2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications BM3 LOG/// weirdest symptoms of a tuned F10 after injectors replacement
      11-15-2023, 07:37 PM   #1
00866b
Drives: Bmw 535i
Hi guys , so my F10 is a mess rn and idk what to do.
So let’s start with what the car has been done to it :
Stage 2 E30 agg on bootmod 3
Intercooler upgraded
Catless downpipe, straight piped
Pretty much a full bolt on except hpfp upgraded just yet waiting on dorch to ship the pump.
I fill it with 6 gallons of gas btw for almost a year now
Anyways , the car has been misfiring for some time last year before e85 gas was being put in , I’ve asked this forum n yall said if it can’t b the plugs or the coils , it got to b the injectors , at that time I only replaced the plugs and got precision raceworks ignition kit ,
Keep in mind oem injectors were never replaced and the car has 69,443 miles Fast forward to last week my car got the EU6 injectors , so I was like fuck it since imma get the stage 2 dorch hpfp lemme get the EU5 injectors , and that’s what I did ,
I replaced 3 things while I was gon open the car for the injectors :
Ngk plug: gapped to .20 ✅
I contacted PR n asked what do I gotta change the wires for the coils or the whole block thing , they said the wires , so I’ve ordered 6 wires and replaced those ✅
And replaced the injectors with Eu5 and coded it with protools app on android .
First startup the car was idling rpm crazy , but it Settled down after it warmed up ,
Then I got a CEL and saw this first codes :
118001
Mixture control: Mixture too lean
140302
Combustion misfires, cylinder 3: harmful to exhaust gases after starting
140502
Combustion misfires, cylinder 5: harmful to exhaust gases after starting
140002
Combustion misfires, several cylinders: harmful to exhaust gases after starting
140310
Misfires, cylinder 3: detected
140510
Misfires, cylinder 5: detected
140010
Misfires, multiple cylinders: detected
11CF30
Mixture control: Group error
At that time , it was November 7th , but it would only show symptoms of misfires upon startup not during WoT
Fast forward to November 9th at 5:18pm I got these codes upon wot
118001
140102
Combustion misfires, cylinder 1: harmful to exhaust gases after starting
140110
Misfires, cylinder 1: detected
140302
140502
140002
140310
140510
140010
1BC112
Zero gear sensor, electrical. Snort
I cleared the errors and fired my car up at 8:49pm and got these codes
140302
140502
140002
140310
140510
140010
118001
Fast forward to November 11 I got these codes , the reason why I clear the codes is bc I only use this car to go to gym after work so for the whole month I’d only typically drive the car 50 miles anyways :
140401
Combustion misfires, cylinder 4: Injection is switched off
140001
Misfires, multiple cylinders: Injection is switched off
140410
Misfires, cylinder 4: detected
140302
140502
140002
140310
140510
140010
140011
Combustion misfires: Injecton s
And I’m like .??????? I thought cylinder 3,5 was bad but now 1,4 too? I cleared the error n they gone but 3,5 was kept showing
Here’s this : central gateway codes if it ever matters :
101008
Non-resolvable ambiguous routing - SG not in the SVT target table
100600
Flexray protocol startup time is too high
100104
HW Weckgrund ZGW
100001
VemResultSvtCheck - identity check: Differences between the SVT actual and SVT target have been recognized.
anyways ,
Today , I finally go to gym again, rough idle , drives smooth but I feel like there’s loss of boost pressure and power and mpg is 9.0
While driving out of no where I got a
“Drivetrain malfunction error” 5 seconds later it disappeared, I parked my car checked BimmerLink, bootmod3, and xHP for diagnostics. Nothing for the drivetrain
But upon checking bootmod I got these codes : 119304
Rail pressure sensor, plausibility: pressure too high before engine start
118001
140302
140502
140002
140310
140510
140010
I don’t know what to do anymore , I thought replacing all 3 plugs , injectors and coils would do it but it made the car even worse .
On top of that now , I hear a sudden “thumb/clunk,” wtv I let go of the gas pedal from the middle of center console or in the rear seats ,
I hear that stomp sound when I press on gas pedal or let go , it lowkey sounds like it’s coming from the tank under the seats .
Idk what to do anymore please help oh yeah here’s the log I’ve logged
April1st (the only log I have before I swapped the injectors)
November9th (the day I turned the car on after I swapped all 3)
And today after mid 70% wot
      11-15-2023, 07:39 PM   #2
00866b
Drives: Bmw 535i
Like I already contacted ecs tuning , bc before I’d install the injectors , 3 of them were opened packaged with signs of used / dirt marks , since now it’s been misfiring does the plugs needs to b replaced too? What about the pr coils wires?
      11-17-2023, 04:26 PM   #3
NikMN
Drives: BMW F10 n63tu
Take it to your favorite indi. Don't forget the cc.
      11-17-2023, 07:00 PM   #4
00866b
Drives: Bmw 535i
What do you mean ?
      11-18-2023, 07:54 AM   #5
NikMN
I mean wot isn't going to solve your issues but mechanic will
