01-28-2016, 02:42 PM | #23 |
Dream crusher
984
Rep 2,421
Note: do not attempt to do the rear by yourself.
The back seats have to come out, the rear panels and rear deck have to be removed, someone has to press with a large breaker bar on the lower control arm to remove the strut and to reinsert and someone has to push up on the strut when reassembling. Other then pretty straight forward.
IG: @bmwdoubles |
01-28-2016, 02:43 PM | #24 |
Dream crusher
984
Rep 2,421
Stock vs Eibach pro rear spring
IG: @bmwdoubles |
01-28-2016, 06:05 PM | #25 |
Dream crusher
984
Rep 2,421
Just installed after it settles I'll do a another. Definitely lower in the rear, right after install.
IG: @bmwdoubles |
01-28-2016, 08:36 PM | #27 |
Rep 14,522
Looks pretty damn good!
01-28-2016, 10:10 PM | #28 | |
Dream crusher
984
Rep 2,421
The ride is way better than stock. I had non m sport springs and no dynamic handling package . Also I have the m5 sways and my body roll has dramatically reduced. I have the 650 sway in the rear and that was noticeable stock height, but not the m5 sway front. Now that it's lowered the m5 sway is handling business. Body roll is almost gone under semi hard cornering. Springs suck up bumps way better than stock, almost make the run flats tolerable. There's still some unwanted rebound because I had one leaky strut in the front. That's going to be replaced with Koni or Blisten B8's soon. That should improve ride quality even further.
IG: @bmwdoubles |
EV8634.00 |
01-29-2016, 07:38 AM | #30 |
Rep 14,522
definitely will improve big time! for the price your gonna pay or paid with the Eibachs and now shocks shouldn't have been better bro to go with the KWV1's? i'm going with that hear come Springtime...$1349 and save on labor and do it myself with the help of my boys! i'll have to check and see because i remember googling prices awhile back on shocks for our cars. i think we both have the same car as i don't have EDC
01-29-2016, 12:32 PM | #31 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
02-15-2016, 04:38 AM | #32 |
Poland approaching...
24
Rep 264
So how is the ride now?
Has the car settled bit more since you have put new springs on?
F10, Styling 312, Eibach Pro Kit, Black Grill
02-15-2016, 07:29 AM | #33 |
Rep 14,522
How any fingers in the rear gap?
02-16-2016, 02:23 PM | #34 |
24
Rep 264
On Friday I will change OEM springs with eibach pro kit.
Before I do it I measure gaps before and after to give you some idea...
02-16-2016, 04:40 PM | #35 | |
Dream crusher
984
Rep 2,421
Great improvement in handling.
IG: @bmwdoubles |
02-16-2016, 05:05 PM | #36 |
Dream crusher
984
Rep 2,421
A pinky. Just enough for a 12-15mm spacer
IG: @bmwdoubles |
02-17-2016, 03:23 PM | #37 |
24
Rep 264
Thanks for comments.
What also wonders me is the back seat... Why have you removed it when you have the access to the shocks via rear speakers. Taking out rear seat does not make the access easier as still you need to unscrew shocks via rear speakers. Or am I mistaken....
02-17-2016, 04:43 PM | #38 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
02-17-2016, 05:15 PM | #39 |
Dream crusher
984
Rep 2,421
See the side panels removed
IG: @bmwdoubles |
02-18-2016, 03:19 AM | #40 |
24
Rep 264
Ok get it but I've removed the speaker covers and speakers without taking off these side panels.
If you take them off there is not much more space in my opinion. With back seat however I agree - if it is out it is easier then to play with tools via these speaker holes In my F10 it is a bit less work to do with rear seat as I have back seat opening system. So the back seat just opens and makes the flat floor with the boot and then operating area is clean. Anyhow thanks for info and pictures. I will post mines later today when I get my car lowered.
02-18-2016, 12:05 PM | #41 |
Dream crusher
984
Rep 2,421
New parts installed always makes for an exciting day. Congrats.
IG: @bmwdoubles |
02-19-2016, 06:34 AM | #42 |
24
Rep 264
So my ride is on eibach today.
I have measured the height before lowering and after. Height from the ground to the highest point of the edge on the fender. So front before lowering was 71,5 cm and 68,5 cm after. Rear was 70,5 cm and after is 68,5 cm. So 3 cm down for the front and 2 cm down for the rear. Below some pictures. Sorry for the quality but we have winter here in Poland and the weather is too shitty to keep the car clean longer than 5 minutes after leaving the car wash Before the lowering. After the lowering with summer 20" just to see how all fit together Gaps
02-19-2016, 09:36 AM | #43 | |
Dream crusher
984
Rep 2,421
IG: @bmwdoubles |
