10-04-2019, 10:24 AM | #1 |
Rep 16
20x10 setup + fitment
I'm looking to purchase new wheels and I love the look of the OEM M5 343 20x10's (or even aftermarket wheels). Is anyone running a 20x10 square setup on their front and rear wheels? If so, how is the fitment? Do they rub? I have a 2011 535 xDrive. I do NOT want a staggered setup. PLEASE HELP ME!
12-16-2019, 09:09 AM | #3 |
Rep 16
12-16-2019, 12:45 PM | #5 |
Rep 231
05-14-2020, 03:34 PM | #7 |
Rep 53
I have 20x10's all around on my car and the highest offset you'll likely be able to run on the front is around +30. Any higher and the wheel will contact the front hub/knuckle.
My wheels are originally 20x10 +40, but they hit the knuckle/hub on the inside of the wheel before I could bolt it down. I ended up running a 15mm spacer, which basically makes the set up a 20x10 +25. The wheel just barely clears the front knuckle with that spacer. I haven't measured the exact amount of clearance now but it's probably around 5mm or less. |
05-15-2020, 08:26 AM | #9 |
Rep 53
I'm running a 255 which is a bit of a stretch on a 10" wheel. With the spacer the wheel sits about flush or maybe pokes out a little from the edge of the fender.
I rub constantly on the front fender liner on big dips, but that's cause my car is pretty low. I do have some rub marks on the inside of the fender lip but the strange part is I have no marks on the tire from it... |
05-15-2020, 09:50 AM | #10 |
Rep 10
So if I run with a 245 35 19 I should be able to make the fronts fit. Wheels are a 19x10.5 et22. I ordered bc coilovers extreme low. Waiting for them to come in to install and test fit the rim in the front. Do you have any pictures of your ride ?
