2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Exhaust valve Open: how to
      01-05-2014, 04:18 PM   #1
ARC550
Drives: M3, X5, 720s, X5, 750xi
Does anyone know the proper way of zip tying the mechanism that keeps the valve open? Is there a how to? What is recommended? Zip ties? Or wire?
I am looking for an increase I'n noise without upgrading exhaust. Thanks.
      01-05-2014, 04:24 PM   #2
Lee
Germany
64
Drives: '17 X5 50i/'01 Z3
Check it out, halfway down the thread. I managed to do it and I'm not handy at all. Noticed a slight increase, but not as much as the 650 on the clip.
http://f10.5post.com/forums/showthre...&highlight=zip
      01-05-2014, 05:17 PM   #3
ARC550
Thanks for the info. Much appreciated.
Would you happen to have a video of your car? Sound sample?
      01-06-2014, 01:30 AM   #4
audiogolf
audiogolf's Avatar
40
Drives: 2023 X7 40i
AR,
i am planing to do this...
http://f10.5post.com/forums/showthread.php?t=630331
this will take care of the flaps..
      01-06-2014, 10:33 AM   #5
ARC550
Great!! Maybe we can do it together!.. I will be honest I Really like the trapezoid exhaust. I think I will do that but retain the original look. i just need a little more noise.
      01-11-2014, 12:38 PM   #6
ARC550
I just did this mod and it took 5 minutes .
I used 10 inch zip ties. It was easy considering the maneuverability of the long ties.
The slight increase in sound (10%~15%) . Honestly It is not really noticeable unless it's a cold start.
Verdict: this car needs mufflers/ exhuast's.
      04-30-2014, 06:48 PM   #7
obiltagi3
V.I.P.
obiltagi3's Avatar
Drives: F10 535i 2011, F10 550i 2015
2015 BMW 550i  [9.00]
I cannot figure out where those vacuum springs are on a 2011 535i.
Instead, I found a connector (looks similar to the E92 golf tee mod connector) on the left side just between the diffuser and muffler tucked in. I unplugged it, did notice a slight increase in noise, Although it threw a TPMS Error I am unsure if that plug was for the vacuum line for exhaust or the TMPS.
ANY feedback if that connector is the right one, how I can find this setup for a 2011 535?
F10 550i Imperial Blue/Ivory
BM3 Stage 1 - xHP Stage 1
F10 535i Alpine White/Oyster
BMC - Vorsteiner Exhaust - ER Chargepipe - AR Catless DP - MHD Stage 2 - FMIC
      05-03-2014, 07:25 AM   #8
srs_bsns
Drives: 2017 i3
I'm PRETTY sure that the 535 doesn't have the valves.
Just did it on my 550 and noticed a slight increase in sound, but definitely need a a new exhaust/muffler eventually lol.
      09-21-2016, 08:05 AM   #9
danfratamico
danfratamico's Avatar
Drives: 2007 BMW 335xi
2007 BMW 335xi  [0.00]
Do you know for sure the F10 535 doesn't come with the exhaust valve? Seems strange since I've been reading the 528 has it and so does the 550. Doesn't make sense that the 535 wouldn't. Can anyone with a 535 confirm this?
      09-21-2016, 03:48 PM   #10
TTG
TTG's Avatar
Drives: M340
Pretty simple. Wait for cold weather to come in and start your 535 to see if both pipes are active.
My E92 335 had valves and they were deactivated by unplugging the connector in the trunk. This does not appear to be the case for 535s.
2016 F10 535i xDrive - AW - Retired
2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired
2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired
      09-21-2016, 03:50 PM   #11
danfratamico
I actually don't have a 535, which is why I was asking. I know you can check, I have it on my E90 335. I'm curious to know because I like it and will be sad if it's not on the 535.
      09-23-2016, 09:53 AM   #12
TTG
TTG's Avatar
Drives: M340
It was cold enough this morning. Both Valves are open on the 535 at idle and it appears that both pipes are functioning at the same time.
The car doesn't sound anything like the 335 though. It is much much more quieter.
Hope this helps.
      09-25-2016, 04:37 PM   #13
xxpanipuri
Drives: 550i
You can also buy an exhaust Meister (Google it)
Gives your flexibility of keeping valves open or closed as you need it
      09-25-2016, 10:15 PM   #14
TTG
TTG's Avatar
Drives: M340
May be for a 550, there are no valves on the 535 as OP was asking.
