2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes BMW M5 to F10 DIY Brembo Brake conversion
      01-28-2016, 11:15 AM   #1
mikekilpatrick
mikekilpatrick's Avatar
Drives: 2013 BMW F10 550 Xdrive Msport
Brembo Brake DIY conversion BMW M5 to F10
I will use this thread for a single point to obtain part numbers and DIY as I get installed on car. Will create a step by step DIY for anyone to follow. Please do not post other options in this thread. This is designed for a person to go to www.getbmwparts.com, Obtain OEM BMW parts, purchase Caliper adapters, and then do the install:
Good Video on how to change the rear Calipers which are identical to the OEM units with the exception of the adapter bracket, brake hose and cutting dust shield:
My research has shown:
ECS Tuning - 3-Liter European Pressure Brake Bleeder (BMW suggests 2 BA for pressure or about 30 PSI, I only went up to 25PSI) https://www.ecstuning.com/b-schwaben.../007237sch01a/
ECS Tuning - Brake Bleeder Catch Bottle - https://www.ecstuning.com/b-schwaben.../007481sch01a/
BMW - All parts available from www.getbmwparts.com Ask for Jason
All Bolts on the calipers are suggested TO BE REPLACED by BMW. This is mostly from what I can see due to Blue Semi permanent Thread lock being on all bolts.
Front Brakes:
Left Caliper 34117845747
Right Caliper 34117845748
Left Rotor 34112284101
Right Rotor 34112284102 Pads set 34112284869
Brake hoses 34322284318 each (2 needed, one per side)
Brake pad wear sensor, front left x 1 34356791958
Inner hex bolt M8X12 x 2 34111123072 (Different size than Rear)
Rear:
Rear caliper left 34217845815 (Optional, Identical part number as stock, just not painted)
Rear caliper right 34217845816 (Optional, Identical part number as stock, just not painted)
Rear pads set 34212284389
Rear brake lines 34322284319 each x 2 (These ARE different than stock and connect differently, Much easier to install over stock_
Left Rotor 34212284103
Right Rotor 34212284104
Cable bracket, left 1 34212284377 (This holds a "Banjo Bolt onto the caliper and suggested torque is 40 NM)
Cable bracket, right 1 34212284378 (This holds a "Banjo Bolt onto the caliper and suggested torque is 40 NM)
Brake pad wear sensor, rear x 1 34352284343
Inner hex bolt M8X14 2 34211161806 (Should be identical as stock, but good to replace)
MUST have at least 20 inch rims for Rotor clearance...
Must Bleed entire system after install. Left Rear, Right rear, right front, left front - In that order.
Rear Electronic parking brake can just be moved from Old Brake to new Brake. You can use a Star Socket to turn the Electronic center gear CLOCKWISE until it gives you a little resistance. Then, Ensure you clamp the caliper down to compress it back to stock. This can be done with a scan tool or coding but this is mechanical short cut.
Brake Grease on rear brake pads but NO BRAKE grease on front pads.
https://www.drive2.ru/l/5698330/
https://www.drive2.ru/o/b/2498650/
Pics at end of this thread and will build DIY as they get completed. MUST make sure you torque bolts to proper specs and do everything the RIGHT way. Use www.newtis.com for procedures and torque.
First Tip: BEFORE STARTING go find yourself a 9mm HEX socket. THEY DO NOT EXIST for the most part in stores! To remove the OEM brake assembly you MUST Have a 9 mm Hex socket and most tool kits go from 8mm then to 10mm! So ORDER one on amazon before you start. There are several mods you have to make. On the Front Brake dust shields you have to trip the top AND bottom of the shield with a Dremel by about 1-2 inches on each side. Then use a Metal cutting disc with Dremal to cut the outline out of the metal shield. Then remove sharp edges.
The rear shields will NOT come off of the car like the fronts, so they have to be cut ON the car. Torque of the Bolts to hold on the Adapter to axle is 115 NM and the M5 Caliper bolts to the Adapter on the car is 110NM. When installing the brake adapters onto the axle, you can see one side is flat and the other has a slight arch to it, the Russian writing engraved on them should face INWARD on car which will place the adapater with flat side facing car. Will do a complete write up once this project is finished.
I am adding pictures of the rear Calipers and the Axle modification I had to make for the adapters to fit. Had to remove 2-3 mm from axle and does not effect structural stability. Rear Adapters can be installed upside down by mistake, so this will reassure the correct installation. Also note that you SHOULD purchase the M5 Brake line holder AND the M5 Brake line itself. They are different for OEM units.
      01-28-2016, 01:56 PM   #2
550Reasons
550Reasons's Avatar
Drives: F10 550i
I personally wouldn't touch the rear, they look exactly the same as my 550i, save some money.
2011 550i
2013 M5
2014 M5 CP
2016 550i
      01-29-2016, 10:03 AM   #3
Aaron@Autosource
Aaron@Autosource's Avatar
98
Drives: F110/F22
Just came across these 2 ads this morning while browsing..
www.ebay.com/itm/252253422457
www.ebay.com/itm/272117762081
      02-01-2016, 03:46 PM   #4
mikekilpatrick
Very nice. Still can get the front and back shipped from Russia for $440.00.
Here is price from getbmwparts.com Brand new. Not sure if I trust used calipers or not. But up to person buying on how much risk to take.
Rear caliper left 34217845815 $387.61
Rear caliper right 34217845816 $387.61
Left rear rotor 34212284103 $301.87
Right rear rotor 34212284104 $301.87
Rear pads set 34212284389 $109.60
Rear brake lines 34322284319 $49.47 each x 2
Left Caliper 34117845747 $767.66
Right Caliper 34117845748 $767.66
Left Rotor 34112284101 $394.57
Right Rotor 34112284102 $394.57
Pads set 34112284869 $346.10
Brake hoses 34322284318 $51.68 each (2 needed, one per side)
      02-04-2016, 10:00 AM   #5
cipher5
cipher5's Avatar
Drives: 2020 Donington Grey X3M Comp
Looking forward to your thread Mike! Good luck!
      02-04-2016, 01:49 PM   #6
cipher5
cipher5's Avatar
Originally Posted by mikekilpatrick View Post
Thanks. I was recently told that a new master cylinder has to be installed to use the M5 Brembo brakes on the F10 550 Msport. Has anyone identified this as an issue currently? Have heard that Stoptech makes a pnp set, but i really wanted to go with the M5 Brembo setup.
While I'm not sure if the 550i one will work with the brakes, parts wise, the M5 does have a different Master Cylinder than the 550 (34336799903 vs 34336796729 respectively). Interestingly enough, the M5 master cylinder is used on the M5, M6, and the 640 and 650, but not the 550.
      02-09-2016, 02:09 PM   #7
cipher5
cipher5's Avatar
Looks like the parts are cross compatible:
http://www.yoyopart.com/oem/12789525...336796729.html
That's great news! I wonder if the same is true for the rear brakes.
      02-09-2016, 02:13 PM   #8
CVS23567
Drives: 16' M6 Coupé
Did you figure out if the rear brake modification will have any influence on the EM brake? I think if it does have the problem, the best we can do is to get a pair of Brembo sport drilled/slotted rotors and paint or not paint the rear calipers. Just to have a better look...
      02-11-2016, 10:57 AM   #9
CVS23567
Electronic parking brake should be no issue. Talking to Brembo directly in the next few days and speaking to an engineer.
That'll be great! Waiting for your good news! Thanks
      02-12-2016, 12:28 AM   #10
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
all you need is the brackets!
http://f10.5post.com/forums/showthread.php?t=1216776
      02-17-2016, 08:11 PM   #11
cipher5
cipher5's Avatar
Sweet! Keep us updated on the install!
      02-18-2016, 02:36 AM   #12
lsturbointeg
Just received the brackets from Russia today. BEAUTIFUL work and ONLY 440.00 SHIPPED in total!
      02-20-2016, 03:10 AM   #13
lsturbointeg
Are the calipers new or did u pickup the one's for an M6 that were for sale in the Market Place? Can't wait to see the finished product!
      02-21-2016, 12:54 PM   #14
lsturbointeg
Awesome! Can't wait to see it installed
      02-21-2016, 01:10 PM   #15
Hasser
Hasser's Avatar
Isle of Man
447
Drives: 2014 F10 M5
this sounds like its going to be an excellent job worth seeing.
2014 M5
1990 E30 318i Touring
1999 E38 728i -sold
M235i - sold
Activehybrid 5 - sold
      02-22-2016, 01:28 AM   #16
mikekilpatrick
All of my research points to the M5 and f10 using an interchangeable master cylinder. The caliper adapters from Russia are TOP NOTCH and at 440.00 for a front and rear set, a real deal. He even includes the bolts. Torque Specs on Caliper adapter bracket: М12-1.75 torque 115 Nm (~80 ft lbs),
Brembo does NOT MAKE A F10 retrofit kit for the our cars. I spoke to their engineers directly. That means all these kits you see online for brembo f10 calipers are someone taking either m5 calipers or GT calipers, custom making the bracket adapter and making a 4 thousand dollar profit!!! Not one of those kits states a new master cylinder is needed. Even DINAN makes a brembo brake kit for the f10. So.... Where are all of these calipers coming from??? My opinion is they are m5 calipers, repainted, new adapter bracket and then sold at crazy profit.... We will see....
      02-22-2016, 10:10 AM   #17
lsturbointeg
is it worth doing the rears since the M5 caliper doesn't really scream out look at me!!!
      02-22-2016, 12:26 PM   #18
lsturbointeg
From what I am told by BMW in Maryland, you need to do the rear calipers as well due to the Rotor size difference and they are 4 piston calipers. It has been suggested to me that if you are to do a Brembo upgrade, you "should' do all 4 rotors and all 4 calipers.
That is a personal preference, but I don't want to take any chances.
Mike
that's what i thought? i think i read somewhere someone just did the front upgrade but never the rear. after all is said and done are you going to have both front and rear calipers for sale or just the fronts?
      02-23-2016, 08:33 AM   #19
lsturbointeg
The problem with just the front is that you are then still running small single piston rear calipers. The M5 rears are 4 piston and the rotors are drilled and ten you have Brembo all around, which I think will perform better and at least look better.
exactly! i would love to do the upgrade eventually but i'm still working on the aesthetics. eventually
      02-23-2016, 11:48 PM   #20
mikekilpatrick
Ok, so HERE is the OFFICIAL Brembo Brake application list right from the lips of Brembo! Now, they tell me they DO NOT MAKE a brembo setup for an F10, yet it is part of their application guide. You will also notice that the Rotor diameter is the same as the M5 setup. There are different part numbers listed between the M5 and the F10 on this guide (so how dont they make a kit? hmmm), but with the other cross reference showing Master Cyclinders are interchangeable between M5 and F10 5 series, and the fact that the M5 to Non M mod is HUGE in Europe and Asia, it does look like the adapters made in Russia (marked F10 by the way with match rotor size as Brembo guide), things do look like they will work. Attaching guide...
550i, xDrive Front (F10, F11) 2011 > 6 B,R,S,Y,GT-R 405x34 2-Piece 1N1.9524A 1N2.9524A 1N3.9524A $4,895 $9,295
550i, xDrive Rear (F10, F11) 2011 > 4 B,R,S,Y,GT-R 380x28 2-Piece 2P1.9021A 2P2.9021A 2P3.9021A 7 $3,795 $7,795
535i, xDrive Gran Turismo Front (F07) 2010 > 6 B,R,S,Y,GT-R 405x34 2-Piece 1N1.9524A 1N2.9524A 1N3.9524A $4,895 $9,295
535i, xDrive Gran Turismo Rear (F07) 2010 > 4 B,R,S,Y,GT-R 380x28 2-Piece 2P1.9021A 2P2.9021A 2P3.9021A 7 $3,795 $7,795
550i, xDrive Gran Turismo Front (F07) 2010 > 6 B,R,S,Y,GT-R 405x34 2-Piece 1N1.9516A 1N2.9516A 1N3.9516A $4,895 $9,295
550i, xDrive Gran Turismo Rear (F07) 2010 > 4 B,R,S,Y,GT-R 380x28 2-Piece 2P1.9021A 2P2.9021A 2P3.9021A 7 $3,795 $7,795
640i Front (F12, F13) 2012 > 6 B,R,S,Y,GT-R 405x34 2-Piece 1N1.9524A 1N2.9524A 1N3.9524A $4,895 $9,295
640i Rear (F12, F13) 2012 > 4 B,R,S,Y,GT-R 380x28 2-Piece 2P1.9021A 2P2.9021A 2P3.9021A 7 $3,795 $7,795
650i, xDrive Front (F12, F13) 2012 > 6 B,R,S,Y,GT-R 405x34 2-Piece 1N1.9524A 1N2.9524A 1N3.9524A $4,895 $9,295
650i, xDrive Rear (F12, F13) 2012 > 4 B,R,S,Y,GT-R 380x28 2-Piece 2P1.9021A 2P2.9021A 2P3.9021A 7 $3,795 $7,795
640i Gran Coupe Front (F06) 2012 > 6 B,R,S,Y,GT-R 405x34 2-Piece 1N1.9524A 1N2.9524A 1N3.9524A $4,895 $9,295
640i Gran Coupe Rear (F06) 2012 > 4 B,R,S,Y,GT-R 380x28 2-Piece 2P1.9021A 2P2.9021A 2P3.9021A 7 $3,795 $7,795
650i, xDrive Gran Coupe Front (F06) 2012 > 6 B,R,S,Y,GT-R 405x34 2-Piece 1N1.9524A 1N2.9524A 1N3.9524A $4,895 $9,295
M5 Rear (F10) 2012 > 4 B,R,S,Y,GT-R 380x28 2-Piece 2P1.9039A 2P2.9039A 2P3.9039A 7 $3,795 $7,795 (This has NO electronic rear parking brake and only for racing) But, the OEM BMW Rear does have brake.
M6 Front (E63, E64) 2006 2010 6 B,R,S,Y,GT-R 380x34 2-Piece 1N1.9001A 1N2.9001A 1N3.9001A $4,595 $8,995
M6 Front (E63, E64) 2006 2010 6 B,R,S,Y,GT-R 405x34 2-Piece 1N1.9504A 1N2.9504A 1N3.9504A $4,895 $9,295
M6 Rear (E63, E64) 2006 2010 4 B,R,S,Y,GT-R 380x28 2-Piece 2P1.9003A 2P2.9003A 2P3.9003A $3,795 $7,795
File Type: pdf Retail GT Application List 2015 (12.14.15).pdf (154.1 KB, 598 views)
      03-02-2016, 11:32 AM   #21
lsturbointeg
got these on yet?
      03-05-2016, 03:21 PM   #22
lsturbointeg
Going to drop off the rotors and Calipers for paint today! One thing to notice, it appears that the OEM BMW M5 rotors do NOT have an interchangeable Hat center! We might be able to buy after market rotors, but the hat IS part of the Rotor assembly.
Now, I have to decide, do I get the Dust shields painted Blue as well? Caliper, Rotor Center and Dust shield all OEM M5 Blue?
you know, when i start my caliper project here next month i'm painting the calipers, rotor/dust shield and hat Matte black so aesthetics wise it'll compliment my bronze wheels. i'm not sure if you painting the shield blue will look tacky because the calipers and the hat will compliment each other? but the shield...i'm trying to picture it? might depend on what wheels you have?
