2010 2011 BMW 5 Series Forum F10 Hum at 60mph - 520d Auto |
05-16-2014, 08:45 AM | #1 |
Rep 63
Hi,
I've covered 6k since April 1st in my 520d M-Sport and I've noticed that at exactly 60mph the car hums - it sounds like a fuel pump or at least some kind of pump. It is only audible at exactly 60mph - just the speed the gantrys on the M62 seem to love. Has anyone had this issue, or do I need a trip to the dealers? |
05-17-2014, 12:56 PM | #3 |
Rep 63
Thanks for that, back to the stealers it goes then...
It has been there since day one, guess something is not quite right. The lack of replies suggests it is not something others are suffering from. No what the dealers would call a 'characteristic' of the car. |
05-17-2014, 06:20 PM | #4 |
Rep 181
Definitely not a "characteristic" don't stand for that if that's what they say
05-29-2014, 05:01 PM | #5 |
Rep 322
If it's at about 1700 rpm, then it's the same as mine, which occurs only from time to time, and my understanding is that it's the DPF doing a purge.
Anyways, get it checked out and let us know what the dealer sez. |
06-03-2014, 03:44 AM | #6 |
Rep 63
The car needs a new rear differential, apparently. Part ordered and will be fitted tomorrow. Seems a pretty major part of the transmission to require replacement, but as the car has done it from new I suspect it was a bad unit from the factory.
06-13-2014, 04:15 AM | #8 |
Rep 63
Nit as quick as you might imagine. The new diff required different "bolts" or the wrong bolts were ordered/supplied. When they finally installed the diff, it hadn't solved the problem, the next solution is on back-order, so I could come and get mine in the meantime. Bearing in mind the 118d Sport manual wasn't exactly the nicest loan car I've had (that honour goes to the 530d GT M Sport with pano roof) I was happy to take the car back.
When I came to collect the car I was a bit late so sales had the keys. All was good until I opened the door to find gear oil smeared across the door panel, seat and centre console, worse still it was engrained into the oyster stitching. The red mist descended! I left the car, got back in the 118 and told them to call me when it was showroom perfect, which apparently it was by Monday afternoon, a manager was satisfied, apparently. On Wednesday I went to find it certainly wasn't showroom perfect (this particular dealer couldn't prepare a salad, so I wasn't shocked), they did manage to clean the stitching, but required supervision. As a gesture they put £20 in the tank. How generous. So nothing has changed really, the hum is a bit better, the car is now as clean as it was when it went in, save for the additional coating of back to black on the tyres, which is apparently what constitutes a valet! On one had continued slip-ups by the dealer are frustrating, they seem more bothered about getting their loaners back than fixing my vehicle and major engine/transmission problems seem to be a recurring theme with my MINIs (2.0 SD) and BMWs. On the other hand I'm very tempted by a 525d....maybe third time lucky? |
06-13-2014, 07:38 AM | #10 |
Rep 63
It's Bradford.
Things have improved dramatically, there is a new team who are, on the whole, polite and they are much better at keeping you up to date with progress. In my experience York are probably the best in the area, Leeds are variable. I haven't used Huddersifeld or Wakefield. |
06-13-2014, 09:46 AM | #11 | |
Rep 267
When you think of the number of CustSat surveys they run about their products & services - and then do this ! If I were you I'd 'bring it to the attention' of BMW in Bracknell .... I'm sure they will impress upon their Dealer how dissatisfied you are, and maybe even make better redress ...
M140i LCI-2 is the 16th BMW since 1977 ....
320i *2, 323i, 520i *2, 540i, 535i, 840i, E36 M5, 328i, 530i, 320d, 535d, M135i, M140i * 2 |
06-13-2014, 10:50 AM | #12 |
Rep 181
Sorry to hear of your troubles bd. Seems like there's a fair few problems with this years 520d's from steering vibrations to drivetrain faults (which I'm also experiencing at the moment)
As speedtrip mentioned, let customer service know of your problems. |
06-13-2014, 12:48 PM | #13 | |
Rep 33
06-27-2014, 04:08 PM | #14 |
Rep 63
Well the car went in again today for a rear prop shaft bearing to be replaced. Courtesy car was a smelly 116d with wing damage, noting else available apparently. Oh well, it's only for the day.
They rang at lunch, the part was fitted and the problem solved. Road tested by the workshop controller and the Noise is gone. On collection, more oil in the cabin, this time on the seats and steering wheel. On the test drive the hum is better, but I was not convinced the noise was gone. The technician with me couldn't hear anything. I agreed to go home and see how things develop. On the M62 the hum is still reproducible at 60, so back it went to Bradford. Out with the controller and one of his team. The hum was still there. It's been agreed to raise the issue to "technical" next week, apparently there is nothing else to replace. At this stage the attitude of the dealership is beggining to to get on my nerves. On one had the noise is much improved, but I don't think it should be there at all. I've made it clear that noting short of no hum at all is acceptable and that if that can't be achieved with one more visit then I will reject the car. |
06-28-2014, 04:46 AM | #15 |
Rep 619
Sorry to hear, I have to say, I would be kicking off to merry hell if my oyster had oil on it, the dealer principal would know and they would be keeping it until it was immaculate, whilst I took his car home. Nothing less. That does'nt even cover the technical problems I know, that would be solved after the above was dealt with!!!
Generally I am not one to complain, but after buying a 40k plus car, that I am afraid would not be acceptable.
2017 F10 535d MSport Auto - Mineral Grey - Oyster leather - 19" 351M's - Pro Media - Enhanced bluetooth - MSport rear spoiler - Sun protection glass - Harman Kardon Hifi - Multi Function Display - Ambient Lighting - Folding mirrors - Sunroof - LED adaptive headlights
06-28-2014, 08:24 AM | #16 | |
Rep 628
G30 530d M Sport xdrive, Adaptive Drive and with all of the important options. |
07-19-2014, 06:52 AM | #17 |
Rep 63
Balster, did you get any goodwill gesture from them. Or did they just clean what they shouldn't have put there in the first place?
The hum is still there, and getting refer audible once again. Since it's been back the auto seems a bit dim, not as smooth as it was. BMW tech are coming to have a butchers on Monday at the dealers. I'm hoping they can help pin-point where the issue is coming from. |
