2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Mission Performance Flash Tune Stage 1 - My personal review
      06-15-2016, 07:09 PM   #89
AWF87M2
AWF87M2's Avatar
827
Just had my F10 535i flashed by Alex today with their stage one tune. The car now pulls so much stronger in the mid range then when the car was on JB4 stage one pnp that I had awhile back. Will let the ecu adapt for a couple of days before putting the car on the Dyno to see how much power it is making. I opted for the m boot option as well for future convenience.
      06-16-2016, 04:31 AM   #90
Bmw doubles
Dream crusher
Bmw doubles's Avatar
Drives: Fast
2011 535  [0.00]
Nice! We'll probably be going to the Dyno same day then. I turn my car in this Friday to him.
Alex will hate me for this, but if you want a quicker jump off the line get a sprint booster and put it in red mode. Since you have the m-boot you can experiment with throttle mapping. Alex can make your throttle very aggressive. I like to be able to toggle on the fly so the SB works for me. Actually I had him increase throttle sensitivity and now I can have the throttle plate open instantly if I need. Instance throttle blips on my manual like its hooked up to a cable.
IG: @bmwdoubles
      06-16-2016, 05:09 PM   #91
AWF87M2
AWF87M2's Avatar
827
I think the throttle response with the standard stage one flash is already more then enough for me lol. My car is a 2011 535i 8 speed, so it has the comfort,normal,sport,sport+ throttle settings. The sensitivity of the new remapped comfort mode feels somewhere between the lines of the old sport and normal modes and I find myself using this mode more often now. I am starting to get the infamous high pitched humming/moaning noise coming from the left side of the engine bay at idle when the engine is fully warmed up close to 250 Fahrenheit. Not sure if this is a result of a faulty waste gate solenoid like many n55 e9x 335i owners have experienced over on e90post.
      06-16-2016, 05:52 PM   #92
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
So wait...will the hp be different on a manual than the 8 speed auto? And 2nd, who's got a DIY for removing the ECU? I don't have the sport mode like you guys do so I'm wondering if that will make a difference?
      06-16-2016, 06:20 PM   #93
AWF87M2
AWF87M2's Avatar
827
Removing the DME is a big PITA! Took Alex a little under an hour total for removing and re-installing. The DME on our cars is hidden deep within the engine and it requires removing the entire manifold assembly. Here are some pics I took of the DME/manifold removed.
      06-17-2016, 12:27 AM   #94
lsturbointeg
Lol well that changes things
      06-17-2016, 07:16 AM   #95
malahhaor
Drives: F10 535I xD, F30 328i xD
Get the F out, wow. Taking the manifold off to get to ECU? There is no way I'll be doing that in my condo parking lot.
I guess this will have to wait for longer than I thought.
      06-17-2016, 07:45 AM   #96
vivanapoli806
Drives: 2012 535i Xdrive Msport
There is a YouTube video on removing n55 ecu. It should take a shop an hour or less to do. I might just get a walnut blast when I decide to do this tune since you have to remove manifold anyways
      06-17-2016, 09:11 PM   #97
AWF87M2
AWF87M2's Avatar
827
For those of you thinking of pulling the trigger on this tune, I also recommend getting the p3 multi vent gauge so you can monitor your boost levels along with other temperatures readings for your car.
http://www.p3cars.com/shop/bmw/bmw-5...p3-vent-gauge/
      06-17-2016, 11:17 PM   #98
lsturbointeg
+1 I didn't know I had to remove the manifold as I don't want to f anything up!
      06-17-2016, 11:37 PM   #99
AWF87M2
AWF87M2's Avatar
827
You can hire one of those private mobile bimmer mechanics and have them remove them for you.
      06-18-2016, 03:14 AM   #100
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
If you think about stage 2 jb4 you have to tap factory wires. Taking the manifold seems daunting, but it's actually not that hard.
IG: @bmwdoubles
      06-18-2016, 03:15 AM   #101
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Wow that things had gone way down in price. It used to be so much more. Now it's at the proper price point.
IG: @bmwdoubles
      06-18-2016, 07:13 AM   #102
lsturbointeg
Dude, those things were like $500+
Ill check out the YouTube video and go from there. I'm thinking back in my Honda/Acura days where you just pull up the front carpet and bam...the ECU!
      06-18-2016, 10:08 AM   #103
vivanapoli806
When you add the obd option it comes out to almost $500
      06-19-2016, 02:42 PM   #104
gwong511
Drives: 2013 535i M Sport
I'm local...can this be done while I wait? Also, any factory warranty concerns with the flash? detectable?
      06-19-2016, 04:30 PM   #105
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
Yes while you wait, and not detectable by scan or visual inspection. They would have to send the ecu back to Germany and have it checked down to the tables and its parameters.
IG: @bmwdoubles
      07-02-2016, 09:38 AM   #106
Stück
Stück's Avatar
Drives: F15 X5, E46 330i, R56 Mini.S
Sooooo where is the Stage2 dyno update already?
      07-02-2016, 12:17 PM   #107
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
It's scheduled for July 13th
IG: @bmwdoubles
      07-05-2016, 04:42 PM   #108
AWF87M2
AWF87M2's Avatar
827
I am not going to the dyno as I am away for vacation. I find JB4 unnecessary for my usage at the moment. I feel like spending 600+ for one just to monitor some other stuff isn't worth it, my car does have the m-boot flashed, so if I needed any adjustments to the tune, Alex can do it via obd port or remotely.
Originally Posted by FSociety View Post
///TWM3FAN are you going to Dyno ?
I recommend having a JB4 OBD2 version over that Gauge stuff lol
At least with JB4 you can log your tune, view it, save it later, see how your flash is running and even other things in the future when Flash becomes more readily available as Backend Flash.
      07-15-2016, 06:22 PM   #109
vivanapoli806
@Bmw doubles were you able to do the dyno on the 13th?
      07-16-2016, 09:15 AM   #110
Bmw doubles
Dream crusher
Drives: Fast
2011 535  [0.00]
I'm going in 2 hours from right now. I will post updates shortly.
IG: @bmwdoubles
