2010 2011 BMW 5 Series Forum F10 High mileage n55 rod bearings and failure |
11-26-2023, 12:37 PM | #1 |
Rep 22
Hello everybody, I recently acquired a 2011 f10 535. The car has 191k miles and i don't believe the rod bearings have been changed. I plan to replace them in the next couple thousand miles. The car in nearly perfect and has been meticulously maintained by the previous owner and not drove hard. Should I be scared to death like I am currently? Are the failures as common as people say? And before you say there are lots of forum posts on this, i am asking about the mileage aspect of this. I'm just scared that I have a inevitable failure about to happen
11-26-2023, 08:28 PM | #2 |
Rep 3,000
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
Get an engine oil analysis from Blackstone... they'll tell you if there is high brass or whatever in the sample. If everything comes back good, you can be relieved! Or if they're high, jump into action!
11-26-2023, 09:51 PM | #3 |
Rep 22
Thank you very much for the response, this is helpful. I'll go ahead and make this my game plan!
11-26-2023, 10:44 PM | #4 |
Rep 3,000
Their analysis is VERY detailed, so they'll let you know if anything looks bad based on the results. Plus good to get that done on any new to you car just to establish a base line. Hopefully no issues!!!
LoganN5518.00 |
11-27-2023, 07:10 AM | #5 |
Rep 1,873
Just a note of caution, N55 rod bearings are G-444 and G-488 lead free materials. I do believe I have read that there is still copper in their construction, so if Blackstone can detect the copper appropriate in their process you may still get indications of bearing wear. Blackstone's commentary may or may not be based on specific knowledge of the materials used in our engines. (they might be looking for lead, for instance, which is more traditional)
11-27-2023, 08:22 AM | #6 | |
Rep 233
Drives: 2015 BMW 535i M Sport
FWIW, Here's a sample of their report (sorry the last column to right got chopped off on the scan) but it gives you an idea of what you'll receive. Don't forget they'll do OA on transmission oil & differentials too! +1 to Blackstone Laboratories. The best $35 ($40 now?) I spend on my Bimmer! |
StradaRedlands4943.00 LoganN5518.00 |
12-04-2023, 10:50 PM | #7 |
Rep 22
Well folks, unfortunately a day before the oil analysis came in the mail, another n55 needs rod bearings. I did a 50-110 pull after letting the car warm up perfectly, on a straight road. Got home, and the car idled great but started knocking lightly over 3k rpms. Glad it didn't spin a bearing, but they still have to be done. When completely cold, the motor doesn't knock at all but to be safe I trailed it to the shop I'm currently working on it in. Drained the oil and saw some brass colored metal shavings. Bearing material of course. Haven't got any farther yet. I will post my bearing condition tomorrow or the day after when I get them removed and inspected. Now the real question is why did it do this? I know that I was beating on it, and it's a high milage motor, but it has never been raced, tracked and it has been very well maintained. I waited till it was completely warmed up and on a flat road with no turns. Why would the oil pressure drop in a situation like that? It is best case scenario.
StradaRedlands4943.00 |
12-05-2023, 08:49 AM | #8 |
Rep 21
Sorry for your possible misfortune Logan. I too also recently acquired a 2011 535i, but milage is lower (120,000). Please keep us posted with what you find.
Can you let us know the build date of your car? It will be listed on the VIN plate on the drivers side door frame. I ask this due to finding this post while reading through the forum: https://f10.5post.com/forums/showthr...35i+temp+gauge I have absolutely no idea if the build dates listed in Post #16 have any merit, but my car has a 06/10 build date. So far (barely a month of ownership, but around 2,200+ miles) I am hearing nothing at cold start idle or warmed up revs while driving. Good luck with getting it back on the road quickly and at NOT a huge cost!!!
2011 BMW 535i, 6spd, Milano Beige Metallic, Venetian Beige Leather, Convenience Package, Premium Package 1, Premium Package 2, and Sport Package. 119,500+ miles.
LoganN5518.00 |
12-05-2023, 07:55 PM | #9 |
Rep 22
Well here is the news, and to say the least, it isn't great... these are by far the worst bearings I have seen. Cylinder number 6 spun, cooked the rod and marred up the crank. It was the only one that failed(seems like a very common thing on these). I am a week into ownership of this car. But I do have a plan, because I have nothing more to lose other than time and a few hundred bucks in the name of science. I am going to polish the crank, clean up the rod, throw the new bearing in(plasti gauge it of course), locktite the back of the bearing(not to hold it in place, but rather to take up imperfections from where the bearing spun).
Some will find this as a interesting approach, as most would throw a crank in it or have it turned. But why not have a little fun and test to see if it holds another 100k? If it does, great, and if it doesn't, oh well, it's a high mileage motor and it could use a rebuild anyway. If the repair does fail, then I will document it here and possibly with a new post since this will probably be lost in time. If I don't post about it, assume the best. Wish me luck, and if anyone has any tips, let me know! |
StradaRedlands4943.00 cdmulders326.50 |
12-05-2023, 09:20 PM | #11 |
Rep 22
It was owned by a man before me that had it changed at a dealer every 6k. I think that's a little high but some think it's just right. It had 1k on the last change when this happened. Not sure what oil was used since I have only had the car for a week but I believe that he used Castrol 5-30 full synthetic.
ezaircon4jc4483.50 |
12-17-2023, 07:14 AM | #12 |
Rep 21
Any updates Logan? Those bearings and journals are absolute toast. I applaud your idea for moving forward (Polish and re-bearing) so am interested in the outcome.
The overall engine condition doesn't look horrible for a high milage vehicle (discoloration and carbon/varnish build up) but to my eyes it appears that more than a few oil change intervals were well beyond 6K. If paperwork suggests otherwise, then I stand corrected. Bought one of my kids a 2003 Chevy Tracker as a first car. It had a 2.5L V6 Suzuki engine with 76K when I bought it, and around 225K when I sold it. Oil changes were woefully inconsistent and probably 75+% were non synthetic oil changes. Looking into the oil fill hole, the internals were about the same color (brownish varnish color). Good luck with your fix and hope it turns out well for you!!
12-17-2023, 07:54 AM | #13 | |
Rep 22
12-17-2023, 09:28 PM | #14 |
Rep 3,000
This is great, LoganN55!!!!
12-24-2023, 11:32 AM | #16 |
Rep 22
12-29-2023, 08:58 PM | #17 |
Rep 22
Well, with the new year approaching, I have a new post to share. And it involves another set of spun rod bearings. Oil pressure and level were good. Normal driving circumstances, oil temp was right below 250 before I started going above 2k rpms. Lovely. Time to drop 3k into this motor to fix it. Does anyone have any tips on what to do to increase the reliability(that isn't the s55 oil pan. Nobody can afford that)
