2010 2011 BMW 5 Series Forum F10 lsturbointeg's "Black Candy" build thread! (with daily/weekly updates!) |
07-16-2020, 08:23 PM | #463 |
Rep 14,521
i was just going through pictures of mine and what a difference from than to now.
ezaircon4jc4535.50 jayster0966209.00 |
07-17-2020, 09:53 PM | #464 |
Rep 277
lsturbointeg9163.00 |
07-20-2020, 07:33 PM | #465 | |
Field Marshal 🔱
144
Rep 294
Drives: 2019 M5 Competition (F90)
2019 F90 M5 Competition - Black Sapphire Metallic
2015 F10 535i xDrive M-Sport - Jet Black (retired) 2008 E60 528i - Space Grey (retired) 2002 E46 325i - Space Grey (retired) 1999 E46 328i - Orient Blue (retired) |
lsturbointeg9163.00 eman45171745.50 |
07-20-2020, 08:31 PM | #466 | |
Rep 14,521
jayster0966209.00 Alcenos144.00 |
07-22-2020, 10:50 PM | #467 |
Rep 14,521
wheels back on fam!
07-23-2020, 11:06 PM | #468 |
Rep 14,521
check it out fam! RaceDeck tiles showed up today! just a few samples i took out of the box. but black, royal blue, graphite and alloy
ezaircon4jc4535.50 |
07-23-2020, 11:07 PM | #469 |
Rep 14,521
07-24-2020, 06:12 AM | #470 |
Rep 19
Drives: 14 F10 N55 (M) 17 F15 N55 (M)
Are the tiles solid or more vented? They look like if water got on them it would go right through to the concrete under. This would become an issue in snowy areas like where I am. Looks incredible though!
07-24-2020, 09:52 AM | #471 |
Rep 14,521
These are the Free Flow design which allows water(snow when it melts) to go through the channels. because the garage floor has a slight grade the water will run out to the driveway. Very common garage tiles alot of enthusiasts go with between this and Swisstraxx
tkatz221464.00 |
07-25-2020, 11:04 PM | #472 |
Rep 14,521
cdmulders330.50 jayster0966209.00 |
07-25-2020, 11:05 PM | #473 |
Rep 14,521
07-25-2020, 11:06 PM | #474 |
Rep 14,521
07-25-2020, 11:40 PM | #475 |
Rep 5,389
Some might say you're a picture whore...
Or you're rubbing-in what a fantastic garage you have!!! |
07-26-2020, 12:28 AM | #476 | |
Rep 14,521
garage is turning out pretty good. just need to start ordering some wall decor art and stuff now got 5 more LED garage lights i need to install above
07-29-2020, 06:30 AM | #477 | |
Field Marshal 🔱
144
Rep 294
07-31-2020, 10:46 PM | #478 |
Rep 418
08-01-2020, 08:19 AM | #479 |
Rep 14,521
lol it's been a dream of mine from my previous house back in Cali. it's actually nice to work in a garage that looks like this. gets you even more motivated to work on the car. wife is a bit annoyed that i'm in the garage even more i'm trying to get her okay to buy a tv so i can put it on the wall to listen to the football games while i'm working on the car
08-01-2020, 09:00 AM | #480 | |
Rep 418
08-01-2020, 10:59 AM | #481 |
Rep 14,521
last couple of days were pretty busy. started full 3 step paint correction and will finally get the Adam's ceramic coating done!
time to break out the detailing car! CG's Maxi Suds along with CleanSlate to remove all the old sealants and waxes if you're not using the 2 bucket method technique you should btw these 5 gallon dollies are freakin awesome rather than carring the buckets around when it comes to wheels i never used a dedicated wheel cleaner until now. i usually just use the the Maxi Suds to clean the wheels. but i'm gonna start off with CG's wheel cleaner and if i like it maybe try something else afterwards. but for the most part i'm actually impressed with how wheel cleaners make cleaning much easier clay bar time! i've tried them all so with experience i don't think it matters which brand is better as they all do the same function...remove contaminants now with the car up in the air i did a last minute thing. 3 years ago i painted the barrels on my AG's black this time i did them with a flake bronze. this is the same paint i used on the strut bar and cross bars also before i started the paint correction i wanted to finally get the GFORCE IC installed! tho it looked nice as wall decor it was time for it to find it's new home! now after reading the forums on the install and watching countless Youtube videos this was not complicated at all as some have stated. install was very easy and straight forward. this thing fit like a glove. not a whole lot of wiggle room if i may say. i did use my jack to help lift the IC into place which made things a lot easier. what a big difference in size and nestled into her home BTW the plastic covers doesn't fit back into place from what other's have said okay onto the paint correction. here's my weapon of choice...TORQ15DA! for products used CG's VLINE along with CG's Hexlogic pads orange and white my previous DA polisher was Harbor Freight which did the job but burned through pads after 12 hours which in the detailing world is nothing i got the paint correction done. usually a full correction takes anywhere from 24hrs+ easily. thoughts on the TORQ15DA...works great! doesn't generate heat like my HF. ergonomically feels good in my hand. noise is very low and it's got a nice digital display. so i'm drained! taking a day off but probably Monday i'll start applying Adam's Ceramic Coating
08-01-2020, 03:25 PM | #482 |
Rep 205
Dude. I need your level of energy! Great work! I just ordered the Adams ceramic coating with graphene so I'll be in your shoes here soon
08-01-2020, 08:56 PM | #483 |
Rep 14,521
Haha thanks my dude! Gotta love life right always try to keep myself busy. Let me know how you like the ceramic coating
08-05-2020, 12:09 PM | #484 |
Rep 14,521
time for the final coat...Ceramic Boost!
