2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums USA - California X-series style 375 20" rims on F10?
      11-26-2014, 06:05 PM   #1
TeutonicDan
TeutonicDan's Avatar
40
Drives: 2011 F10 550i
Guys,
I wanted to get a feel of what you all thought of these rims on a F10?
Based on the size/offset there should not be an issue.
I was going to go 255 35 R20 front and 295 30 R20 rear
Available Fitments:
20x9.5 Fronts 20x10.5 Rears
Bolt Pattern: 5x120
Offset: +35 mm
Color : Gunmetal / Machined Face
Hub: 74.1 mm
Do you think I would need hub centric ring, I also have 5mm spacers on right now but I don't think I would need them.
Please chime in and tell me your thoughts? Too busy?
      11-26-2014, 09:27 PM   #2
twelve535i
twelve535i's Avatar
Drives: 2015 X5 35i M Sport
I think there is too much going on there.
If you do decide to get them:
1. I used hub rings on my forgestars which have a 74.1 bore
2. Check the offsets on the rear M5 343m wheels. If its 35mm or higher, a 295 on the rear will rub.
      11-26-2014, 11:50 PM   #3
TeutonicDan
40
Ya, thanks for your thoughts - not too sure about them.
Although, good call on the 295's because I really want to go wider in the rear.
