2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes Cheap EBay Strut Brace
      12-22-2019, 10:04 AM   #23
jooobi3
jooobi3's Avatar
Drives: 2011 BMW 535i XDrive
Originally Posted by John H. View Post
Originally Posted by jooobi3 View Post
Item link: https://rover.ebay.com/rover/0/0/0?m...2F264087717513
Installation was easy, just removed the top 3 bolts that's holding that your struts than place it over. However, I had to made some of the existing holes on the product a little bigger in order to make them sit flush with my coilover bolts. Shipping was fast and for the price I can complain.
How long did it take for you to get the bar?
I didn't have that choice to remove the muffler. So it took me about 2 hours to get it in. It wasn't fun lol
      12-23-2019, 11:04 PM   #24
someone16
Drives: F10
Okay, just got them installed the other night I have not taken the car out for the test ride due the crappy weather. The front were really simple to install. However the rear was a pain in the ass. I'm assuming this is due to the different in the sizing. I'll update again once I get more seat time in the car.
Do you know what's the size of the stock stabilizer bar and the Eibach one? Does it make a big difference in the ride?
      01-22-2020, 04:21 PM   #25
John H.
John H.'s Avatar
Drives: 2014 535i XDrive
Just received my strut brace. It is good quality. Appears to be made for a German company, there is a sticker on underside of bar with name and address of a German Tuner. I'm sending the bar out to get polished. Have the new strut bolts, and will install the mounts todays. Will take a pic when complete.
      01-23-2020, 09:46 AM   #26
Sylverlee
Drives: White 535i M-Sport, 911 GTS
Nice will be curious if you notice a difference when it's installed.
      01-24-2020, 06:46 AM   #27
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
is it the same bar from the link posted? I may order one here next month
      01-24-2020, 09:45 AM   #28
John H.
John H.'s Avatar
prowrapper is the seller. Here is the linky...
https://www.ebay.com/itm/BMW-F10-F11...72.m2749.l2649
      01-24-2020, 10:02 AM   #29
Unspec
Unspec's Avatar
1301
Drives: 2015 BMW 535xi
Just a heads up to those doing the bar, because it just happened to me.
Be careful when bolting down the bar. The bolts go into little wells on the brace, so you can't use your fingers to hand tighten the bolt and you need to use an extension to tighten them initially. This makes it hard to feel if the bolt is cross threaded or not. I just stripped two (one on each side) strut tower holes and now need to retap them to a size larger.
If you ever need to remove the bar to remove, for instance, the airbox, just undo one of the bolts holding the actual silver bar, loosen the other side, and then just swivel it up. It's way faster and more convenient.
2015 BMW 535xi
ISTA VM Setup/Tutorial
John H.230.00
      01-24-2020, 10:33 AM   #30
BimmerHausPerformance
BimmerHausPerformance's Avatar
513
Drives: 2011 535i 6MT
2011 BMW 535i  [0.00]
I'll have to do this as well. Excited to see what it looks like polished!
2011 F10 S55 6MT
Website Insta @bimmerhausperformance YouTube
John H.230.00
      01-24-2020, 08:51 PM   #31
John H.
John H.'s Avatar
Good looking out Unspec! I just logged on to advise same. BTW, my LH/Drivers strut mount is toast. After removing the bolts, I noticed metal shavings on them. I suspect they were impacted, installed crooked, and/or over-tightened when I had the springs done. My RH/pass mount is OK.
The torque specs on the strut mount bolts are approx. 20 ft lbs. It can be easily over-tightened by hand. Also, these bolts are set-tapping.
For those who plan to do this....Test fit the strut brace mounts, and see how the holes line up with the strut mount. I had a few that would have made the mount bolt go in crooked. Used a Dremel to to open it up a bit.
I'm debating whether to replace the strut mount or installing Helicoils. If am not mistaken, the bolts are M8x30x1.25, 10.9 grade. Are you going with a M10 or near equivalent SAE bolt?
Did not have time to pick up brace from polishing shop. I'll get it on Monday.
      01-25-2020, 11:07 PM   #32
Unspec
Unspec's Avatar
1301
Yea, probably going to M10. Definitely can be overtightened by hand, so don't even bother tightening them by ratchet, go straight for the torque wrench. Helicoils seem like a good option as well, might just come down to cost versus retapping.
2015 BMW 535xi
      01-29-2020, 03:49 PM   #33
jooobi3
jooobi3's Avatar
As previously mention some of holes from does not line up perfectly. I used a step drilled and made them larger. I believe I only did this with two holes. You want to make sure you don't drilled it larger than the diameter of the nuts that's goes on them. It's fairly easy to do and yes hand tighten this before you use a ratchet. That's just common sense stuff with any bolting items.
      01-30-2020, 04:37 PM   #34
John H.
John H.'s Avatar
I decided to go with M8 Helicoils on the strut mounts. I can get a 21/64 bit through the body sheet metal w/o cutting into it. Also, I can still utilize the stock OEM strut bolts. On eBay, found a few NOS USA-made Helicoil kits out East. I'm expecting them today.
Did pick up the strut bar from the polishing shop. Will install when I square away the mounts. It will match the other polished items in my engine bay.
      01-30-2020, 04:40 PM   #35
513
Pics! What kind of shop did you take this to?
2011 F10 S55 6MT
      01-30-2020, 04:54 PM   #36
John H.
John H.'s Avatar
Dean's Polishing....same guys that did this....
      01-30-2020, 04:55 PM   #37
513
Nice! was the ham and cheese extra or did they throw that in?
And nice California car wash brush deal, I have the same thing lol.
2011 F10 S55 6MT
      02-01-2020, 07:31 AM   #38
513
Ordered.
2011 F10 S55 6MT
      02-01-2020, 08:02 PM   #39
John H.
John H.'s Avatar
So, I managed to Helicoil driver's side strut mount. It is SOLID. Tomorrow, will do pass side, and install the bar.
Had a bit of scare, tap fell out of t-handle into the BMW engine bay abyss. Dropped the splash shield, nada. Dropped the aluminum support, nada. Found it behind a brake line on the inner engine sidewall. Man, I was really worried.
      02-01-2020, 08:06 PM   #40
John H.
John H.'s Avatar
Lol. You saw that! On way home, picked up some snacks at the supermarket.
      02-01-2020, 08:19 PM   #41
513
Dropping crap down there is the worst lol.
2011 F10 S55 6MT
      02-02-2020, 01:53 PM   #42
Unspec
Unspec's Avatar
1301
How'd you drill out the hole? Just using a cordless drill?
2015 BMW 535xi
      02-02-2020, 05:46 PM   #43
John H.
John H.'s Avatar
@Unspec, Yes. Use a quality bit that cuts well. Also, be easy with the tap, I had broke one in the process. Some tools and parts used...
1.). M8x1.25 Helicoil kit, stainless inserts,#5546-8, NOS(New Old Stock) USA Made, $18 - eBay, stitapandtoolsupply
2.). Dewalt drill bit, , 21/64, item #93021, $5 - Lowe's
3.). T-handle tap wrenches, 3 pieces, item #38560, $9 - Harbor Freight
4.). Aerosal air duster spray, remove shavings from drilled holes, $2 - Micro Center
5.). Loctite Blue - for strut mount bolts.
6.) Brake cleaner -clean up area of oils.
7.) WD40 - For tap use and inserts installation.
Just finished the install. No hood adjustment needed. Came out tits.
      02-02-2020, 06:33 PM   #44
513
That looks nice, like the polished cross bars. Fair warning - that is going on my to-do list!
2011 F10 S55 6MT
John H.230.00
