2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions Rear M diffuser removal
      06-01-2012, 10:24 AM   #1
sbrown35
Chief
sbrown35's Avatar
Drives: 2012 535i M Sport Alpine White
Anyone have instructions with pictures perhaps of how to remove the rear M diffuser? Thanks
Sean
2012 535i M sport Pkg - HUD - Alpine White w/ Beige
      06-02-2012, 11:11 AM   #2
PeterC4
Drives: 2021 BMW M550
Removal of M Diffuser
Not difficult and no need to remove the bumper.
1) There are 5 plastic plugs on the bottom of the diffuser that can be removed with a trim remover or small and thin pry bar. There are two parts to the plug, the stem and the receptacle. Both come out.
2) This takes a little patience and bravery. Start at the bottom corner near the tailpipe. Push inward with your thumb towards the part where the diffuser meets the bumper and pull away with your other hand. There are tabs that snap into and out of place. With a little force you will pull if free at the corner. Once you have it free the rest will be self evident, but you can pull it away from the bumper fairly easily.
3) Reinstallation will require you line up the tabs first and then push them forcefully into place for proper alignment. You might have to do this a few times to get it fully flush. You can bang the diffuser from the bottom with the palm of your hand.
4) Reinstall the plugs at the bottom of the bumper.
I will try and post some pics.
      06-02-2012, 11:35 AM   #3
PeterC4
Here are the plugs that are removed from the bottom of the diffuser. I used the tool (gently) in the picture. There are 5 in total.
This is the bottom of the diffuser where the plugs go.
The side tabs are pictured below. Pull the diffuser away from the bumper at the tailpipe and work your way up. You need to push with your thumb where the tab meets the bumper and pull away with your other hand in the opening for the tailpipe.
The top tabs. When reinstalling, forcefully push from the outside where these are with your thumb or palm to align to the bumper.
2012 BMW 535xi MSport Carbon Black
      06-04-2012, 08:31 AM   #4
sbrown35
Chief
sbrown35's Avatar
Thanks and the pictures were extremely helpful... Thanks again!
Sean
      06-20-2014, 03:06 PM   #5
eplace
eplace's Avatar
Drives: F10 550i
You are awesome Peter! Thnks for the writeup!
      07-02-2014, 12:02 PM   #6
M535
PinOyBIMER
M535's Avatar
Pitcairn Islands
21
Drives: 535
great write up Peter. we appreciate you.
      04-21-2015, 06:20 PM   #7
EmArAsOnS
EmArAsOnS's Avatar
Sweden
13
Drives: LCI F11 MSport Xdrive (I.Blue)
Really appreciate the writeup PeterC4
      06-19-2016, 02:34 AM   #8
Ross620
Ross620's Avatar
22
Drives: 335i
thank you peterc4 ;D
16 f10 535xi m sport - on its way
07 e90 335i - retired
      06-21-2016, 07:10 PM   #9
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
