2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications F10 Methanol Injection N55
      10-09-2013, 12:40 AM   #1
Grumpy514
Grumpy514's Avatar
Drives: 2022 M3X
I have been trying to do some research on the boards and it does not seem there are many if any people on here running methanol on their 535i N55s. I have a 14' 535i and am about to pull the trigger on a RSI catless downpipe as well as a JB4 Stage 2. Also I am having a custom 3" catless straight pipe exhaust custom made for me.
I'm looking to squeeze the most power I can out of this motor and noticed that SOME but very few people have done meth injection (seems like it's mostly a N54 thing)
I noticed BMS has a meth injection kit where it stores it in the trunk (seems much safer than running it in the washer reservoir.
http://burgertuning.com/meth.html
Anyone have any experience with this kit or with meth injection?
Any help would be greatly appreciated!!!
      10-09-2013, 07:54 PM   #2
Grumpy514
Grumpy514's Avatar
Drives: 2022 M3X
Nobody huh? I found one person who is going balls to wall and running Meth + E85, or at least he is trying to. Having an issue with BMS Flex Fuel wires.
Has ANYONE done this before? Doesn't look like it.
      10-12-2013, 11:45 AM   #3
mk47
mk47's Avatar
Drives: 2015 X5 50i
Hey Grumpy, try checking out 54tech.com It seems like there are some guys running meth on that site.
      10-12-2013, 11:46 AM   #4
mk47
mk47's Avatar
Drives: 2015 X5 50i
Oops, I meant n54tech.com
      10-12-2013, 01:26 PM   #5
Grumpy514
Grumpy514's Avatar
Drives: 2022 M3X
Will do, Thanks man!
      10-13-2013, 11:18 PM   #6
RambleJ
RambleJ's Avatar
Drives: F10 535i M-sport
I think this was around more often for the N54 as there was much more room for tuning. The F10 N55 is basically at a stand still, so adding meth may help a little but seems like a lot of work for little benefit.
      10-14-2013, 02:03 AM   #7
shockin330i
shockin330i's Avatar
798
Drives: 2016 ZCP M3
The f10 and the f30 have a lot in common. Just more f30 people willing to mod.
ERnie
2016 BSM/f80/ZCP
      11-11-2013, 09:12 PM   #8
DinoNac
Drives: 535 xDrive N55
I am running meth using a custom 335 N55 CP for the F10. The issues you first will have is having a cp made. Once done I would advise you not to do excessive log type runs where you are wot at a low rpm in the powerband of 3rd gear. I run FBO+Meth with 100 octane and I am generating enough torque that if I try to open the throttle in a low rpm I can get the trans to slip.
      11-11-2013, 09:49 PM   #9
badblack550xi
badblack550xi's Avatar
done any 1/4 mile runs yet ?
2011 550i RWD 60-130 7.35
      11-12-2013, 01:10 AM   #10
///M ARMY
Drives: F90
Evolution Racewerks charge pipe will be able to accommodate meth injection.
