2010 2011 BMW 5 Series Forum F10 VO Coded entire ECU Folder |
05-07-2016, 04:44 PM | #1 |
Rep 7
Hello i have a Problem and i need your help.
I retrofitted last christmas a rearview camera + rearview camera ecu (TRSVC). After retrofiting i coded 3AG into the FA and coded this onto the entire ECU folder (the root folder, because i did not know which ecus need this new FA). Now i have a appointment with bmw monday, the want to look at the clima. So i deleted the 3AG from the FA and coded again onto the whole ecu folder. Now the rearview camera is gone but i get some errors while driving: - 5AG Lane Change Warning -> does not work anymore - 5DP Park Assistant(self parking) -> does not works sporadically anymore How can i solve this problem ? sorry for my english i am from germany with a german car if it is important. I have the log file from yesterday there was an error: Code:
Transaktions-Report: Aktion: Codieren TRSVC [6] cdDeploy Finished cafd_00000223-013_008_005 Finished JBBF [0] cdDeploy Finished cafd_00000014-004_027_007 Finished EMF [2a] cdDeploy Finished cafd_0000029b-000_005_006 Finished ZBE [67] cdDeploy Finished cafd_0000007e-002_003_004 Finished CID [73] cdDeploy Finished cafd_00000186-007_004_003 Finished DME [12] cdDeploy Finished cafd_000001a7-000_007_003 Finished RK [a7] cdDeploy Finished cafd_0000026c-051_000_000 Finished cafd_00000bf3-051_006_000 Finished EGS [18] cdDeploy Finished cafd_0000023f-016_016_003 Finished SZL_LWS [2] cdDeploy Finished cafd_0000033d-001_005_000 Finished ASA [16] cdDeploy Finished cafd_00000021-004_055_002 Finished HUD [3d] cdDeploy Finished cafd_000000c9-001_006_000 Finished ICM_V [39] cdDeploy Finished cafd_00000044-006_006_001 Finished DSC [29] cdDeploy Finished cafd_000000d8-004_175_119 Finished GWS [5e] cdDeploy Finished cafd_000000d0-003_004_000 Finished AMP_HIFIHB [37] cdDeploy Finished cafd_000002aa-002_000_002 Finished RK [a5] cdDeploy Finished cafd_0000026c-051_000_000 Finished cafd_00000c1e-051_006_000 Finished CAS [40] cdDeploy Finished cafd_0000000f-005_017_002 Finished FRM [72] cdDeploy Finished cafd_0000012f-005_005_045 Finished ICM_QL [1c] cdDeploy Finished cafd_00000052-007_005_000 Finished IHKA [78] cdDeploy Finished cafd_00000092-003_011_004 Finished PMA [2c] cdDeploy Finished cafd_0000025f-004_006_041 Finished ACSM [1] cdDeploy Finished cafd_0000009c-005_001_001 Finished cafd_000008e5-005_001_005 Finished cafd_000008e8-005_003_007 Finished EPS [30] cdDeploy Finished cafd_000002c9-001_006_006 Finished RK [a6] cdDeploy Finished cafd_0000026c-051_000_000 Finished cafd_00000c1e-051_006_000 Finished EKPM [17] cdDeploy Finished cafd_00000098-000_008_045 Finished MULF [55] cdDeploy Finished cafd_000001f6-019_006_005 Finished RK [a8] cdDeploy Finished cafd_0000026c-051_000_000 Finished cafd_00000bf3-051_006_000 Finished HU_CIC [63] cdDeploy Finished cafd_000000f9-005_013_007 Finished FZD [56] cdDeploy Finished cafd_00000552-001_015_001 Finished cafd_00000553-001_016_001 Finished SM [6d] cdDeploy Finished cafd_000000b5-007_003_005 Finished PDC [64] cdDeploy Finished cafd_00000018-004_004_000 Finished HSR [2b] cdDeploy Finished cafd_00000028-004_055_006 Finished HC2 [8] cdDeploy FinishedWithError cafd_00000160-003_004_001 FinishedWithError TEL [36] cdDeploy Finished cafd_00000205-022_003_000 Finished KAFAS [5d] cdDeploy Finished cafd_00000122-003_003_003 Finished KOMBI [60] cdDeploy Finished cafd_00000069-007_001_045 Finished Today i tried to inject the CAF and get this error: Code:
Caf's suchen Tal wird generiert Abarbeitung wird gestartet TAL-Abarbeitung gestartet. ExecutionID=2016/05/07-13:42:52.181 [] "prepareTALExecution" wurde gestartet. [] "prepareTALExecution" wurde beendet. [] "prepareVehicleForCoding" wurde gestartet. [] "prepareVehicleForCoding" wurde beendet. [HC2 - 8] "prepareECUforCoding" wurde gestartet. [HC2 - 8] "prepareECUforCoding" wurde beendet. [HC2 - 8] "authenticateECUforCoding" wurde gestartet. [HC2 - 8] "authenticateECUforCoding" wurde beendet. [HC2 - 8 - cafd_00000160-003_004_001] Transaction type: cdDeploy; Message: Transaktion wurde gestartet. MCDDiagService [HC2 - 8 - cafd_00000160-003_004_001] Transaction type: cdDeploy; Message: Transaktion wurde beendet. [HC2 - 8] Während der TAL-Abarbeitung ist ein Fehler aufgetreten, bitte überprüfen Sie die Log-Datei. [HC2 - 8] - [Exception - HC2 - 8] Job-Ausführung ist fehlgeschlagen: negative response error: code: service returned global negative response description: Service WDBI_PLAIN returned a negative response with response code incorrectMessageLengthOrInvalidFormat; ECU: HC2_08_ETHERNET severity: ERROR [HC2 - 8] "finalizeECUCoding" wurde gestartet. [HC2 - 8] "finalizeECUCoding" wurde beendet. [] Es ist ein Fehler aufgetreten, bitte überprüfen Sie die Log-Dateien! [] - [Exception - HC2 - 8] Job-Ausführung ist fehlgeschlagen: negative response error: code: service returned global negative response description: Service WDBI_PLAIN returned a negative response with response code incorrectMessageLengthOrInvalidFormat; ECU: HC2_08_ETHERNET severity: ERROR [] "finalizeVehicleCoding" wurde gestartet. [] "finalizeVehicleCoding" wurde beendet. [] "finalizeTALExecution" wurde gestartet. [] "finalizeTALExecution" wurde beendet. TAL-Abarbeitung beendet. TAL-Abarbeitung beendet mit Status: "FinishedWithError". [C207] TAL-Abarbeitung beendet. Dauer: "12s". [C206] Abarbeitung beendet |
05-07-2016, 05:11 PM | #2 |
Rep 553
Post the question here:
http://f10.5post.com/forums/forumdisplay.php?f=463 to have the fastest reply.
Regards,
MWPos |
05-21-2016, 12:58 AM | #4 |
Rep 67
you must inject CAFD into DME and VO Code ECU:
Connect => Read FA (VO) => Activate FA (VO) => Read SVT (VCM) => Left-Click on DME => Click on "Detect CAF for SWE" => Select the CAFD from latest I-Level Shown => Select OK => Right-Click on DME (the ECU itself not the underlying CAFD) => Select CODE. Motor MUST NOT be running during this. BMW F series VO coding: http://bmw-f-coding.blogspot.com/201...vo-coding.html VO FA list: http://bmw-f-coding.blogspot.com/201...-download.html |
