2010 2011 BMW 5 Series Forum F10 Lowering springs and headlamp adjustment |
12-01-2012, 10:59 AM | #1 |
Rep 896
Drives: 2021 X5
Does anyone know if lowering the can will cause the headlights to require an adjustment?
I had lowered a 2007 Passat which had adaptive xenon lights and there was a lever in the rear that needed to be modified. How does it work on the F10's?
2018 540d xDrive Carbon Black Metallic on Cognac leather. Spec'd out to the max
2017 Mercedes C43 AMG Coupe. Black on black |
12-12-2012, 08:14 PM | #2 |
269
Rep 6,093
Drives: E90 M3
Location: 1460 White Oaks Rd. Suite F Campbell, CA 95008
Depends on how low you go. We offer this to customers but have only had 1 or 2 decide to actually do it and none of the others have reported any issues post install.
12-13-2012, 07:51 PM | #4 |
Rep 1,035
I adjust them a tad after lowering most cars. They will point slightly lower. You can adjust it directly from the headlight housing, its very simple.
If your car isnt lowered yet. Pull up about 15ft away from your garage (if you have one) Measure where the lights line up. After lowering do the same thing, make sure you are parked the same distance, re measure and adjust as needed to get them to the same height as they were OEM. |
12-17-2012, 10:27 AM | #5 |
Rep 104
I had ACS springs installed and I need to raise the beam on my headlights. The ACS lowering isn't that much of a drop but you can really tell on the low beam setting that the lights now point too low.
08 BMW K1200S / 2002 330ci Sport (sold) / 1989 635csi (sold) 07.5 GMC Sierra 2500HD Duramax LMM 09 Honda Odyssey EX-L '75 Ford - Early Bronco |
