2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Why Fog Lamps don’t work with High Beams…
      07-19-2015, 10:40 PM   #1
dbs600
Drives: 2011 750LXi Individual
I know coding can resolve this and that high beams aren’t meant for fog, but anyone know why fog lamps don’t remain on with high beams?
Fog lamps provide additional lighting that should remain on if maximum lighting is desired, no?
      07-20-2015, 05:46 AM   #2
BMWrules7
Drives: 2015, 740 LdX, Alpine White
In the USA, federal guidelines require fogs shut off when hi beams selected.
1. The prevents over bright conditions that could dazzle oncoming traffic with an amount of light normally reserved for emergency vehicles. (My poor speculation)
2. In many cases with fog present, it is best to turn off the high beams to prevent reflection from obscuring your view. (Maybe the Feds don't want you to make the mistake of using hi beams when it's foggy outside.)
      07-20-2015, 09:45 AM   #3
dbs600
Thanks for the great info, BMWrules7!
So it's due to a restriction limiting forward lighting for safety!
      07-20-2015, 11:00 AM   #4
493263
493263's Avatar
71
Drives: 2011 550i xDrive
Because fog lamps and high beams have very close angles. In other words, it doesn't dip down at a steeper angle than low beam. You don't need to have them both on at the same time.
That's why you're not supposed to use fog lamps in normal driving condition because fog lamps can still blind people from far away in the opposite lane. The only reasons why it's not as distracting as high beam is because it's generally a weaker output bulb and it's placed very low to the road.
There's a few people in this forum that are adamant about fog lamps not being a problem. They're wrong and are probably a road hazard to others.
      07-27-2015, 08:22 AM   #5
gspannu
Drives: F10 535, F82 M4
I doubt these are such a road hazard. If they were, legislation would not allow fogs/ high beams in UK or Europe.
I guess it is US legislation based on some early laws - automotive laws are usually the last to be changed; and do not really keep up with technology.
A similar example was the Adaptive LEDs and Xenons - these were launched in UK/ Europe without any limitations, but in the US, the lights were launched without the Adaptive bit; and it took a while for BMW to get the necessary approvals.
Kyngofpop676.00
      07-27-2015, 09:36 AM   #6
493263
493263's Avatar
71
Yes the US legislative process is slow. It's not a big deal with 25W halogen fog lamps but you know people will put higher output bulbs in there. LED fog lamps are starting to pick up. Some also install HID fog lamps. I see it more and more often. It's infuriating when you're blinded by these lights. A quick google will show you a mixed perspective. The people saying it's not a problem probably drive SUVs/Trucks or they are the ones with the unreasonably bright fog lamps.
Seriously, fog lamps blind other drivers more than it helps you see the road more. It's angled near horizontal, not dipped down like your low beam.
      07-28-2015, 05:58 AM   #7
m_alnimah
Qatar
70
Drives: 2016 Mini Cooper S 5 Door
2015 BMW X5  [10.00]
I agree! But if it's a Little Car that's pretty much Superglued to the road I don't see why Fogs will be a Problem...
2015 X5 xDrive35i M Sport, Black Sapphire on Terra Dakota Leather, Lane Change Warning, Lighting Package, 6WB, ConnectedDrive Services... (Sold) 2016 Mini Cooper S 5 Door Fully Equipped. (Sold)
2016 Audi A6 35 TFSI
2017 X6 xDrive50i Pure Extravagance, Space Grey on Coral Red, Fully Equipped.
