what went wrong.
01-21-2016, 11:53 AM | #22 | |
Rep 171
I am assuming you started with S5? I have mine set to S2D then adjusted back to S2B after DME came on. For sure the power gains are there. The HP on yours can't be right.. |
