2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Retrofit TPMS (RDC) from FTMS (RPA) on F10 LCI: flat tire monitoring still active?
      10-26-2023, 10:26 AM   #1
Tony Twoclicks
Drives: 2012 F30 320i
I've been looking into the coding required for retrofitting TPMS/RDC (option code 2VB). Right now my F10 LCI has flat tire monitoring using the ABS sensors (aka FTMS/RPA). My car is equiped with the newer 'DSC_Premium' module, so should be simple with no extra antennas required.
Now, according to info on the web one of the parameters (along with a bunch of other modules) that needs to be FDL-coded is:
DSC_Premium > Allgemein 3000 > Funktion_ReifenPannenerkennung_aktiv = nicht_aktiv (inactive)
My question is: if I do this, will there still be a warning when a tire suddenly goes flat during driving with TPMS/RDC? Shouldn't it be set to 'aktiv_RDCi' like in the F85/F86 for example?
For FTMS/RPA this parameter is currently set to 'aktiv_RPA ohne Koordinatorfunktion im DSC'. Since 'ReifenPannenerkennung' and 'RPA' kinda translate to something like 'tire pressure monitoring', setting this to inactive seems counter-intuitive to me.
Can anyone with an F10 LCI and native TMPS please confirm the correct setting? And if correct, what does 'RDCi' mean?
Cheers,
Tony TwoClicks
Tags
f10, rdc, retrofit, tpms
