2010 2011 BMW 5 Series Forum F10 SAT Gear Selector Switch retrofit DIY |
08-16-2013, 11:17 PM | #1 |
Rep 553
I got the idea from ShawnSheridan's thread found at:
http://www.bimmerfest.com/forums/sho...d.php?t=660759 I really liked the way that the SAT gear selector switch looked compared to the original version that came in my car. BLUF: The original came out and the SAT version went in and the car works perfectly. In order to get the cluster's gear indicator to display correctly, my car required some coding. Part Number 61319251190 http://www.realoem.com/bmw/showparts...5&fg=15&hl=300 is a plug-and-play (no coding for function and no new plug) replacement for: Part Number 61319251186 http://www.realoem.com/bmw/showparts...5&fg=15&hl=197 Step-by-step: Tools needed: TORX 20 1) Pry the center console storage release and lock button's cover off with your fingers. Just pull upward. 2) Slowly lift the entire forward center console decorative panel upward from the rear edge. It pivots on the front edge under the center console. 3) When you meet resistance, stop, and look under the panel. You will see two sets of wires which have three attachment points which must be disconnected. 4) The set on the left is detached by pulling the plug towards the rear of the car. The set on the right is detached by a large plug connected to the bottom of the panel, and a small plug half-way down the larger wire set. Remove the larger plug first and that will ease your removal of the smaller plug from the bundle. 5) Remove the four screws holding the gear selector switch trim panel and move the trim panel aside. 6) On the right side of the gear shift module you will see a two-piece white plug which obstructs your access to the front right screw of the gear selector switch. Pull the back half of the plug out of the front half. Now press the small center white spine of the forward plug downward and remove it from the fixture by pulling it forward. 7) Remove the four screws holding the gear selector switch in place. 8) Lift it until you can see the wires and plug on the bottom of the module. Pull the plug from the module. Note that the plug is horizontal, not vertical. 9) Plug the new gear selector switch module in to the car, and button it up. I started the car and test drove it by trying to do all of the things a gear selector switch normally would do, and I also tried to get it to do things that it shouldn't, like moving from Park into Drive without the unlock button being pressed, or trying to put it into Park at 85 mph (no I didn't just checking to see if you're still awake ) I have not done any coding to get this to work at a functional level. In order to get my car's gear indications to display correctly, I had to code the following: After injecting CAFD's for EGS and GWS, I FA (VO) replaced 205 with 2TB, then EGS and GWS coded with the new FA (VO). Prior to the coding, the gear shift indications were: Drive: D Sport Auto (shift lever just pushed to left): DS Sport Manual: M1, M2, M3, etc After coding, the indications are: Drive: D Sport Auto (shift lever just pushed to left): S1, S2, S3, etc. Sport Manual: M1, M2, M3, etc Please let me know of any questions that you may have.
Regards,
MWPos Last edited by MWPos; 08-18-2013 at 06:42 PM.. Reason: re-ordered some pitcures |
08-17-2013, 12:11 AM | #2 |
Rep 40,728
Drives: 2018 Alpina B6 650ix GC
Nice job and good write-up!
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
08-17-2013, 08:03 AM | #4 |
Rep 553
Thank you. The car is a 3/11 build 535i. Here's the GWS tree and some details from the GWS ECU.
08-17-2013, 04:37 PM | #5 |
Rep 40,728
You do not have a GWS CAFD.
I have only seen this before on M5, which has no CAFD for GWS or EGS.
08-17-2013, 04:42 PM | #6 |
Rep 553
Thanks for your help on this Shawn.
After injecting CAFD's for EGS and GWS, FA (VO) 205 replaced with 2TB, then EGS and GWS coded, everything works perfectly and displays as expected.
Regards,
MWPos Last edited by MWPos; 08-18-2013 at 08:34 PM.. |
08-18-2013, 11:10 PM | #7 |
Rep 40,728
08-20-2013, 07:15 PM | #9 |
Rep 553
When I saw the side-by-side pictures in Shawn's thread I knew I had to do this. I never would have tried it without Shawn's example and another member's pointer to some eBay auctions in Europe.
Regards, MWPos
Regards,
MWPos |
12-27-2013, 11:12 PM | #13 |
Rep 553
According to realoem.com (results of the query below) the exact gear selector that I used for my retrofit is NOT usable in the X5. Something similar may be, but mine is not according the realoem.com's report:
Part 61319251190 (Gear selector switch) was found on the following vehicles: F06: Details on F06 F06 640i Gran Coupé F06 640iX Gran Coupé F06 650i Gran Coupé F06 650iX Gran Coupé F10: Details on F10 F10 528i Sedan F10 528iX Sedan F10 535i Sedan F10 535iX Sedan F10 550i Sedan F10 550iX Sedan F10 Hybrid 5 Sedan F12: Details on F12 F12 640i Convertible F12 640iX Convertible F12 650i Convertible F12 650iX Convertible F13: Details on F13 F13 640i Coupe F13 640iX Coupe F13 650i Coupe F13 650iX Coupe F25: Details on F25 F25 X3 28iX SUV F25 X3 35iX SUV
Regards,
MWPos |
12-29-2013, 08:33 AM | #14 |
Rep 937
I have a ceramic SAT gear selector for sale in the classifieds that will fit F10s or 6 series built prior to 03/2012
03-17-2015, 02:22 PM | #17 |
Rep 553
Very Nice! Congratulations!
Do you have anything to improve or change in the DIY write-up?
Regards,
MWPos |
03-17-2015, 02:57 PM | #18 |
Rep 1,152
The hardest part for me was removing/disconnecting the wiring. I ended up using mini screw drivers (http://www.mscdirect.com/product/det...S_010=72883218) to remove the connectors. Other than that, your step by step instructions were perfect.
12-01-2015, 02:31 PM | #19 |
Rep 7
Hi everyone,
This is my first post, so forgive me my beginners' questions Could You please elaborate i little bit on 'injecting CAFs' ? I am able to change FA and do VO coding, but why should I replace CAFs on any of my installed modules? Currently I have collected all required parts (steering wheel with paddles and airbag, SAT gear selector) and I am preparing for this upgrade - however I would like to fully understand each step before I start. From what I understand, the GWS module is integrated with gear selectors (both the standard one and the new SAT selector), so when I replace the entire gear selector, I will also have the new GWS module installed and connected. Does it need to be coded/flashed anyway? You also mentioned EGS module - why wouldn't it be enough to simply VO code that module? Is there a different ECU firmware for SAT gearbox? If so, does 'injecting' new CAF in this module in fact change it's firmware? Where should I take this new CAF file from and how would I be able to tell, whether CAF origins from 205 or 2TB gearbox? Excuse me if any of my questions would be considered stupid As I said, I would really like to understand every step of this retrofit, before I start doing it myself. Thanks |
03-26-2017, 05:16 PM | #20 |
Neon Garden
85
Rep 402
Hi everybody!
Thank you for your gear switch upgrade DIY. After replacement gear switch my ISTA+ shows 2 error codes 8026F0 and 8026F3 GWS no current codding data stored and GWS control unit is not coded for the vehicle. Anybody knows how to code a replacement sport gear switch to my car and resolve fault codes? I erased it many times but no luck, still getting it back. Thank you for advice! |
03-28-2017, 10:28 PM | #21 |
Rep 553
This may be totally irrelevant, but I'll ask anyway...is the SAT you have the correct part for your car?
Regards,
MWPos |
02-02-2018, 03:43 AM | #22 |
Rep 100
Hello friends, I made this change in a bw f20, and everything works perfect, but I want to update the selector to the latest version and make code from esys to the selector but it does not let me do anything, it appears in esys but code is inactive someone knows What may be happening? thanks.
