2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Anyone with H&R or after market sway bars noticed squeaking noise?
      11-16-2017, 06:01 PM   #1
Klecha man
Klecha man's Avatar
Drives: 2012 535
I just got Eibach sway bars (front and back) and after two days of driving it started making noise. The shop confirmed the sound is coming from the sway bars.
I reviewed the H&R sway bars and bushing and they claim they have a special bushing that prevents them from making any squeaking noise.
Is it work taking out and buying H&R instead of Eibach. I'm not liking the noise i did not have with the factory bars.
      11-18-2017, 12:59 PM   #2
initialM
initialM's Avatar
Drives: F10 535i M-sport
I have H&R rear sway with their no-squeak bushings on my F10. The first couple drives made a little noise and I'm guessing they were still settling in, but so far I do not notice any more noise and I've had it for about a couple months.
      11-18-2017, 04:43 PM   #3
paul223
paul223's Avatar
Drives: F10
Make sure the sway bars are centered correctly and all bolts are torqued properly. If the noise comes from bushings, apply lubricant which will not damage bushings from chemical reaction.
      11-20-2017, 01:01 PM   #4
Klecha man
Klecha man's Avatar
Drives: 2012 535
The shop double checked and it was lubed. I found a few more threads complaining about squeaking Eibach bars. I did also call their tech support and their rep said it's possible and they don't have a fix for it. That's just the way it is and I did not like that answer.
      11-21-2017, 07:03 PM   #5
Jayphil
Jayphil's Avatar
63
Drives: 535I xdrive 2011 (M-SPORT)
I have H&R swaybars and I do not have any sound. I hope you find a fix.
BMW 535I xdrive 2011 M-Sport with H&R Springs, Niche Form Wheels 8.5 ET35 / 10.5 ET35, Continental DSW06 245/35 & 285/30, JB4 Map 5, ER Downpipe, Megan Racing Quad Exhaust with Vibrant resonators, M5 Diffuser, Orange reflector shaved and removed xdrive badge.
      11-22-2017, 11:20 AM   #6
Klecha man
Klecha man's Avatar
Drives: 2012 535
did you end up using any type of lube on the bushing before installing them? or you installed as-is?
I'm thinking maybe the lube the shop used on the outside of the bushing might be causing the noise. I think they probably should have only used lube on the inside of the bushing (the part that wraps around the sway bar) only.
      11-22-2017, 07:34 PM   #7
Jayphil
Jayphil's Avatar
63
Sorry got it installed by a shop so I do not know if they did put anything on.
      12-05-2017, 07:58 PM   #8
BuiltnBoostedZ
Drives: 2012 535ix
I'd check the bushings on the sway bar and the sway bar end links (other end of the end links). If its not binding up, then just lube and drive for a week.
2012 F10 535ix - JB4 - BM3 - Meisterschaft GTC - coded modules - CF front lip - CF rear diffuser - clear bra
      03-14-2020, 04:11 PM   #9
GrabacrOne
GrabacrOne's Avatar
178
Drives: F10 535i
I have H&R sway bars and installed them as is. The H&R bushings are urethane/Teflon composite so they say no lubrication is necessary. But I'm getting a squeak when going up driveways or hitting bumps at slow speed.
I'm fairly certain it is the sway bar because I sprayed some PTFE lubricant spray on the bushings and the noise was gone for a few days but came back. I don't want to have to take the sway bars apart again. Would lithium grease work with these?
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #578262 as a referral.
F10 535i M-Sport | Gone but not forgotten: G01 X3 xDrive30i M-Sport; F15 X5 xDrive35i; E70 X5 4.8i
      03-15-2020, 08:16 AM   #10
BimmerHausPerformance
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
I have H&R sways and no lube, no squeaking.
      03-15-2020, 12:12 PM   #11
Luky
Luky's Avatar
Drives: 2016 550i M Sport
Get some silicone grease, pop off the mounts/bushings, lube them up and put back.
https://www.amazon.com/Super-Lube-92.../dp/B0081JE0OO
Had similar issue with my H&R on my G37S. I had lubed them, but not enough. Even had grease zerts and pumped more in till squirted out the sides, but did not solve the issue. After manually redoing them no more squeaks.
      03-16-2020, 03:26 PM   #12
ramman434
Drives: F30 335i
Bumping 3 year old threads sure seems like fun...
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21
'13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake
      03-16-2020, 03:30 PM   #13
513
At least he did his research, right? Otherwise he might get flamed for posting repetitive questions
      03-17-2020, 06:16 PM   #14
DR-JEKL
Australia
898
Drives: Space Grey E92 335i 6MT
Hey guys are there notieceable improvements with the H&R or eibach sways over standard msport?
I have a well sorted E9X chassis with all the fruit for my weekend car and whilst I want a comfortable daily driver F10, I'd like to improve the handling and replace 100k kay shocks with some ST X coilovers figured might as well chuck in some stiffer sways if they're worthwhile
      03-17-2020, 06:22 PM   #15
513
If you like the feel of a sportier set up then yes, I would do them. If you are old and don't want to "ruin ride quality" then no, don't. IMO it is easy nicer over stock.
