2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Dinan Lower Springs with F10 DHP Package?
      12-30-2023, 12:20 AM   #1
SocomCA
Drives: BMW M6
Question Dinan Lower Springs with F10 DHP Package?
Hey guys,
I have a 2016 BMW 550i xdrive with the DHP Dynamic Handling Package and I was wondering if the ride quality would affected if i installed Dinan lowering springs with dinan bump stops or if it would affect the DHP package.
I have 20 inch M5 OEM rims and want to reduce the wheel gap
I want to install these: https://www.turnermotorsport.com/p-3...g-set/?pdk=AQI
      12-30-2023, 09:52 AM   #2
cdmulders
cdmulders's Avatar
Drives: 2013 535xi
Originally Posted by SreeM View Post
Hey guys,
I can't give you a definitive answer, but a related one. I installed the ACS springs onto my xDrive, and it has both the DHP and the ARS. The ride seemed to get just a little bit more sensitive to bumps, but I got used to it almost immediately. The other aspects of driving quality, including cornering, weight transfer, nose diving, etc, all improved. If the Dinan springs are progressive (like the ACS) then it even means that you can still load up the car with as much weight as you like, and it won't go too low. I cannot see any down side with changing the springs to the Dinan. If I remember correctly, they don't lower the car as much as the ACS ones.
2010 Z4 35i, Crimson Red, beige interior, 6sp manual, Adapative Suspension
2000 528i, Cosmo Black, beige interior, Sport package (retired)
      12-31-2023, 12:50 AM   #3
addy27
Drives: F10 550i
First, before you switch hardware, go ahead and buy the Dinan Shockware (should work with your car since you have a 550 drive). If the Shockwave doesn't cut it, then switch our springs for Dinans. The Shockware is great for our cars even with stock suspension
      01-13-2024, 11:41 PM   #4
SocomCA
Drives: BMW M6
thanks!
Tags
dhp, dinan, dynamic handling package, f10
