2010 2011 BMW 5 Series Forum F10 Gargling/sloshing sound coming from behind climate control |
12-14-2023, 02:58 PM | #1 |
Rep 114
Hello all--
I noticed this morning that there is a gargling/sloshing sound coming from behind the climate control. I noticed it when I had turned the thermostat all the way up to 84 degrees and had the fan on the lowest speed. I've been researching this for the last hour and it sounds like this is a common issue amongst several BMW models/years. Most of my search has led me to believe that there is water trapped in the heater core. I found this youtube video to try and "burb" the air out and wasn't sure if it was a good idea or not: I should also note that all AC components work just fine and, as of now, I only notice this percolating-like noise when the thermostat is turned all the way up to 84 degrees. I ran my AC at 83 degrees and didn't notice it as much; dropped it down to 78 degrees and there was no noise. TIA!
2016 BMW 550i M Sport - Mineral Gray Metallic
2015 BMW X5 base - Jet Black 2011 BMW 335i - Alpine White |
12-14-2023, 04:50 PM | #2 |
Rep 127
I don't think bleeding coolant system at any time and not just when coolant change occurs will have adverse effect to the system. just make sure you follow the bleeding procedure.
12-15-2023, 04:39 PM | #3 |
Rep 92
Could be one or more of the heater control valves getting stuck, replacing the heater control valve eliminated any slushing sound I used to get. The rubber diapharms in the valves deteriorate and cause the valves to not shut or open properly causing poor flow of coolant into the heater core and coolant then slushing around in the heater cores. Even with the climate control turned off I could still hear slushing. I replaced the simple part and problem was fixed.
Conserve186.00 StradaRedlands4943.00 |
12-15-2023, 05:59 PM | #4 |
Rep 127
^ +1. every time I come here learn something new.
https://f10.5post.com/forums/showthread.php?t=1861362 |
12-24-2023, 02:23 PM | #5 |
Rep 94
It's usually a symptom of low refrigerant condition. You can check the pressure level and/or refrigerant amount by visiting A/C shop
I found mine leaked refrigerant and oil on both low and high pressure pipes which located near the radiator. The coupler from/to pipe/rubber on both lines were failing and leaking some oil through that. You can easily tell by oily and black residue around the coupler. Try to clean it with degreaser first and rub your fingers around the coupler after driving with A/C on for minutes. See if you have oil around that (caution: high pressure pipe is super hot! Let it cool after driving) I replaced mine with non standard solution offered by Denso authorized workshop and super happy with that |
StradaRedlands4943.00 SummerallGuard0483.50 |
