BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
      09-19-2012, 08:29 PM   #89
VMcV3y
VMcV3y's Avatar
153
Drives: 2022 X3MC; 2012 M3 Cabriolet
Originally Posted by mhaghighi View Post
i have a 2011 M3 and 2013 x5 and on both idrives i cant see the email or text since upgrading to ios6. i have followed all above suggestions except doing anything to the software of the car. how long does it take from the time message appears on the iphone before you can see it on the idrive?
It's almost simultaneous.
I went over the instructions a couple of times to make sure that I had it properly configured...Besides the BMW-side AND the iPhone side configurations, the clincher of the process was making sure that the iPhone was in locked-screen mode.
2022 ///X3M Competition; São Paulo Yellow
2012 ///M3 Cabriolet; Le Mans Blue Metallic. >177k miles and still rocks!
      09-19-2012, 10:17 PM   #90
khaye1
khaye1's Avatar
Philippines
145
Drives: 18 AW F80
Just downloaded the bin file and my idrive states that I do not have any software on it...used 2 different USB sticks, tried it with the main folder and without but no bueno...what gives?
      09-19-2012, 11:00 PM   #91
Chowster
E60_to_E90
Chowster's Avatar
Drives: 2011 E90 M3
Originally Posted by dbhajek View Post
Thanks, the instructions you posted worked for me.
The "no incoming chime/sound on either the iPhone nor the car's system" has bugged me. I am hopping someone fixes this.
Thanks Again
I've also managed to get texts working. The instructions posted in post #82 above are good:
Under Settings, Bluetooth in your iPhone, go to the devices connected where it shows your BMW has paired, open that and turn on "Show Notifications".
Then under Settings in your iPhone go to "Notications" then under each heading "Phone" "Messages" "Mail" make sure you have the following turned on:
Notification Centre ON
Alert Style Alerts - I use banner, and works fine
Badge App Icon ON
Show Preview ON
View in Locked Screen ON
As for the "no sound on the phone or car with incoming messages", I too had this issue nagging me for a while. If we are talking about the same thing, here's how I solved it. In the iDrive bluetooth menu (can be accessed a couple different ways), you have the option to select bluetooth for __ telephone __ audio __ office. Just make sure that Audio is deselected. Try that out. I don't stream music from my phone via Bluetooth, so doesn't complicate things for me.
2011.5 E90 Dinan M3, SS II, M-DCT, EDC, M Drive. 20" MORR VS8.2 wheels
Performance Mods: Dinan St.1 suspension, exhaust, intake; TTPs; BPM St.II, DCT, servo tunes
Cosmetic Mods: OEM CF splitters, mirrors, center console, spoiler; Arkym CF diffuser; LUX; tint
      09-19-2012, 11:05 PM   #92
Chowster
E60_to_E90
Chowster's Avatar
Drives: 2011 E90 M3
I was having a minor issue where the phone was busy syncing contact data when the car was first turned on, that incoming texts were not being updated to iDrive. Once the contacts were finished syncing, it worked well for incoming texts.
      09-20-2012, 12:18 AM   #93
khaye1
khaye1's Avatar
Philippines
145
Drives: 18 AW F80
okay I finally got the BMW update to take...I used my windows computer to transfer the file, I was using the Mac Pro before. However, at first I received all the most recent texts that were already read then I tested it with new text and nothing(phone is on lock screen)...didn't even get a notice on the phone neither but when I opened the messages on the iPhone all the messages that I sent from my other phones were in there. I didn't get notification or the red number on the top right of the message icon.
      09-20-2012, 06:21 AM   #94
aussiem3
aussiem3's Avatar
Australia
274
Drives: Goggomobil
After making all of the above changes as noted in the posts, unpair and pair the phone then it will all work seemlessly. I was struggling initially but once I had done this it was fine.
This is what I did with my wife's F25 X3. I am yet to try this with the '07 M3 with CIC transplant
      09-20-2012, 02:32 PM   #95
mhaghighi
Drives: 2017 M3 Competition package
so the bmw software has to be done no matter what???
i don't underestand my is not doing anything. but i tried to update with memory stick and is not recognizing the stick in the glove compartment. i have 2013 x5 and still nothing. should i unpair and pair up again?
      09-20-2012, 02:35 PM   #96
Chowster
E60_to_E90
Chowster's Avatar
Drives: 2011 E90 M3
I didn't do anything with my iDrive software. I have a 2011.5. Just configured iDrive and the iPhone. Keep trying! Starting over with unpairing and deleting the Bluetooth connection on the phone never hurts.
      09-20-2012, 03:03 PM   #97
mhaghighi
is annoying. i am trying my 2013 x5. that has under office messages. and my 2011 m3 that has current office. both i have everything on like it should put not working. i have the bluetooth options which are a little different on both idrives checked.
      09-20-2012, 03:19 PM   #98
VMcV3y
VMcV3y's Avatar
153
I'm far from an expert on this, but I think it's highly likely that your model-year 2013 will NOT need to update your iDrive's software.
Inside iDrive you can find the software version you currently have, and if it's something like MX-3.5.4 and TX-3.5.4, then you probably have the latest version.
Instead, I'm supposing your problems are not on the on-board software version, but rather configuration...or usage. I see your follow-on post. When you write it is "not working" what's the situation?
For instance:
a) phone shows bluetooth is operational (icon)
b) phone SLEEP button is activated OR it is in time-out lock mode
c) you have received a SMS text message (not an e-mail) WHILE the phone is sleeping/locked.
All of those conditions above must be active in order for it to work.
      09-20-2012, 05:59 PM   #99
mhaghighi
bluetooth is fine. but no messages of any kind. i send email and text with another phone to myself but nothing. it has to be my iphone sitting. phone is set for auto lock in 1 minute. what else? all notification are on and view in lock screen on.
      09-20-2012, 06:10 PM   #100
mhaghighi
wow in bluetooth i didnt have show notification on!!!
      09-20-2012, 06:48 PM   #101
mhaghighi
text works now in both cars but no emails..
i see the email filter and all the icons for email count but no email comes even with the email checked off. is there a problems with emails still? thank you
      09-20-2012, 07:46 PM   #102
Justin(OKC)
Justin(OKC)'s Avatar
Drives: 1988 M3, 1990 M3, 1998 M3/4
1998 BMW M3/4  [10.00]
2011 BMW M3 Sedan  [9.28]
1988 BMW M3  [9.40]
1990 BMW M3  [10.00]
2008 BMW 135i - sold  [0.00]
2003 BMW M3 - sold  [0.00]
I am so happy to have found this thread!!! Thanks for all who have contributed.
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black
1998 BMW M3 - Alpine White/Mulberry
2011 BMW 328i racecar - LeMans Blue/Black
      09-20-2012, 09:33 PM   #103
VMcV3y
VMcV3y's Avatar
153
Question
Text is all that was working yesterday, and you've hit the "tah-dah!" success bell!
And then...driving around today, I noticed that I had...an e-mail show up in iDrive. Yes, it was a genuine e-mail, not a text message. I did the voice-play back thing, and it worked.
But I didn't get the audible "ding" of an incoming e-mail, and then I went back (as someone suggested) and un-checked "Audio" from the iDrive bluetooth configuration. Then an hour later, I got another e-mail, but it did NOT appear on iDrive. Uh...oh. So...maybe that wrecked it, or perhaps getting e-mail in the first place was a slip-up in the system. Don't know, but having put all of the configuration back to where it was this morning, I am again NOT receiving e-mails. Strange....
(I've never used so many emoticons before on the same posting, LOL.)
      09-20-2012, 09:44 PM   #104
tlp
Drives: 991 GT3, Sold:'11 e92 M3 SG/FR
Even a blind squirrel finds a nut now & then.
I wouldn't worry about email in this release. Email was rock solid in Beta 3. Beta 4 and the GM have issues with email that will hopefully be addressed in the next update from Apple.
991 GT3, Sold: '11 e92 M3 SG/FR ZCP|ZCV|ZP2|2MK|494|415|6NR|752
      09-20-2012, 09:46 PM   #105
VMcV3y
VMcV3y's Avatar
153
ROFLMAO. True, so true!
      09-20-2012, 09:52 PM   #106
khaye1
khaye1's Avatar
Philippines
145
Drives: 18 AW F80
Finally got texts on the way home today...with audible sounds and all. I don't know what changed from last night to today but yippee!
      09-20-2012, 10:22 PM   #107
Shaan
Drives: '11 M3 / '14 Tundra
still not working with mine.... guess i dont have BMW office ?? it shoes messages under the phone option
      09-21-2012, 09:15 AM   #108
M3 DCT
M3 DCT's Avatar
South Africa
11
Drives: Space Grey M3
2012 x5 40d M Sport  [0.00]
2012 BMW M3  [10.00]
Question Email Issues
I logged a call with BMW about the email issue not showing up in iDrive.
I just got the following reply - they know about the issue and they are going to issue a new firmware to solve the problem.
We have now escalated the matter to Germany AG and Apple. BMW Technical could only get the BlackBerry device to sync with the idrive system and not iOS6. As per BMW Technical, a firmware needs to be developed for your vehicle to recognise MAP (MAP ACCESS PROFILE) to synchronise emails on your idrive system.
This case is currently logged on our system, I will report back to you next week on progress.
Thanks
Regards
BMW (South Africa) (Pty) Ltd
      09-21-2012, 09:17 AM   #109
astacun
Drives: 2011 MW E92 ZCP
Great thread! Thanks for all the useful information. I was able to get this to work this morning.
One thing I noticed that may help others. After updating, restarting, repairing and setting all the options I couldn't get text messages to show up in the filter or in idrive when the phone received one. When I went into the office from the main menu it went straight into messages, showing the email filter with all of the google poi that I had sent myself. If I tried changing the filter, the text messages option would not show up. I then pushed left on the idrive control knob to get to the office main, scrolled up and selected current office. This opened the screen that shows the total unread messages, as seen on picture #1 of the OP. Then, I selected that and voila, the list of available messages refreshed and I can now see the text messages option on the screen and the text messages show up in idrive when the phone receives them.
So if anyone is having some issues, try to back out of office and refresh it as I described above. Hope this helps!
Ed
      09-21-2012, 09:19 AM   #110
VMcV3y
VMcV3y's Avatar
153
<snipped>
Great. Thanks. I'm keen to find out if they really do get back to you in a week with an update. It would show us how fast BMW's software teams can respond. I recall watching a video awhile back of a BMW mobile phone developer group in California talking about how they are progressing through many iPhone and Android apps...let's see how quick they are!
m3post
