2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums ASIA My proposed mods
      07-26-2011, 03:00 AM   #1
AsiaKid
Drives: GTR/Gallardo Spyder/X5
My proposed mods
A bit like kfiend's
white body, cf splitter in black but Msport front, cf spoiler, black f14's (maybe changed to forged 1 7's afterwards), whitelines, KW V3 (deposit in), pbx (not installed yet), change all the roundels to carbon.
optional: hamman exhaust
any advice?
on a serios note, pros vs cons of paint and vinyl?
      07-26-2011, 03:12 AM   #2
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
2011 F10 528i  [10.00]
complete make over?
window trims must be black with your set up.
CF splitter in black, do you mean painted black CF or just CF with no paint?
Personally I prefer a full lip than a splitter for F10. Splitter may be good for the E9x.
How about CF roof with white body? Just a thought with your proposed look.
I wouldn't repaint your car. It's still quite new. resale value will be affected.
Also, you must have the black grills either matte or gloss or may be the black side gills with your set up.
2011 F10 528i Black Sapphire / Oyster Black
2000 E46 325ci Cabrio Titanium Silver / Black - retired
1997 E36/7 Z3 Montreal Blue / Black - retired
      07-26-2011, 03:14 AM   #3
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
BTW, I think your car will be more like 78mao's. kfiend has no m sport front (not sure if he has it now as he has disappeared).
      07-26-2011, 03:51 AM   #4
AsiaKid
Yes, i think that is a good resale option too.
I will probably keep the CF untouched. but yes, u reminded me..if i do the vinyl, i will also get them to black out the chrome trim and maybe order the black kidneys
      07-26-2011, 04:04 AM   #5
jxnco
Hong Kong
33
Drives: BMW F10
Sounds like it's going to be one mean looking car!
Mine is white as well and I love it! Be prepared to get dust/black specs on your car and these can be easily seen. Dark colored ones get swirls, light colored ones get the black specs. Nothing is perfect.
Agree with RC3. Just have it wrapped. Check this out:
http://x3.xbimmers.com/forums/showthread.php?t=552323
You can mix it up. Since car is matte, you might want to go gloss black grills, gloss window trims, and gloss rims. Or just do matte for everything.
      07-26-2011, 04:04 AM   #6
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
Just ask the guy to wrap the parts you wanna black out. You paid already, why pay more?
re-painting another color is easy to spot. they won't paint the inconspicuous parts like under the hood.
      07-26-2011, 08:56 AM   #7
tinybeammer
Singapore
14
Drives: F10
Sounds good happy modding...
Cheers
Tinybeammer
      07-26-2011, 10:19 AM   #8
AsiaKid
I think i will probably just do a very glossy/bright white.. the matte white is a bit too MK.
But the wraps i seen for bright white is not as glossy, so will hope if they got it as bright as typical paint.
      07-26-2011, 10:47 AM   #9
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
AsiaKid, I wanna propose 3 mods for you since you are into performance mods with the PowerBox and V3. And you probably need these for your reckless driving at 160-200. 2) and 3) will improve the performance of our N53 engines.
1) Brembo GT Kit for front 6 piston calipers
This line is dedicated to the most demanding customers. This braking system originates from the Racing components, consisting of a ventilated, integral or composite disc, available drilled or slotted, 4, 6 and 8 piston aluminium calipers, a complete set of high performance brake pads, metal braid tubes and high quality small parts.
1. High Performance Friction Material: Aggressive pads that provide the highest level of performance.
2. Cross-Drilled or Slotted Discs: Clears gasses, cleans pads for better “bite”.
3. Mounting Brackets and Assembly Hardware: Aircraft quality included and pre-torqued specifications.
4. Stainless Steel Braided Brake Line: DOT/TÜV approved.
5. “Floating” Disc Mounting System with Billet Aluminium Hat: Reduce “Unsprung Weight” for better handling and reduces heat-related stress; increases brake performance and pedal feel.
6. Four, Six or Eight Piston Cast Aluminium Calipers: Provide maximum braking force without the flex of sliding calipers.
2) Okada Projects Plasma Direct
A revolution in ignition technology!!
The Plasma Direct is the ignition coil with a high power amplifier built in to it.
The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM.
The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines.
The Plasma Direct will increase horsepower and torque throughout the entire rpm range. This upgrade will also reduce fuel consumption. Even the engines with a legendary smoothness will be further refined with the Plasma Direct upgrade. Our Plasma Directs are OBD II compliant.
Installation is easy. Direct bolt-in to the engine, no splicing or cutting into stock wiring, simply replace the stock coils with our Plasma Direct Coils and ready to go!
Plasma Direct- Plasma Direct is made to a specific application. Please check Application chart to find the correct model for your car.
3) Okada Projects Plasma Ground
The Plasma Ground is connected at the ground side of the ignition coil and increases performance and engine efficiency by creating an ultra fast alternating current at the secondary spark discharge, this is called Coil Ground Tuning.
Plasma Ground works perfectly together with all other Okada Projects Plasma Ignition parts and increases secondary spark discharge current.
Increase in secondary current is extremely important, since it creates a faster burn for high performance engines. The Plasma Ground is engineered to increase spark effectiveness on BMW engines, and is 100-percent compatible with any late model OBD and engine control units.
      07-26-2011, 10:54 AM   #10
AsiaKid
haha..with that big car..brembo is not a bad idea..but not cheap la..very expensive.
What is this plasma stuff? I read it once before, was it from you? I am curious what it is...if its legitimate wouldnt we hear mor e about it?
      07-26-2011, 10:56 AM   #11
KL535
Drives: f10
Just do a re-print if you want glossy white, sure it will look much better than wrapping.
      07-26-2011, 10:59 AM   #12
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
yeah, I had the plasma stuffs in my proposed mod list. A lot of the E9x guys installed them. Popular in Japan. I already enquired the local vendor for the stuffs. If you like I can pass you the info.
As you can see, my mods are all cosmetic and none performance yet. Hey, I am group D, bro.
      07-26-2011, 11:00 AM   #13
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
Brembo just for the front won't be that bad for your wallet.
      07-26-2011, 11:01 AM   #14
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
I suggest asiakid just get a new AW F10
      07-26-2011, 11:02 AM   #15
AsiaKid
hahaa..i am thinking..liek i said..if i should trade in for a AW 535i..haha...but no...i gotta keep some discipline..the problem with cars is that you can keep creeping up and up..and only thing that stops u is ur wallet
      07-26-2011, 11:05 AM   #16
LACSTER
Drives: Hybrid
This thread is going to get expensive!
      07-26-2011, 11:06 AM   #17
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
FYI asiakid, Okada Plasma Direct HKD 8,600 and HKD 3,000 for the Plasma Ground installed.
http://www.okadaprojects.com/usa/products.htm
Not bad for Performance gain.
      07-26-2011, 11:07 AM   #18
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
hehe, Kevin. But AsiaKid is asking for mod advice. Please chime in bro.
      07-26-2011, 11:14 AM   #19
KL535
Drives: f10
Right! But seem you have unlimited mod budget~~! haha!
      07-26-2011, 11:17 AM   #20
LACSTER
Drives: Hybrid
He's on the right track but I'm just going to give my 2 cents on any mod
you do please keep the BMW roundals white and blue.
      07-26-2011, 11:19 AM   #21
RC3
RC3's Avatar
Hong Kong
81
Drives: F10 528i
Oh, the Plasma Direct is also applicable to 535 too. Whereas Plasma Ground is only for the 528
      07-26-2011, 11:24 AM   #22
mlai
mlai's Avatar
Hong Kong
166
Nothing for the 550i?
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT
2011 F10 550i M Sport - Retired
