2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications New Injectors Good For 600+hp
      06-16-2021, 04:06 PM   #23
$howtime456
$howtime456's Avatar
301
Drives: BMW 640i
Originally Posted by ziekxq View Post
That... my goal figure out dual lpfp solution.
+ bmp4 fuel module
+ port injection kit
+ motiv reflex
+ e85 line with sensor.
Where did you get the line with sensor for $250? Spools is almost 400 dollars.
3k+ job lol then onto sending trans and torque converter to pure transmission for upgrade plus transfer case clutch upgrade/rebuild.
Then upgrade axels to hold extra power from stop light launches lol before they bent.
that sensor you can get anywhere. amazon. ebay. $35. Its a GM sensor. just need the fittings to attach it, or in you want to go from the tank bank fuel it sells the line i beleive.
N55 GENERAL
David Shoup Tuned
Fully Built By Miami Engines/Project Motorworks
Precision 6266 On Steroids
      06-16-2021, 04:35 PM   #24
ziekxq
Drives: 2011 535i xDrive
Originally Posted by BrowBMW View Post
One lpfp pump can supply both port and direct injection? What size lpfp are you running and what size injectors?
Nope... need two pumps connected via y line at the tank then also y line between hpfp and port injection fuel rail that connects to the intake manifold.
The problem is our cars don't have a bucket per say in the tank its a fuqing donut with lpfp stuck in the middle. So unless we can fit a bucket in there or some sort of alternative I don't know. Showtime says spool got something but they never replied to me. David Shoup said he will check for me and get back to me so let's see.
      06-16-2021, 04:37 PM   #25
ziekxq
Thx... I will check it out.... BTW did you get your diff upgraded or still running stock ones?
      06-17-2021, 03:18 PM   #26
$howtime456
301
Drives: BMW 640i
still stock ones
N55 GENERAL
David Shoup Tuned
      06-20-2021, 10:11 AM   #27
$howtime456
301
Drives: BMW 640i
They have arrived. Hopefully will get to test these out after breaking in the motor
N55 GENERAL
David Shoup Tuned
      06-20-2021, 09:49 PM   #28
burro_blasta
Drives: 2013 535 M Sport
If someone could answer a dumb question:
I got an upgraded hpfp (spool fx150) when I got my ps2 although I'm only on pump - no e - is there any point to upgrading injectors (and tuning accordingly) on a setup like mine?
2013 535xi M Sport (PWG) // PS2 // Spool fx150 // MHD // xHP // FTP Inlet // FBO: AR HF DP, Wagner IC, BMS Intake, VRSF CP
      06-21-2021, 09:30 AM   #29
ziekxq
No point... these are really meant to be for people who want to push more ethanol.... you can probably push more fuel but can't change the octane rating on pump gas.
      06-21-2021, 09:39 AM   #30
burro_blasta
The pushing more fuel is the part I'm wondering about:
After the ps2 it was worth upgrading the hpfp in order to push more fuel - even just pump gas - and add more boost...at this point I don't understand whether the stock injectors happen to be the constraint or something else before something more could be done with just pump gas
      06-21-2021, 11:05 AM   #31
ziekxq
Hmm what boost psi are you running on pure stage 2 on pump gas? And what boost psi were you running before upgrade of hpfp? My understanding is more boost requires higher octane or engine will knock, so pushing extra fuel with low octane rating won't do much. Anyone can correct me if I am wrong.
      06-21-2021, 12:54 PM   #32
burro_blasta
IIRC, running PS2 with a stock HPFP (the newer kind, not your N54 style) limits the psi to around 16-17 and upgrading the HPFP enables you to get up to 20ish
Wondering if that's sort of just the limit for pump gas, or maybe if it just so happens that then the injectors become the limiting factor and this upgrade might actually be worthwhile. But, small chance, I figure.
      06-21-2021, 05:58 PM   #33
$howtime456
301
Drives: BMW 640i
yes everyone is right. In order to reach anything above 21psi+ you will need a HPFP. Stock cant keep up. Especially if your running e85. The more e85 you run the more strain you put on the fuel system. Especially the primary LPFP. Even when you have the LPFP and HPFP you then will put a strain on the fuel injectors. When tuning you want to keep the LPFP happy. The stft must stay between +5 and -5. You also dont want to max out your fuel injectors or the rail pressure will crash. Everything has to flow in accordance.
N55 GENERAL
David Shoup Tuned
      06-21-2021, 06:55 PM   #34
$howtime456
301
Drives: BMW 640i
So good news. Just spoke to Jake on the MHD forums. He said for the n55 the injectors will be added on the checkbox!!
N55 GENERAL
David Shoup Tuned
