2010 2011 BMW 5 Series Forum F10 ARDesign Ceramic Coating Catless Downpipes for (550i/N63) |
03-02-2017, 10:21 PM | #1 |
Rep 106
ARDesign Ceramic Coated Catless N63 downpipes w/ 2 bolt flanged (fits early F10 550s ) Selling them for half the original MSRP (Boxed up and ready to ship) $700 Trade offers welcome. Open to full or partial trades for various N63/550i performance or exterior parts that I don't already have. Last edited by MpJaj; 04-28-2017 at 10:43 PM.. |
03-03-2017, 03:14 PM | #2 |
Rep 106
DETAILS
We are extremely excited to present our F-Chassis 3" Hi-Flo™ catless downpipes! The best 3" downpipes currently on the market! In addition to an intoxicating and exotic sound, these downpipes add significant power and virtually eliminate turbo lag, making the amazing N63 engine even more responsive! Downpipes are available with both factory style connections - slip fit, and 2 bolt flanged. Please VERIFY which version is on your car, as Real OEM is not always correct, even with the VIN number! Fitment for all F Series Chassis with the twin-turbo V8 N63 Engine F01 750i Sedan F01 750iX Sedan F01 ALPINA B7 Sedan F01 ALPINA B7X Sedan F02 750Li Sedan F02 750LiX Sedan F02 ALPINA B7L Sedan F02 ALPINA B7LX Sedan F04 Hybrid 7 Sedan F04 Hybrid 7L Sedan F07 550i Gran Turismo F07 550iX Gran Turismo F10 550i Sedan F10 550iX Sedan F12 650i Convertible Our Hi-Flo™ 3" Catless Downpipes Feature: Typical gains with tuning in the 30bhp range! 100% hand crafted in the USA from premium 304 Stainless Steel - flanges and O2 bungs included! Water-jet cut 304 Stainless cat-back flanges, and CNC'd 304 Stainless V-Band flanges. 100% TIG welded, argon back-purged. Grade 10.9 Metric Hardware (145,000PSI tensile strength, C32-C39 Rockwell, Zinc Plated), and Nord-Lock positive locking re-usable washers included. Available with a 2000°F ceramic coating. Coatings come with a 3 year warranty against corrosion and rust to original owner. Lifetime warranty against any manufacturing defects given to original owner. We do NOT grind/polish our welds as some other manufacturers do. Grinding welds compromises the strength of the weld, and can lead to weld failure! Especially critical in applications exposed to temperatures in excess of 1500°F. Such temperatures will also rapidly deteriorate the polished finish. Last edited by MpJaj; 03-03-2017 at 05:41 PM.. |
03-09-2017, 06:26 PM | #4 |
Rep 106
Since my car ended up needing the slip on version. I wasn't able use them. I did just install and different set of Catless downpipes (slip on) and they gave the car a much deeper and aggressive tone but it didn't add drone. I think that depends a lot on your Catback setup. On stock mufflers i dont think there is any drone but If you already have drone i assume it would get amplified.
Performance wise its been my favorite modification.. The turbos spool up way faster ( You can hear this now) and the car feels much faster.. Last edited by MpJaj; 03-09-2017 at 06:34 PM.. |
03-10-2017, 09:50 AM | #5 | |
Rep 14
And CEL's? Anything to watch out for in that regard? |
03-10-2017, 05:11 PM | #6 |
Rep 106
Yes it may trigger the CEL. These downpipes have the extended L valve on the 2nd 02 sensor which may reduce the chance of getting a CEL but it will most likely trigger it eventually. I have the JB4 which eliminates this problem and just sold my BMW CAN tool which also eliminates it.
03-30-2017, 12:41 AM | #10 | |
Rep 106
You will want to confirm but its pretty simple to check because this area exposed from the bottom. Just follow the exhaust to the point where it starts to angle up towards the engine. Toward the bottom the downpipes will either slip into the bottom portion of the exhaust or be clamped on with a couple bolts. If yours are bolted on then these are the ones you need. |
03-31-2017, 06:12 PM | #11 | ||
Rep 160
04-01-2017, 05:36 AM | #12 | |
Rep 106
"Downpipes are available with both factory style connections - slip fit, and 2 bolt flanged. Please VERIFY which version is on your car, as Real OEM is not always correct, even with the VIN number! Fitment for all F Series Chassis with the twin-turbo V8 N63 Engine" Based on that one can assume production date isn't a solid identifier. I'm pretty sure the only way to know for sure is to look. |
04-10-2017, 07:27 PM | #14 |
Rep 160
04-10-2017, 08:23 PM | #15 |
Rep 317
Anything before 04/11 Prod date is Flanged style
04/11 and later is slip fit. If you have 04/11 Prod date you may want to verify which you have. Somewhere in 04/11 BMW stopped using the flange style. I also have 04/11 Prod date and my N63 has slip fit. |
04-11-2017, 12:49 PM | #16 |
Rep 160
Or sorry I have the slip style. Not flanged or bolted if that is what you're referring to as the flanged model.
04-11-2017, 01:56 PM | #17 |
Rep 160
04-25-2017, 06:14 AM | #20 |
Rep 106
@socrates42
No issues that I am aware of.... I sometimes run my car on Map 0 (JB4 Bypass/Stock) and the gains are still substantial. The manufacturer claims 30-40 rwhp on stock setup, I haven't dynoed my car but those numbers feel accurate to me. Even more noticeable is the increased throttle response and deeper exhaust tone. |
