2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions SAT Gear Selector Switch retrofit DIY
      02-02-2018, 11:53 AM   #23
Originally Posted by r0b3r View Post
Hello friends, I made this change in a bw f20, and everything works perfect, but I want to update the selector to the latest version and make code from esys to the selector but it does not let me do anything, it appears in esys but code is inactive someone knows What may be happening? thanks.
I believe ESys needs a new token to work as on 12/31/17. Check the coding section for more info.
      02-27-2018, 07:18 AM   #24
r0b3r
Drives: Bmw F
If I have paid, but I can not update, anyway to update does not need token
      11-06-2018, 10:28 PM   #25
jonobro
Drives: bmw f10 535i
Originally Posted by shawnsheridan View Post
Originally Posted by MWPos View Post
Thanks for your help on this Shawn.
After injecting CAFD's for EGS and GWS, FA (VO) 205 replaced with 2TB, then EGS and GWS coded, everything works perfectly and displays as expected.
Hey Shawn I purchased this for my 2011 bmw 535i turns out I only have 8 pins... ugh what do you recommend I do and has anyone done this
      11-06-2018, 10:30 PM   #26
Did you get the right shifter? IIRC, there was a change with the LCI (2014+). I could be wrong, just ask my wife...
      11-06-2018, 10:48 PM   #27
jonobro
This is the one I purchased.
      11-07-2018, 11:59 AM   #28
Physically they look the same... You'll need to check part numbers. I upgraded my 2012 to the SAT and it was plug-n-paly.
      11-07-2018, 12:13 PM   #29
jonobro
Damn mind helping me find the correct 1 then ?
I have a 2011 bmw 535i
      11-07-2018, 01:29 PM   #30
I went to realoem.com and found this...
For a 2011 F10 the p/n should be 61319253077; however it was replaced by p/n 61319296900. There does seem to be a change between MY2013 and MY 2014.
http://www.realoem.com/bmw/enUS/part...&q=61319251182
      02-19-2020, 07:54 AM   #31
Tiger Joe
Drives: BMW 535i
just joined, sorry for bumping an old thread, but is there any way to tell what shifter you have without removing it and counting the pins, 8 vs 10?
it seems like 3/2012 is the changeover
my car is a 2012, purchased 3/12, so i assume is the early version.
I just bought the car and want to replace the shifter since the "P" is worn. would love to upgrade to the sport shifter, just want to get the correct one.
      02-19-2020, 08:37 AM   #32
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Changeover happens in the factory, so you need to look at your production date, not purchase date. If your car was purchased 3/12, it was probably made in 2011. So you have the early version.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      02-19-2020, 09:25 AM   #33
Tiger Joe
Drives: BMW 535i
right like i said i assume my car is early, but is there any way to confirm without removing the shifter and looking at the actual plug?
i think the early cars should be 8 PIN vs the later 10 PIN
      02-19-2020, 09:46 AM   #34
Unspec
Unspec's Avatar
1300
Nope, they're visually identical. Just remove the shifter, it's not particularly difficult.
2015 BMW 535xi
      02-19-2020, 04:02 PM   #35
I just bought the car and want to replace the shifter since the "P" is worn.....
If all you want is to replace the "P" why not paint it? I did that on our 2012 before I just replaced the shifter with the SAT shifter. Chip off the old "paint' (BE CAREFUL!) get a stencil kit the right height (I don't remember the size) and put the "P" in the middle then just paint with plastic spray paint. Once dryish, pull the stencil and voile, you have a new "P"! The silver surround (base shifter) just pops-off giving you access to the "P" piece. Just be careful, slow and methodical.
YMMV
      02-19-2020, 08:20 PM   #36
Tiger Joe
Drives: BMW 535i
Well I do like the look of the sport shifter better so if I can find a decent used on cheap I’ll swap it.
I did pull my shifter tonight and it’s the old style, 8 pin. It actually had a date on the side of 2/12 so it was close to the cutoff.
Unfortunately it looks like the 8 pin one is much harder to find than the 10 pin
      03-20-2020, 10:02 AM   #37
ivanoviskie
Drives: BMW 530d xdrive
Thank you for the informative thread, I will do the change of the Gear selector switch because the lights aren't working on my current one, I have the error code 802680 (Function indicator faulty).
Is there any fix to this error code other than just changing the whole GWS.
Thanks again.
