2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum annoying noise driver seat
      10-15-2012, 04:52 PM   #1
martin mustang
Ireland
256
Drives: 640d,X5 45e, 911c4s, 635csi
I have a very annoying noise around my head when driving, not sure if this is coming from the headrest or the sunroof, not always on but very noticeable when no music on, any of you folks experienced similar noise if so any solutions on how to fix this? thanks for any feedbacks on this none sense from a car meant to be Premium.
      10-15-2012, 05:40 PM   #2
ceebange061175
Drives: f10 535i M-sports
I heard one of the member had same problem and found out the hex. screw from sunroof were loose to make some kind of noise. Check and see they are tight enough. I hope this helps.
      10-15-2012, 08:43 PM   #3
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
My plastic seatbelt buckles rub against the leather seat, squeaking through every bump and turn. It's irritating.
      10-16-2012, 07:16 AM   #4
fat dog
fat dog's Avatar
England
29
Drives: iX3 M Sport Pro
Is it the same as this?
http://f10.5post.com/forums/showthread.php?t=745516
      10-16-2012, 08:29 AM   #5
Alan l.
Alan l.'s Avatar
5415
Check this - http://www.bimmerfest.com/forums/sho...d.php?t=651747
Simple fix if it is.
Alan
      10-16-2012, 01:31 PM   #6
martin mustang
Ireland
256
Originally Posted by fat dog View Post
Interesting, I never thought of the seat belt side, I know the passenger one after used, never goes back properly hence moves against the plastic cover on the B pillar, once pushed back to its normal position no longer an issue, I be checking this one out for sure, thanks for the link.
      10-16-2012, 01:38 PM   #7
martin mustang
Ireland
256
Alan
excellent, thanks Alan or this one I guess next one on my list of the belt is fine and not the one behind the problem, mind you very annoyed about this in a car like the 5 series. maybe on a 1 series.
      10-16-2012, 01:41 PM   #8
martin mustang
Ireland
256
Hi JNolSol, I know the passenger one after used it never goes back properly hence moves against the plastic cover on the B pillar, once pushed back to its normal position no longer an issue, i.e. you want to it back between the seat and the b pillar fully back, this is how I solve this one, the seat I have are the standard sport one with the M package.
      10-18-2012, 03:59 PM   #9
JNoSol
JNoSol's Avatar
The squeak is actually coming from the female buckle, rubbed against the bottom seat.
