2010 2011 BMW 5 Series Forum F10 Car Vibration when Braking |
09-20-2011, 08:15 AM | #1 |
Rep 1
My F10 Has now been back to the Garage 3 times for new Discs (done 22000 miles) as I keep getting vibration through the car under normal braking. When they put new discs on they are fine for a few thousand miles and then the problem returns. You can feel a slight vibration through the car when driving too. Anyone else had anything similar? The car is great but this problem is really getting to me. Ive not had a BMW before, my last 2 cars were Lexus and absolutely faultless, BMW is so far proving to be a bad choice.
09-20-2011, 04:53 PM | #3 |
Rep 440
Check the rotors for warpage or runout. That will always cause vibration with breaking. While my Lexus was great it did also have vibration when breaking and the dealer corrected it by shaving the rotors to make it true again at 40k miles and the brake pads were replaced at 45k.
09-23-2011, 11:22 AM | #4 |
Rep 582
1 on that! Every Lexus I owned warped the rotors except my 92 sc400,after that all warped.You can have this problem on any car but will have to pay for a brake job.
2015 M6 Gran Coupe> DME stage 3 tune back end flash>JB4 with Methanol control>Fabworx Catless downpipes>Full Meistershaft GTC exhaust 102mm GB tips>Built motor with Forged Cp Carillo Rods and Pistons > SSP spec X clutch > Stage 1 Pure Turbos>PG front mount intakes>PG charge coolers>Vorsteiner front and rear Carbon diffuser>Auto Tecknic Carbon shift paddles>3D Design aluminum pedals
10-12-2011, 05:26 PM | #5 | |
Rep 25
10-13-2011, 04:01 AM | #7 |
Rep 61
Do you by any chance wash your car when your brakes where hot?
Or maybe you did drive trough a puddle of water with hot brakes.. Both could de-form your discs because of the big difference in temperature. It's just an idea because I've had it twice allready with my old BMW (e30) but no problems so far with the F11. A friend of mine did have the same issue wit his M3 (e46), he changed the front rotors and pads and the problem was solved. But it also came back after some time, no clue what the actual problem was because he sold it some time later. |
10-13-2011, 08:04 AM | #8 |
Rep 585
Although BMWs are made with vents in the front air dam that are directed at the front brakes, they can still get hot. If you go through a car wash (heaven forbid) or wash the wheels, you should always allow the brakes to cool.
10-13-2011, 07:47 PM | #9 |
Rep 135
Your brake rotors could be getting corroded due to some outside source. Chlorine or salts can seriously corrode brake rotors and cause the vibration. One possibility.
06-13-2013, 02:46 AM | #10 | |
Rep 5
I wonder if you have what solved the vibration?? I have the same problem! |
06-16-2013, 11:47 AM | #11 |
Rep 78
I also had vibration issues.. replaced the front discs and got rid of the problem.. but my BMW technician told me that the problem could be that some bearings should be replaced or else the damage of my discs could happen again.. o_O
06-22-2013, 01:47 PM | #12 | |
Rep 1,730
13 F10 535xi JB/B working on it
11.75 E93 M3 MR/Black Stock (wifey) 11 F10 535i AW/CB Mods Gone |
08-20-2017, 03:15 PM | #13 |
Rep 3
I have the same problem. Already 3 sets of rotors and pads changed. Problem is solved after changing rotors and pads but reappers after 5000km.
Calipers also checked. It seems they are ok. Did you finally solved the problem? If so what it was? Thanks |
09-01-2017, 07:30 AM | #14 |
Rep 80
Another thing to check would be the lower control arms, took me a while to find this on my X5
2001 530i
2004 330i 2006 X5 4.4 the beast 2014 328i 2012 535i |
12-23-2020, 07:40 PM | #15 |
Rep 3
Hello I live in Taiwan, I have a BMW F10 ActiveHybrid5 (2012) with 80km/hr brake jitter problem. It was repaired 7 times in the BMW factory. They changed 3 sets of new brake discs,4 brand new aluminum rims and tires and one direction The machine during the repair process, it 's about 3200 kilometers the same problem reappears again and again every time. Does anyone have the same problem? How to solve the problem? thanks
04-20-2021, 01:05 PM | #16 | |
Rep 2
Picture of damaged Zimmermann rotors after only 20k km https://ibb.co/4NyDBrL Thank you. |
04-28-2021, 10:26 PM | #17 |
Rep 1,035
2016 XDrive 335d here, just purchased with 90k km (56k mi) and original brakes were pulsing badly.
Replaced with one piece aftermarket rotors and Bosch pads, and after only a few months of driving the brakes are pulsing, not slowing smoothly. This can be felt even at low speeds. Has anyone figured this out yet? I'm wondering if one or more hubs are not machined true. If that were the case no new brake rotor will ever fix the issue. |
04-28-2021, 10:32 PM | #18 |
Rep 504
Drives: 2013 BMW F10 N55 535i XDrive
Vibration while braking...even more with heavy braking, check those rotors
04-28-2021, 10:35 PM | #19 | |
Rep 1,035
Even being driven gently there's an issue with my brand new brakes after only a few months. |
musclesmarinara75206.00 |
04-29-2021, 09:20 AM | #21 |
Rep 2,590
If you have a diesel, how are you engine braking?
2015 BMW 535xi
04-29-2021, 06:30 PM | #22 |
Rep 1,035
It engine brakes quite well, especially around town at lower speeds in lower gears. According to Wikipedia there are several ways modern diesels create effective engine braking:
https://en.wikipedia.org/wiki/Engine...ng?wprov=sfti1 I imagine with the advantage of a very flexible valve train, they could force the engine to operate in a similar fashion to the heavy diesels "Jake Brake" by releasing compression. I drove truck during college as a summer job, and though the International 466 I drove didn't have a Jake Brake (and had less power than my 335d!) you could still get enough engine braking out of it to make it worthwhile downshifting on long hills to take some load off the service brakes. |
