2010 2011 BMW 5 Series Forum F10 slow puncture - car does warning which tyre - /replacement valve +metal cap |
08-19-2012, 02:57 AM | #1 |
Rep 5,025
In another thread mentioned about getting warnings from the car about a flat tyre but complaining it didn't say which one (I don't have TPMS)
Well now it has stated which one has low pressure (rear right) So looke like after only 2000 miles, I need to get a new tyre. Luckily it would seem to be s low leak so been able to just pump up theair again and contine on againwithout any warnings For those of you thathave had to replace a tyre, the valve and cap , have the replacemnts matched the others that areon teh car from new? i.e. get that metal valve cap. On tyre replavements in the past I just got a rather cheap looking platic cap. Want it to match the others , do BMW supply these or are these industry standard? Just fussy to make sure it matches the other wheels |
08-19-2012, 03:27 AM | #3 |
Rep 5,025
cheers
I'll need to get this sorted , just looking at prices and I nearly feel off my chair! Similar tyres were around £350 plus fitting on top, so not very cheap at all (thats a 275/24 R19 Y ) I've got Michellin Primacy on my at present so need to get one of those to match. I'll get a bm delaership to sort this out for me. I doubt I'll be able to claim for this under warranty - I doubt very much its a tyre defect as such. |
08-19-2012, 04:04 AM | #4 |
Rep 37
Even BMW dealers fit the industry standard plastic ones. My advice is remove alloy cap before car goes in. Theft of the alloy caps was a problem in UK as boys wanted them for their push bikes. My local dealer sells replacement caps and has a box that must hold thousands, he said that he bees such a big box to keep up with demand.
The standard UK TPWS sounds an alarm and indicates which the is flat. It went off on Good Friday. As the Easter holiday is a public holiday in UK could not get booked in till following Tuesday. Drove to dealers with completely flat tyre which was replaces then came bad news my other rear also has a screw in it and was also at zero pressure. No second alarm shown. The system uses ABS data to compare rotation so when fist tyre went flat alarm sounded, I assume the second tyre went down more slowly and was flat by Tuesday with both at zero system would not recognise any difference in rotational speed and hence no alarm. Flat tyres have smaller overall diameter so rotate faster is a simple explanation of how system works. |
08-19-2012, 05:49 AM | #5 |
Rep 537
Personally I wouldn't let the dealer sell you a new tyre. The mark up they have on them is absolutely massive and most will only get a mobile fitter in to fit it anyway and tell you they fitted it. I was in my dealer once while he sold some one an NCT5 runflat for an E60 and it was about £130 dearer than online prices fitted.
08-19-2012, 09:45 AM | #6 |
*Bimmerpost Plasti Dip Guru*
81
Rep 1,174
Drives: E53, E46-M3, E70, F25-X3
If you read your tire warranty packet, the manufacturer would replace the tire, not sure which causes it would cover as long it's not below 4/32.
It's worth to check it out to save you around 400$.
