2010 2011 BMW 5 Series Forum F10 Resonators deleted, and I'm pleased to report... |
07-07-2015, 06:35 PM | #1 |
Rep 844
That it did absolutely nothing. Not a grumble, not a gurgle, nothing. It did save about 15 lbs from the resonators, but its just as depressingly quiet as before I may order a pair of magna flows next week, but it was miserable being under that car today while building that so my interest in doing ANYTHING until november when it cools off is zero! I haven't picked up a mig welder in probably 2 years now, and all I had to work with was a sawzall, welder and a marker since my buddies shop isn't setup for exhaust work.
2014 M5 Competition with ESS Tuning Flash
Gone but never forgotten...2015 X5 50i M Sport, 2015 550i M-Sport, 2015 M3, 2014 X5 50i M Sport, 2015 435i M Sport, 2011 550i, 2011 535i |
07-07-2015, 09:14 PM | #3 |
Dream crusher
984
Rep 2,421
I wonder if a muffler delete with resonators still intact would give the sound and minimal drone at freeway speeds?
IG: @bmwdoubles |
07-07-2015, 11:02 PM | #6 |
Rep 844
nothing vibrant will ever go on my car... Magna flow, Borla, maybe dynomax, but thats about it. I like Akrapovic but just too expensive.
07-07-2015, 11:44 PM | #8 |
Rep 844
curious what components he used. I have my eventual system planned out once (if) I get down pipes, I was just wanting more rumble. Magna flows have a tendency to sound incredible and deep under hard acceleration, as do Borlas... the big issue is which one I want to use for fitment purposes as even the short body mufflers leave little room for tips.
07-08-2015, 10:54 AM | #9 |
Rep 844
Ehh little update after driving for a day... I know it shouldnt feel any different, however throttle response and power DOES feel different. I keep telling myself its only in my head, but it feels significantly less lazy down low when you stab it. Only conclusion I have is I got rid of all the squished tubing they used to clear things and have only full diameter round now. Right after the rear large resonator it did pinch down pretty small , almost wish I saved those pieces just to show.
07-08-2015, 11:02 AM | #10 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
07-08-2015, 12:36 PM | #11 |
Rep 844
none at all, I almost think its a bit quieter than stock... which makes the kick in the balls worse! My car is silent and the roads here are for the most part great with average speeds of 70-80 mph, so id notice even the slightest increase in volume or drone. Too bad its 110+ out every day or id go dyno to see if there was actually a difference. Going to order Borla XR1s as soon as I take some measurements and pick out tips.
07-09-2015, 11:23 AM | #13 | |
Dream crusher
984
Rep 2,421
However, I'm very interested now in replacing my resonator with an x-pipe now that your reporting better throttle response. I'm getting a catless DP next week while keeping my stock exhaust in tact. I'll report back on sound/tone. FYI I've if the sound quality is right for me meaning DP and x-pipe combo and I want the look of an expensive exhaust I was going to do the M5 retrofit diffuser and these tips on my stock exhaust. http://m.ebay.com/itm/161343769695?_...49&_mwBanner=1
IG: @bmwdoubles |
07-10-2015, 12:03 AM | #15 | |
Rep 844
To each their own, and theres no "wrong" way to do it, just whatever you like. Ive had AT LEAST 5 different exhausts on every car ive owned until I was happy.
07-10-2015, 09:40 AM | #17 |
Rep 844
Really doesnt matter, dual 2.5ish (slightly larger since its metric) is more than enough to support over 600 rear wheel horsepower, the main thing would be to get the restrictions out of the factory setup where it has been crushed for clearance. Obviously bigger is better when it comes to turbos (you will not EVER find a factual article supporting smaller exhaust for turbo vehicles as the turbo produces plenty of backpressure, but there is a point of diminishing returns where its just a waste of money) but at the same time unless youre running larger turbos, E85 and LOTS of boost, theres no need to increase the actual diameter of the exhaust (and even then, cars have been making 1000+ horsepower on dual 2.5 or single 3.5-4 inch forever). If you live in an area where stainless is required for rust purposes, you may want to buy an entire system for that reason instead of modifying as I did, otherwise you need to make sure you use stainless steel piping and stainless welding wire so it doesnt rust.
07-10-2015, 05:30 PM | #18 |
Rep 183
Drives: 2015 BMW 650i GC
Hey Mike, I have a Shteigen system on my 550 now and if you'd like to hear it some time just let me know. It sounds pretty good to my ear and downright angry at WOT...
07-10-2015, 05:51 PM | #19 |
Rep 844
as a fabricator, it goes against my religion to pay more for anything that it costs me to build it, but id love to hear it sometime Knowing what goes into building a muffler, and how much in the steel, I cringe at the cost of these systems! That being said, single piece mandrel bends arent cheap even for shops that sucked it up and bought a mandrel bender, so im sure its just offsetting labor/ R&D costs and reduced sales compared to something common. This months fun money went to firearms, so maybe next month I will order up some mufflers and tips.
07-10-2015, 06:04 PM | #20 | |
Rep 183
07-10-2015, 06:06 PM | #21 | |
Rep 844
07-11-2015, 09:16 PM | #22 | |
Joint Chiefs of Staff
24161
Rep 190,725
If it was my car i would rather get an exhausts system built for it . You have a ton of options AFE, GThaus, Megan Racing, Remus,etc...
