04-23-2017, 09:15 PM | #1 |
Rep 194
Just ordered JB4
After probably not enough research, I pulled the trigger on a JB4 with OBDII, the JB4 Bluetooth add-on and BMS intake.
I am CPO with maintenance for a couple more years, so a tune seems like a non-starter, but my question is; do I need to run the OBDII cable if I have to Bluetooth add-on? TBH, I really can't even explain to myself why I even ordered any of this. The car was already fast enough! I almost never go WOT since I work from home, and the only times I actually get to open her up is on vacation trips once or twice a year. I guess I justify it by the fact that I traded my last fast car (and love) for her, and though I rarely will need or use the power, knowing it's there is EVERYTHING! |
04-24-2017, 04:06 PM | #3 | |
Rep 160
If your dealer is one that won't allow it I would recommend the ESS Tuning one. Just make sure anytime you bring it in you unplugged the system with the blank piece. My dealer won't allow me to use the JB4 if I want to keep my CPO warranty. |
FSociety3811.50 |
04-24-2017, 10:01 PM | #4 | |
Rep 704
04-24-2017, 11:10 PM | #5 | |
Rep 68
04-24-2017, 11:11 PM | #6 | ||
Rep 160
04-25-2017, 12:17 AM | #7 |
Rep 68
04-25-2017, 11:45 AM | #8 |
Rep 194
Many thanks for all the replies. From further reading, it sounds like I do need to use the ODB cable since that is how the JB4 gets data such as oil temp, RPM etc.
I thought the only thing the cable was for was allowing control via steering wheel buttons, but it sounds like there's more to it than just that. |
04-27-2017, 11:21 AM | #9 |
Rep 1,085
Drives: 2013 BMW F10 550 Xdrive Msport
Mine is a 550, but I am sure the install is similar on 535.
It is this simple... You can plug in the OBDII cable and have access to ALL functions of the BMS stage2 beta for boost increases and map choosing through the B/C control. If you want to add High performance Fuel option and the Waste gate control, you have to plug the wires into the ECU. Removal takes about 30 minutes (Maybe less on a 6 cyl and you get better at it everytie you install) and MAKE SURE your battery is disconnected EVERY TIME you remove or install the BMS. Basically, you plug into two harnesses (One on yours) to the front of both turbos on the 550, connect the OBDII port and good to go. If you want bluetooth and other features, you have to connect a wire in the blower motor area on passenger firewall, I suggest going to automotive store and getting a 2 to 1 fuse block which allows you to run the 20/30 amp fuse for the car and then a 10 amp fuse for the BMS. Keeps the car and BMS on different circuits that way. The ECU install is fairly simple, but a little time consuming. Just double and TRIPLE check your wire numbers on the harnesses to make sure you have the right connections done. If not, you might throw a code. If that happens, disconnect battery and go back and double check your wires. I would ALWAYS remove the BMS to ANY dealer before service. JUST to make sure you dont run into any problems. Once removed, there is no evidence of the mod. |
S1ammin44.00 |
04-27-2017, 11:32 AM | #10 |
Rep 194
Mike,
Thanks for that info! On the bluetooth power, it looks like they supply a quick-connect and you can just tap one of the red wires inside of the JB4's enclosure. I'll know for sure tomorrow when it arrives. Yes, been reading all last night regarding aftermarket addons and some of the horror stories involved, and since I have a dealer visit coming up middle of next month, I am undecided if I will install it this weekend, or wait two weeks. I think the practice of installing and removing might be a good idea anyway so I am leaning towards installing it. I'm a little excited to see the guages on my iPhone move :-) |
04-28-2017, 02:14 PM | #12 | |
Rep 1,085
Go to Advance auto or Autozone and get something like THIS: http://www.sears.com/accele-electron...FemhswodysAJPg When you open up the Blower motor box, 4 hex screws, There should be 2 large Fuses at the front of the box right on top of one another. The top one is 30 amp. Remove the fuse, insert THIS type of adapter, put the 30amp fuse back into the first slot and then put a 10 or 5 amp fuse in the second slot which has a wire running out of it. Use THAT power wire to make your BMS option work. I would also suggest taking a drill and Notching a SMALL "U" shaped hole in the rubber grommet to the right of the Blower motor box so the wire does not get Crimped. THAT is the proper way to install this option and ensure you do not make any holes in your OEM harness. Not to mention you are adding a layer of security with the fuse in line. Mike |
04-28-2017, 02:18 PM | #13 | |
Rep 1,085
http://www.autozone.com/electrical-a...ries/32414_0_0 You want the full size fuse, not the mini. Pull out the fuse from your car and bring to store to match it up Mike |
04-28-2017, 06:29 PM | #14 |
Rep 194
Mike,
The BT module connects to the JB4 via a D connector. The red power wire for the BT module can be connected to an external +12v source, or using the supplied posi-tap, you can connect it to one of the red wires inside the JB4 enclosure. Mine arrived this morning and I connected the BT power wire inside the enclosure. These latest JB4's also come with the OBDII CANbus cable that you have to pass thru the firewall. |
04-29-2017, 03:38 PM | #15 |
Motiphd
122
Rep 232
What is your take in regards to its performance?
2016 535i xDrive M-Sport | 2016 328 xDrive w/Lighting (hers)
2012 VW Jetta GLI 6MT APR Stage 2 (retired) | 2012 VW Tiguan SEL 4Motion (hers/retired) 2012 Acura TL SH-AWD Advance (retired) | 2012 Acura RDX Tech (hers/retired) 2010 Acura MDX SH-AWD Advance (hers/retired) |
04-30-2017, 03:23 AM | #16 | |
Rep 1,085
As I said, right inside the blower motor housing there are two fuses and the wire that you would position tap has a fuse in there. I do not tap into wires on these cars, the risk of braking even one strand can can voltage fluctuation down the road. Germans have almost zero tolerance on their vehicles for issues. If you maintain them and do everything by the book they last forever, but any deviation can cause problems. The solution I suggested gives you a dedicated fuse for the JB4 setup and makes the whole thing plug and play without tapping into other wires. Personal preference but after working in cars for 35 years, I just don't add any power connections with tapping off a fuse box or fuse area without the use of the item I listed. Especially if you are removing, installing when going to dealer. I actually had the wires fail on me where the JB4 harness connects to obd2 connection just from removing and installing on dealer trips. These small wires only have less than 10 strands. Oh and btw, if you have ANY technical issues, bms is THE BEST for support in my experience. |
04-30-2017, 03:27 AM | #17 |
Rep 1,085
People have reached mid 11 second quarter miles with JB4 and some modest mods. You have to run higher octane for best times though
They are the only choice for pre TU f10 models as well. JB4 allows two maps to be turned on or off on the fly and allows you to istimise your own maps if you know what you are doing At the track, I beat a Saleen mustang and three other hod rods in the quarter. You can achieve and surpass M5 stock power numbers with JB4. Best money u will ever spend. |
04-30-2017, 12:21 PM | #18 | |
Rep 170
05-01-2017, 08:12 AM | #20 |
Rep 194
05-01-2017, 10:51 AM | #21 | |
Motiphd
122
Rep 232
05-04-2017, 05:45 PM | #22 |
Rep 194
Just installed my JB4 and BMS intake and all I can say is DAYUM!!!
Car is scary! I do not dare turn traction control off. Yet :-) Floor it from 30mph and it plants you into the seat really good. Things happen so fast that you can't watch anything but the road. This is a totally different car! |
