2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums Regional Forums UK Phone mounting options?
      06-27-2015, 08:41 AM   #1
IanS100
IanS100's Avatar
England
136
Drives: 520d F10 LCI M Sport
I'm trying to find a practical phone mount that neither obscures a big part of the dash, nor risks impact to/from a knee when stuck on one side or the other of the centre console (eg Brodit). Has anyone come up with any bright ideas for mounting a mob phone? If it makes any difference I'm using a note 3 - cheers!
      06-29-2015, 05:51 AM   #2
325_bucks
Drives: F90 M5 Competition
This is my solution to exactly the problem you are having. I was not happy with the brodit mounts for the same reason. I use this:
http://www.carcommunications.co.uk/c...ies-f1011-2010
Then i use the brodit cradle attached to it. You have to remove the front of the dash area and zircon to screw the mount it (but its easy) and once its in, its solid. I've wired a USB cable from the mount back behind the dash and under the centre console and to the USB socket in the armrest.
Once installed, everyone thinks it looks almost stock and does not obscure any part of the dash or get hit with any knees etc.
      06-29-2015, 06:05 AM   #3
IanS100
IanS100's Avatar
England
136
Thanks for the reply, I've seen these but was worried it could 'kneecapitate' any passengers?
As a temporary measure I've butchered a Brodit mount from my old 3 series (right hand dash fitting), it's not perfect and needs hard wiring but it does the job for the moment. The headlight switch is obscured somewhat, but it's still accessible and doesn't inconvenience me as I seldom change it from auto.
      06-29-2015, 06:09 AM   #4
325_bucks
no it should be ok in the current position, the picture is misleading, mine is much higher, near the horizontal trim strip above the glove box etc. I don't know if i installed mine incorrectly but I think i remember using a screw higher than the one they recommended and it still fit fine, and was even further away from the passengers knees, and was in a better viewing position in my opinion. Ill try attach a pic if i get to my car soon
      06-29-2015, 06:12 AM   #5
xenon
xenon's Avatar
England
1397
Drives: 2021 G21 330i M-Sport
Why do you need to mount the phone at all if it connects by Bluetooth?
What am I missing?
Ian
Current: 2021 G21 330i M-Sport
Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2
      06-29-2015, 06:15 AM   #6
325_bucks
well one reason is that I like to see the phones display but mainly it's so i can use the apps like spotify, deezer etc over USB, so as soon as the phone goes in the cradle, it connect to usb (and charges) and I can see it as a second "display" in the car. Mainly though its for app use and a convenient place to put it. If i just used it for Bluetooth applications then yeah, mounting it might be unnecessary but i don't.
      06-29-2015, 06:33 AM   #7
325_bucks
      06-29-2015, 06:47 AM   #8
IanS100
IanS100's Avatar
England
136
What am I missing?
Despite having Pro Nav I tend to use TomTom on the phone for routing as it usually suggests more sensible routes.
I also have a speed camera alert app which I usually run, and before the speed camera police shoot me down, I endeavour not to speed but I still prefer to be warned of cameras.
I don't have 'OFFICE' so I don't get access to emails other than on the phone, neither can I reply to texts, I don't mind stopping to read / answer but, mounted properly, I don't have to faff around getting the phone as I can read and answer directly from where it's mounted.
      07-01-2015, 01:36 PM   #9
Chrissy_bwoy
Drives: F11 520D M sport
I use a Nokia CR-123. It attaches to the windscreen and i have it on the right hand side of the instrument cluster. Very stable and perfect for iphones as its fully adjustable.
https://www.amazon.co.uk/dp/B005WKEY..._DkdLvb4CM2XQK
      07-01-2015, 01:55 PM   #10
Pottsy
Drives: F10 535d MSport
Interesting.
I too use Tomtom (on a Nexus 5) because Pro Nav + RTTI just is not good enough by quite a long way. I use a decent quality vent mount on the right hand side of the cluster, but that Nokia looks good. Can you get a charging cable in - on the bottom edge right in the centre?
      07-01-2015, 02:12 PM   #11
IanS100
IanS100's Avatar
England
136
The Nokia does look interesting and ripe for a little modifying, can you grab a couple of pictures of the holder in situ and with phone attached, cheers
      07-01-2015, 04:07 PM   #12
Chrissy_bwoy
Couple of pics. Bit crap cos its dark, if you want some more ill do some tomorrow.
http://smg.photobucket.com/user/chrissy_bwoy/media/78946F84-611B-4013-846D-932F2D711FFE_zpsoo3gdnyd.jpg.html][IMG]http://img.photobucket.com/albums/v6...psoo3gdnyd.jpg[/IMG][/URL]
http://smg.photobucket.com/user/chrissy_bwoy/media/C2A7519A-7733-4F6D-9A39-529EB78FC6F6_zpsixf0f5dt.jpg.html][IMG]http://img.photobucket.com/albums/v6...psixf0f5dt.jpg[/IMG][/URL]
http://smg.photobucket.com/user/chrissy_bwoy/media/F4065429-1571-4CC0-B7FE-6137266ACB71_zpsmhbfouim.jpg.html][IMG]http://img.photobucket.com/albums/v6...psmhbfouim.jpg[/IMG][/URL]
      07-01-2015, 04:09 PM   #13
Chrissy_bwoy
Originally Posted by Pottsy
Interesting.
Yes, the bottom mount is open to allow a usb or apple lightning through.
      07-01-2015, 05:14 PM   #14
IanS100
IanS100's Avatar
England
136
Cheers, that looks really good, if you could take one from the side showing the sucker mount to phone I'd appreciate it
      07-02-2015, 06:52 AM   #15
Pottsy
I think I'd rather have mine lower, so it doesn't obscure the view out of the windscreen.
      07-02-2015, 10:41 AM   #16
Chrissy_bwoy
Is this what you meant?
http://smg.photobucket.com/user/chrissy_bwoy/media/D63463F0-0A5E-42F5-A897-A1776F7D54D9_zps36ft4scj.jpg.html][IMG]http://img.photobucket.com/albums/v6...ps36ft4scj.jpg[/IMG][/URL]
      07-03-2015, 12:38 AM   #17
IanS100
IanS100's Avatar
England
136
Cheers, I'm torn now, I think the Nokia gives us what is probably the most user friendly mounting position I've seen in an F10, yet I'm with Pottsy, and hate to have anything obscuring the windscreen, even a little corner like that!
      07-03-2015, 03:08 AM   #18
Chrissy_bwoy
In practise I don't notice it there as it doesn't really obsure anything other than the top of the dash. For me being at that level I don't need to drop my eyes to see the screen.
      07-03-2015, 10:58 AM   #19
325_bucks
did you see mine above? It seems to fit your requirements, it is the most convenient, and least obstructive of all i looked at
      07-03-2015, 12:36 PM   #20
IanS100
IanS100's Avatar
England
136
Yes I did thanks, I see you're using a Brodit active mount, where have you taken the power from?
      07-23-2015, 02:35 AM   #21
richiemail
Drives: X4 M40d (G02) LCI
Originally Posted by 325_bucks View Post
Hey 325_Bucks, how is the cable routed for your active mount? Does it go back to the centre console USB port, or the glovebox?
      08-06-2015, 07:40 AM   #22
325_bucks
Hi sorry I didn't see this reply before.
Yes the power goes into the dash under the metal trim (you can still squeeze it all back together with the cable running into it) and then under the centre console and back to the USB port in the arm rest. I had to remove the metal cover on the centre console but it could probably be achieved with smaller fingers and a coat hanger.
