2010 2011 BMW 5 Series Forum F10 M5 sway bar installation problem |
10-10-2013, 05:19 PM | #1 |
Rep 372
I am trying to install M5 sway bar purchased from getbmwparts.com on 2013 m sport 535. Problem is the end holes are smaller than the bolt at link arm. I thought this was direct fit according to forum as well as getbmwparts.com. Do I need to buy set of link arms as well? Is it good idea to drill m5 sway bar end holes bigger to fit on current link arms? See pics.
10-11-2013, 01:02 PM | #3 |
Rep 8,805
Strange....did you actually try to do the install?
I watched my shop install it on my 2013 535xi and it was direct bolt on. Alan
10-20-2013, 09:14 PM | #4 |
Rep 372
I tried installing it, but it just does not fit right. For example, when tie the end links on tie rod, it facing in upward of 45 degrees, opposite of M Sport bar. I don't know if that is normal. Also, on M Sport bar, ends are bit angled inside vs straight up on M Bar. Can some post of pics on end links with tie rods.
10-21-2013, 10:17 AM | #5 |
Rep 29,202
This is very weird, since the M5 front sway bar seems to fit all F10's, from my 520d to 550i.
02-24-2014, 10:45 AM | #6 |
Rep 92
02-26-2014, 02:27 AM | #8 |
Civilian
14
Rep 158
Is this the right part number 31352284460?
Warning, I'm prone to sudden attacks of enthusiasm.
__________________________________________ 2014 BMW 550i M Sport - Jet Black 2014 BMW X6 35i - Black Sapphire 2011 BMW X5 50i - Titanium Silver (traded) |
02-26-2014, 08:09 AM | #9 |
Rep 29,202
Yes, that's the front M5 sway bar.
02-28-2014, 07:39 AM | #11 |
Rep 29,202
Less body roll in curves.
02-28-2014, 02:30 PM | #12 |
Rep 29
For those of you who have DIY installed both the front and rear sway bars, is it possible to do without lifting the car? Is putting the car on jack stands a must?
03-31-2014, 08:26 PM | #14 |
Rep 1,126
UPDATE: It does fit msport 2013. BUT here is some things to notice. When you are looking at OEM Msport bar, links on each end point downward. When you install M5 bar, links point up. I don't know if it bad a thing. Only time will tell.
If you install on your own as I did, takes about 30-45min. Used ramps on front end only to raise up car. |
04-01-2014, 01:19 PM | #16 |
Rep 1,126
Holes are the same. Problem was I could not get the link bolt to loosen up, and just visually checking, oem sway bar holes looked bigger. But when I was installed m5 sway bar, links joint point upward. So if you take oem Msport sway bar and straighten up the ends, I think you can get stiffer joints & steering.
04-02-2014, 01:15 PM | #17 | |
Rep 29,202
M5 top M-sport bottom
04-04-2014, 10:38 AM | #19 |
Rep 29,202
OK, I see what you mean now.
04-16-2014, 06:21 PM | #20 | |
Rep 318
Thanks |
04-17-2014, 07:32 AM | #21 | ||
Rep 1,126
04-26-2014, 02:39 PM | #22 | |
Rep 318
Regarding the angle of the connection...my indie mechanic (former BMW master tech) noticed the angled and tight fit and agreed the set up is prestressed. But, he also said that I shouldn't expect any surprises, unless I go hard core racing, and even then, broken links are "cheap" to replace. Only time will tell. Thanks. |
