2010 2011 BMW 5 Series Forum F10 DIY: N63/N63TU High Flow Performance Panel Air Filters |
11-20-2017, 04:40 PM | #1 |
Rep 1,398
Warning: I am an Enthusiast and a DIY kind of guy. I have done this at my own risk and you should bear that in mind as well!
Having the n63 intake from ARM Motorsports throw a code on me and seeing what CReynolds did with his car gave me a great idea. You can see his DIY here to route flex tubes and cone filters to the front of the car, but I want to make an intake like the Mr. 5 intake from my n54 days. Here is CReynolds DIY (thanks for sharing man) and I have started my mission to make a high flow panel filter... CReynolds's DIY is here: http://f10.5post.com/forums/showthread.php?t=1441680 My mission begins. Materials: -2 stock air filters from RockAuto (L and R) for $17.09 each -UNI Universal Foam Filters Fine and Coarse $14.21 for coarse and $13.41 for fine -Hardware Cloth (metal mesh) Home Depot (1/4in- 2ftx5ft) 6,3mm for $9.99 Tools: Exacto Knife or Box Cutter Garden Shears Sharp Scissors Total before Tax and Shipping: Around 80 bucks DIY Part 1: 1) Take the stock panel filters and cut out the paper element but leave the orange gasket in place. 2) Make a template in the back of the filter where the paper element was. This will assist you in cutting and measuring the mesh and the foam filters. 3) Use your template to mark and cut the mesh and the foam. I'm working on this a bit at a time.. part 2 will come soon! Any questions/suggestions please let me know! Last edited by Simple5; 12-04-2017 at 04:09 PM.. Reason: Title Clarification |
11-21-2017, 03:20 PM | #4 |
Rep 659
11-21-2017, 03:21 PM | #5 |
Rep 659
11-21-2017, 03:49 PM | #6 |
Rep 1,398
11-21-2017, 04:32 PM | #7 | |
Rep 659
You've removed the filter and replaced it with mesh, but it's going back inside the airbox so thats why Im confused. Last edited by 535_BiTurbo; 11-21-2017 at 04:46 PM.. |
11-21-2017, 08:27 PM | #8 | |
Rep 1,398
Its a spin on Mr.5's intake.. I won't be drilling into anything. In Mr.5's intake: Stock Air Box- K&N Panel Filter Attached to Air Box- Drilled in Flex tubing that runs to the front driver side fender well with a cone filter attached. My intake: Stock Air Box-A Custom Foam Panel Filter like BadBlack's Attached to Air Box- The flex tubing with filters running into the grills. They will not be drilled because they will attach to the induction side of the stock air box by silicone couplers.. |
11-22-2017, 12:30 AM | #10 |
Rep 1,398
No, I put up the diagram that CReynolds posted. The Flex pipes replace the stock air ducts and the part where I circled is where the flex pipe attaches via silicone coupler. So no, no secondary holes. Dinan's design is CRAP cause it draws little to no extra air with those dinky ass filters. Also, their design requires you to drill into the SIDES of the airbox and also into the front end. With CReynold's approach you are using all the stock attachments etc
11-22-2017, 08:19 AM | #11 | |
Rep 659
11-22-2017, 09:00 AM | #12 |
Rep 1,398
Bingo, Bango, Bongo! After I finish the filters I will run with them for a day or so to test them. After that I will add on the flex pipes.
11-22-2017, 09:40 AM | #13 | |
Rep 659
Interesting to see how it compares to the ARM intake design and also if you notice any power differences. Do you you think there is a difference between using smoothing piping vs flex piping? It seems like flex piping would slow the air velocity down... Last edited by 535_BiTurbo; 11-22-2017 at 10:02 AM.. |
11-22-2017, 10:34 PM | #14 | |
Rep 1,398
Main thing is sound and I believe the filters sitting in the front grill will achieve that. |
11-23-2017, 05:33 AM | #15 | ||
Rep 153
12-04-2017, 03:53 PM | #18 |
Rep 1,398
Okay, I finally got the time to finish these. I have been driving around with them for a day or so and I have noticed that the car feels slightly smoother and there is a slight bit of induction noise.
It has been 150+ miles (took a road trip with my buddy to pick some stuff up) and NO CELS. I've also opened up the airboxes and checked the filter's integrity and no signs of stress, fraying, or anything.. So, On with the show.... DIY Part 2 (and final part) Additional Stuff you need: 4- JB Weld Clear Weld 4000- $4.89 each Walmart 1- Gorilla Glue Heat Gun Sticks- $3.97 Walmart 1- Uni Cleaning and Oiling kit- $20.95 Ebay 4) Cut the foam pieces out and put them aside. 5) Now you have to glue the mesh to the plastic part of the air filter. I used JB Weld Epoxy 4400 psi Clear Weld. 6) Line up the mesh onto the filter and place some weight onto it. Now while the mesh is weighted down use copious amounts of the epoxy and just layer it onto the mesh and the orange portions of the filter. Let the mesh/filters dry for an hour before you can work with them. 7) Once the epoxy has set you will find that the mesh is on there. Now the next part is to put the foam onto the mesh. This i s where you will be using the Heat Glue Gun. Put in a Gorilla glue stick, plug in the unit, and wait for 5 minutes before using. 8) Once the glue gun is heated up, lay the FINE (Black) foam piece down onto the mesh. Now lift up only one side at a time and lay down the glue (you cannot lay the glue down first and then put the filter on. It will dry too fast). Give it a few minutes to set. 9) When you have the fine foam layer onto the mesh now attach the coarse filter onto the fine filter the same way you did in step 8. Lay the coarse filter on top of the fine filter and heat glue the outer edges down. 10) I let everything settle overnight. The next day I sprayed the UNI oil onto the course portion only of the filter to trap particles and to minimize the chance of a CEL. But also, I will be coupling this with CReynold's intake setup very soon. Let the oil soak overnight. If you want you can spray the fine portion as well. I placed paper towels on the coarse side with some weight to catch any extra oil. Total Cost of the Project: $120 If you guys have any questions please let me know!! Last edited by Simple5; 12-04-2017 at 04:25 PM.. |
12-05-2017, 12:04 PM | #20 | |
Rep 1,398
Also a good DIY for someone that wants performance filters instead of their stock ones. |
12-05-2017, 01:48 PM | #21 |
Rep 659
You realize Dinan has an Auxillary air source introduced on both air boxes and they add 2 additional filters to filter that air. How is it tons more flow if you are adding 2 filters in the same air pathway when you go CReyonolds route?
12-05-2017, 03:02 PM | #22 |
Rep 1,398
Dinan uses those dinky filters and you drill into the stock airbox. Dinan also relies on the stock filters. You yourself said on CReynolds setup your car is breathing better and deeper because the piping is wider and the filters behind the grill are drawing in more air. More airflow means less restricted overall.
I just don't like the idea of the filters going out begins the grills without something between the filters and the MAF sensors. I picked the thinnest and less restrictive foam to use on my filters. In the end you're getting an intake for sound. I've heard/seen the Dinans in person and they are NOT worth the $2800 they are asking for on their website. Engine eye candy? Very much so. |
