06-30-2011, 02:45 PM | #1 |
Rep 10
Sport Mode
I disabled drivetrain sport activation when toggling between "normal" / "Sport" and "Sport+" settings on console.
Is drivetrain activation on console button the same as when I throw shifter into "sport" mode? |
06-30-2011, 10:12 PM | #3 |
Rep 2,340
Drives: 650GC/E93M3/Lexus LS600HL
Actually, no. This has been talked about before. There are very subtle differences.....
Refer to this thread. In short, moving the shift lever to S mode: 1) Holds a gear longer, so you are ride the torque curve longer before shift. 2) Gives you synthetic manual shift. The car will not automatically shift up/down until you move shift lever back to D. Switching the car to Sport mode with drivetrain enhancement (without putting shift lever in S): 1) Holds a gear longer, you ride the torque curve longer before shift. (sames as lever->S) 2) On Sport Automatic equipped F10, also further reduce gear change time (this is from a BMW technician working on my car). F10 with SAT already shift faster than non-SAT equipped F10s, but putting the car in sport mode further shorten the time required to change gear. 3) Pseudo manual like in normal. You can downshift/upshift and the car will adjust gear after a while depending on the driving style. 4) Accelerated throttle response in sport mode. (does not happen when shift lever in S but car in normal). Again this is on a SAT equipped F10. And those are just the drivetrain differences. I am ignoring steering/suspension differences as the OP was asking about drivetrain only.
F06 650i Gran Coupe Ruby Black/Dakota Cinamon- 2012-10-12 Adaptive Drive/IAS/Surround View/Adaptive LED/Comfort Seats/BMW 356 Liquid Black/Michelin PSS 245/35R20-285/30R20
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT 2011 F10 550i M Sport - Retired Last edited by mlai; 06-30-2011 at 10:28 PM.. |
07-01-2011, 02:35 AM | #5 |
Rep 2,340
It does. Putting gear lever in S holds the gear that you manually put the car into.
E93 M3 Cabriolet Satin Pearl White/CR - 2012/03/12 Bilstein PSS10/ Michelin PSS 245/35R19-265/35R19 Brembo GT 2011 F10 550i M Sport - Retired |
07-01-2011, 02:58 AM | #6 |
Rep 3,016
My personal preference is to have sport mode configured to chassis only; that way I get sharper steering response and reduced body roll whilst retaining eighth gear. When I want a bit more I select sport+ and this, to me, gives a natural progression, all done on the toggle switch. I hardly ever select manual/sport mode with the shift lever and very rarely use the paddles.
07-01-2011, 03:05 AM | #7 | |
Rep 827
07-01-2011, 11:13 AM | #10 | ||
Rep 6,694
Several incorrect / partially correct statements in your post.
#2, this also happens in S mode from the lever, not only in "Sport" powertrain mode. Also, it happens regardless of SAT vs. normal transmission. #4, this is incorrect, the advanced throttle DOES happen with lever in S mode, regardless of drive select position. And this also does happen regardless of which automatic. |
07-01-2011, 11:18 AM | #11 | |
Rep 6,694
I think the "more" that the poster was referring to is that regarless of how you have "sport" mode set up (drivetrain / chassis vs. one or the other), sport plus will engage the drivetrain "sport" settings. As those posters said, by not having your "Sport" settings set to the combined setting, you can have firmer ride with more relaxed throttle and shifting in sport, or both in sport+. If you have sport configured as the "combo", the only benefit to sport plus is the reduced DSC. |
07-02-2011, 02:52 AM | #12 | |||
Rep 2,340
To confirm that this is indeed the case, I had a blind test (ok, maybe not physically blind) by one of my friend who has not driven my F10 before, doing the same: merging into uphill traffic at speed from standtill. And he can tell the difference between S and sport. That's a good enough proof for me that there is a difference. My BMW tech told me that S mode primarily moves the shift points higher up, but for throttle responsiveness, gotta put the F10 in sport/sport+ mode. Maybe they did something special to my car to appease me, or rather to make me stop badgering them for the difference between sport and S
07-02-2011, 01:31 PM | #13 |
Rep 144
Drives: 2011 535xi, Graphite Grey
I hardly ever use the sport mode. The car is fast enough as it is in normal. If I get pissed off & have to drive aggressively THEN, (BAM) I put the F10 into sport mode & handle my business ( which doesn't take very long ...........LOL). On occasion I do use the shift paddles when I remember. As you all know, it does not take long to reach 100 MPH........where the heck am I going. . Arrive safely everyone...
07-02-2011, 02:20 PM | #14 | |
Rep 205
07-02-2011, 05:33 PM | #15 | |
Rep 6,694
07-02-2011, 08:58 PM | #16 |
Rep 2,340
Mine has SAT. Must be, as I have mentioned in my original post, #2+#4 are on cars with SAT
