2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Putting the Car Into Neutral
      12-05-2010, 03:00 AM   #23
gorban
Sweden
11
Drives: F11 520xdAT, E87 120dM
Originally Posted by raleedy View Post
AFAIK the 7-series still uses the 6-speed transmission.
The 760i and 760Li uses the 8-speed transmission.
      12-05-2010, 08:00 AM   #24
grimlock
Drives: F10 N52B30@255PS
Originally Posted by Jon D View Post
So, without lifting the rear wheels clear of the ground, how do you tow it when it's stuck in park?
Doesn't bmw have a button or idrive setting that unlocks the transmission? The only time I got towed by I didn't even have to press the tow button even though it was right there, the little tow truck had a rack which lifted all the wheels clear of the ground -they really do expect to be dealing with car-idiots.
I'm sure there is an easy solution, why do they have the tow bar if u can't unlock the transmission?
      12-05-2010, 11:04 AM   #25
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
If you're referring to the screw-in towing eye, I imagine it's purely for towing other cars.
      12-14-2010, 03:41 PM   #26
ghueser
Drives: 2014 M5
Transmission Unlock Answer
I heard from BMW NA as a response to my question about setting up the Transmission and Electronic Brakes for Towing.
The basic answer is that if the car needs towing, the dealer should be called first. Then if arrangements are made for towing, a flatbed is needed (as they illustrate in the manual) and the back wheels will need to be put on Wheel Dollies so the car can be brought up the ramp. (which would mean 4 Wheel Dollies for X-Drive vehicles)
Keep in mind, this applies to September on production vehicles that no longer have the transmission unlock tool. I noted to the Rep that there evidently is some form of physical movement of the shifter that can unlock it for 15 minutes. He said that the dealers may know of this feature, but that he was unaware of anything specific.
Once again, I really can't fathom any condition that would cause a need to get get towed...outside of an accident. However for ALL F10's, and for a condition of complete electrical failure after having parked the car, I would think we would all need this "Dolly" procedure since there is no way to unlock the rear parking brakes...no matter if you have the transmission tool or not.
I forgot to ask about putting the car in Neutral which was my original question on the thread. It would seem however from other respondants that there is no way to do this without strating the car. Oh well.
      12-14-2010, 04:13 PM   #27
raleedy
Drives: 2016 228i 6-speed
So the fitting in front would be for towing other cars in reverse?
      12-14-2010, 04:30 PM   #28
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Or for pulling someone out of trouble in a situation where you're head onto them and don't have sufficient room in which to turn your car around .
      12-14-2010, 05:18 PM   #29
Jon D
Jon D's Avatar
Scotland
224
Drives: 2022 840d
Or for being towed if you have a manual gearbox .
      12-15-2010, 06:22 AM   #30
LuvMyE92
Occasionally frequent poster
LuvMyE92's Avatar
3000
Drives: CT5V-Blackwing
I do believe that a) BMW would tell you not to do this and b) you will cause some damage to your car and c) it is not designed for this.
The tow hook is for situations like when you're stuck on the side of the road in some mud or maybe snow... you've got little to no traction and you just need some help. I really, really don't think you should be towing anything heavier than a sled filled with laughing children. And you shouldn't do that anyway, as that is very dangerous. I was just trying to make a point. Tow nothing!
Current inventory:
F22 & G05
Cadillac CT5-V Blackwing w/3 pedals
Past: E24,E28(3),E34,E36,E37,E38(2),E39(4),E46,E89,E92 (obviously),F01,F06,F10,F30,F87,G12,G30(2),G82(2)
      12-15-2010, 09:39 AM   #31
grimlock
Or maybe BMWs like to get together when we're asleep and play tug-o'-war..
