2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications Need help installing BMS N63TU tune on my 14 550i
      06-28-2014, 10:47 PM   #1
Eli550
Drives: 2014 BMW 550i M Sport
Has anybody installed the N63TU BMS tune on the 14 550i?
It seems pretty simple from what others are saying, just wanted to hear some exact installation instructions.
Thanks!
2014 550i Alpine White / Mocha Interior
M Sport with Gloss Black Wheels and Blue Calipers / BMS N63TU Tune / Muffler Delete
      06-28-2014, 10:51 PM   #2
didithepest
didithepest's Avatar
Drives: 2014 F10 550IX
2011 BMW E93  [0.00]
How much this ran you ?
      06-28-2014, 11:15 PM   #3
EZDozzit
Civilian
EZDozzit's Avatar
Drives: 2014 550i M Sport
Mine ran $599. The installation instructions are pretty straight forward. The only thing they don't cover is how to remove the engine cover. But I had read how to do it elsewhere. It just pulls right off, no need to remove any screws. Once you do that, the MAF plugs are visible. You can then follows the steps provided by BMS. The engine cover snaps back on.
Warning, I'm prone to sudden attacks of enthusiasm.
__________________________________________
2014 BMW 550i M Sport - Jet Black
2014 BMW X6 35i - Black Sapphire
2011 BMW X5 50i - Titanium Silver (traded)
      06-29-2014, 07:07 AM   #4
LiLS
Drives: ISF
how much extra power do u get?
      06-29-2014, 04:30 PM   #5
ezmaass
ezmaass's Avatar
Drives: '17 650xi GC / '15 Audi R8 V10
Eli - would love to hear about your experience once you get through it... maybe some pictures of the process if you can!
I've thought about it, but I'm really not sure I need any more power... I know, who says that? I recall the process was quite in-depth (at least from the BMS video) for the N54 335 (my previous car)... kept me from doing it, honestly, since you had to pull apart quite a few wires to stick it in the ECU. Granted, it probably would only take 10 - 15 minutes for someone who knew what they were doing, but it was more complicated than I cared to get into at the time.
I believe it's supposed to add about 60HP for the N63TU?
2017 BMW 650xi Gran Coupe | MSport | Exec Package | Driver Assist Plus | ACC Stop & Go | Adaptive Drive | B&O | Night Vision | Cold Weather | Active Seats
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching
Previous: '14 550xi, '07 335i, '01 325i
      06-29-2014, 07:27 PM   #6
naamanf
Drives: '14 550i '10 MDX '79 TA OH-58D
N63TU looks to be super easy. Pull the top off, connect to each MAF sensor, put top back on. Looks like it should take about 4 minutes if you take your time.
Seriously looking to pull the trigger on these.
335d M-Sport/Everything + Individual, 550i M-Sport ED APR 2014
      06-29-2014, 07:37 PM   #7
ezmaass
ezmaass's Avatar
Wow! I'm going to take a look to see what the instructions look like. If it's that simple, I may seriously consider it. I really don't think I *need* more power - most of the time I can't find a way to use what I've got - but for $600, it's hard to turn down the extra boost.
      06-29-2014, 07:52 PM   #8
ezmaass
ezmaass's Avatar
Just looked at the install instructions... and wow, it couldn't get any simpler. This is WAY easier than any of the previous JB tunes. Looks like the N63TU just requires literally two boxes to be plugged-in under the engine cover. Now this may become a bit tempting.
      06-29-2014, 08:08 PM   #9
Eli550
Where did you get the instructions from?
      06-29-2014, 08:33 PM   #10
Eli550
When I install I will post pictures.
      06-29-2014, 10:50 PM   #11
ezmaass
ezmaass's Avatar
Eli - go to the BMS website, look up the N63/N63Tu product. On the product page there's a big graphic that's a link to their install guide. You can scroll to almost the end of the guide to see the N63Tu instructions - the majority of the guide before that covers the N63/S63/S63Tu engines... all much more involved.
The N63Tu install looks literally like... (a) pull the engine cover off, (b) plug the left JB box in, (c) plug the right JB box in, (d) enjoy!
It looks like the whole thing should take less than a few minutes. The previous installs I've seen (such as the N54) were fairly involved... literally pulling out a bunch of stuff from the engine bay to get to the ECU box, and then half a dozen connectors being rewired in there. Still not amazingly complex, but clearly those installations would take 30 minutes or so and some more tedious (and careful) work. The N63Tu install looks to be simple enough that a novice should be OK with it (myself included!).
      06-29-2014, 11:06 PM   #12
ARC550
Drives: M3, X5, 720s, X5, 750xi
After you install crank that dial! Big POWa!!
      06-29-2014, 11:53 PM   #13
ezmaass
ezmaass's Avatar
Looks like they say to only adjust the dial upwards if you have either other aftermarket hardware or are using race gas... ?
Do you know what the OOTB boost is? The site's marketing says "up to 60whp" for the N63Tu... presumably this is under the highest setting? Would be nice to have more info, but I can't find much more on the BMS site.
      06-30-2014, 04:07 AM   #14
combatbmw
Drives: 20' X3M CP
It came with directions, follow them.
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 |
      06-30-2014, 03:06 PM   #15
naamanf
Ordered. Will see how it goes.
      06-30-2014, 04:00 PM   #16
ARC550
I have it cranked at the 3PM setting and the car is running like a BEAST! its been like this for almost 7K miles no probelms lol. I dynoed 480/540
      06-30-2014, 07:28 PM   #17
ezmaass
ezmaass's Avatar
Holy cow! That's up there!
      06-30-2014, 09:45 PM   #18
combatbmw
Drives: 20' X3M CP
Im at the 2'oclock. Running strong. I'd go higher but im in cali, only running 91 w/octane booster.
But I do have catless downpipes/3inch full system.
      06-30-2014, 10:01 PM   #19
ezmaass
ezmaass's Avatar
Looks like the default setting is 11 o'clock from what I can see. Do these setting correlate to PSI in additional boost? Any documentation on it?
      06-30-2014, 10:30 PM   #20
ARC550
My experience is every time the dial goes up I saw an increase of 20whp and 20wtrq on a dyno jet.
My 12 o clock setting netted me 480/540. .. Do the math if I crank that all the way!
      06-30-2014, 10:31 PM   #21
Eli550
What octane are you running and do you have any other engine mods?
      06-30-2014, 11:01 PM   #22
ezmaass
ezmaass's Avatar
I'm wondering how long until you'll need new turbos though? This needs to be seriously pushing the PSI of turbo boost.
