07-03-2011, 03:11 PM | #1 |
Rep 287
550i Undercar pictures
So i got my new 550i Xdrive with adaptive drive up on my 4 post lift on saturday.
Love to see under my cars and inspect it, and learn more about it. Here are a few pictures from my iphone. Mostly the exhaust do The exhaust has a outside diameter of 2-3/4''OD (70mm) from the downpipes all the way to the mufflers. I must say i was impressed on the setup ( for a factory setup) Nice big dual piping all the way, with nice secondary cats. These pipes must flow pretty good. A few crushed areas to add extra clearance room. But not bad at all in general. I was thinking of making a mid section to bypass the resonator x-pipe with a high flow x-pipe. This could add a bit of sound to the car. The 550 is just to quiet, needs a little more tone!! My car has the adaptive drive suspension, i took a picture of the rear swaybar hydraulic motor that is located right in the center of the bar, the other edges of the bar is like a normal swaybar, but it has the hyd motor in the middle. This motor must increase and decrease hyd pressure as required by the suspension controler. Pretty cool stuff.
Current, i3 Capparis White, Lodge interior
Ex- F10 550i Xdrive M sport, white Ex- trade-in 2008 E90 M3 |
07-08-2011, 04:45 PM | #2 |
Rep 100
Very nice...thanks for the pics...agree with you that the car is away too quiet...wish BMW would take a page out of the mercedes V8 cars..all the benz 8 cylinders have great sounding exhausts.. Wonder if just removing the center resonator and replacing with straight pipes/tubes will make a noticable difference.
07-12-2011, 08:29 PM | #4 |
Rep 287
You don't see the jacking points on these pictures.
The car has 2 plastics square lifting point on each side below the rockers.
07-12-2011, 09:50 PM | #5 |
Rep 100
I meant the central lifting points, not the jack pads. The beamers of old had a pad under the engine and a brace that in front of the diff that was the place to use seemingly.
07-12-2011, 10:16 PM | #6 |
Rep 287
oh sorry, was wondering before how come you asked that,
I should have figured that lol But i did not notice one
07-13-2011, 07:24 AM | #7 | |
454
Rep 4,592
Try an eisenmann system, you will definitely hear the car after installing it. |
07-13-2011, 09:07 PM | #8 |
Rep 287
Do you have info on the Eisenmann systems?
