03-17-2020, 09:37 PM | #23 | |
Rep 5,365
03-18-2020, 11:21 AM | #24 |
Rep 14,522
been watching a lot of youtube videos on this now. seems like a good idea. so as long you get one with a good baffle and probably with a clean look and not a mickey mouse type of install. gonna keep searching on a decent oil catch can that blends well with the engine bay. probably spending anywhere from $125-200. anyone have recommendations or links?
03-18-2020, 06:43 PM | #25 |
Rep 1,126
I just installed Dorch HPFP, car is at 50K miles, had Pure stage 1 at 20K, than Pure stage 2 at 35K, valves look pretty clean. I do full throttle everyday till 100-110mph. Don't need catch can.
lsturbointeg9158.50 |
03-18-2020, 07:04 PM | #26 | |
Rep 5,365
03-18-2020, 09:25 PM | #27 |
Rep 1,442
Drives: 2011 535i 6MT
Here is a video that explains the advantages for DI engines, another topic of discussion on this forum. As well, it reviews a 25 dollar can, a 100 dollar can, and the Mishimoto can! Good review.
I now know why on each intake I had build up on my values on one side, but not as much as the other... very interesting! Last edited by BimmerHausPerformance; 03-19-2020 at 08:47 AM.. |
03-19-2020, 07:05 AM | #28 |
Rep 14,522
we noticed some oil in the intake when we were pulling things apart so that's what got me thinking about maybe doing a catch can. plus it would probably help lessen the amount of carbon build up on the valves
03-19-2020, 07:06 AM | #29 | |
Rep 14,522
03-19-2020, 08:25 AM | #30 | |
Rep 423
Checkout my YouTube channel, Like and Subscribe. https://www.youtube.com/user/Gjohnson7771 MHD Flash, RVG Catless DP, RVG CP, RVG Boost Pipe, Walbro 455 LPFP, Style 433 Wheels, BC Coilovers, Ebay Strut bar, M-Sport Front Conversion, RVG FMIC, 6WB Cluster. |
03-19-2020, 08:47 AM | #31 |
Rep 1,442
There is the link, that video explains why blow by creates build up. |
03-19-2020, 09:05 AM | #32 | |
Rep 14,522
03-19-2020, 09:06 AM | #33 |
Rep 14,522
Yup. Seen that one along with others
03-19-2020, 09:35 AM | #34 |
Rep 423
Well guys, let me know if you need any feedback from me on the $25 one I installed in my video? I think it is well worth it and it has been doing a good job of collecting blow by.
lsturbointeg9158.50 mangos86q4.00 |
03-19-2020, 09:47 AM | #35 |
Rep 14,522
that was a great video btw! the catch can you used is that a baffle design? i did see you remove the cap but i've seen some other cans that had a filters and what not. it's nice that it's got a dip stick included
03-19-2020, 10:08 AM | #36 |
Rep 423
Sorry, I didn't realize the link wasn't included in the video description. I just added it.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 That is the catch can I purchased and installed. Yes, it does have the baffle design, however I don't believe I can remove it. I saw a video from another guy online, that seemed to have the same setup, but the baffle port could be unscrewed and he was able to insert additional material as a filter. I will double check mine again. |
03-19-2020, 10:17 AM | #37 |
Rep 423
As a side note. As you can see from another review video here.
https://www.amazon.com/vdp/c7b469a0f..._OvibJXkrJL4Qd The catch can does come with a extra "filter" (Looks like a scrubbing pad) that you can leave in the can for additional filtering. I'm currently running my can without it. Not sure if I will add it or not. |
03-19-2020, 10:19 AM | #38 |
Rep 1,442
How often do you have to empty it out?
I bet the VVT Valve cover filter thing would help improve PCV as well... |
03-19-2020, 10:40 AM | #39 |
Rep 423
I've only emptied it once, at about 1500 miles. I documented it in my Intake valve cleaning video. The container was a little over 1/3 full, but I know I was having an internal vacuum leak issue with the valve cover. We will see how that affects everything.
04-13-2020, 01:55 PM | #40 |
Rep 1,557
Drives: F10 M5 & F85 X5M
I remember I installed one on my 135i with an N54,
I thought N55s didn't need one, that issue was fixed with the new engine Am i wrong? |
04-13-2020, 01:58 PM | #41 |
Rep 1,442
Debatable... look at how much Johnson pulled out of his! I suppose "needed" is a strong word. It's needed in any car with blow by, so eventually we'll all "need" it.
I look at it as preventative - it won't hurt anything and if you get one with a vent it'll relieve unwanted pressure as well. |
04-14-2020, 08:38 AM | #42 | ||
Rep 14,522
04-14-2020, 09:01 AM | #43 |
Rep 1,442
How many miles do you have on yours? Have you pulled your intake mani to see how your valves look?
04-14-2020, 10:51 AM | #44 |
Rep 14,522
i have 100k on the odometer. Burrninja when he pulled the intake housing off notice some oil there too! we did pull off the intake manifold but i don't recall if we looked to see how the valves looked. when i pulled my cp off it also had oil as you can see. i'm sure at least putting the oil catch can should limit the amount of blow off vs leaving as is. anything helps really. at least that's the consensus from watching all those oil catch can reviews of whether it's a good idea to have them or not to have them
