2010 2011 BMW 5 Series Forum F10 2012 550i Xdrive staggered setup |
03-01-2012, 02:49 AM | #23 | |
Rep 304
03-01-2012, 03:22 AM | #24 |
Rep 1,583
As long as you have a good tire you'll be fine. I'm using Michelin PSS
2013 M6 Coupe SG, VSE 003's 21, Akropovic Evo Carbon, KW V3, AMS DP's, Vorsteiner Full Aero, Gruppe M Intake, Bel Stir Plus & V1 with HP Laser Interceptors, P3Cars Gauges, JL 2X12W6Subs, 35%tints.
My Thread: http://www.6post.com/forums/showthread.php?t=794659 |
03-03-2012, 07:48 AM | #25 |
Rep 304
03-04-2012, 06:17 AM | #26 |
Rep 1,583
I've heard good things about the toyo tires. Not sure about the other 2 but I know some people on here are using them or have used them.
03-06-2012, 04:10 PM | #27 |
vroom vroom
19
Rep 134
sorry to highjack this thread, I'm learning as I go after having read 100+ threads, I also have 550xi, wanting to buy a set of 303M wheels from a friend off his F01. The wheels sizes are F20x9 and R20x10, tires are F245/40/20 & R275/35/20, will I have a "rolling diameter" issue? Also will my speedo be off since most people put F245/35 & R275/30 on 20" wheels??
03-27-2012, 03:11 PM | #28 |
Rep 4
Staggered Setup
Have you been running the staggered setup you listed below on your 535xi? Does it seem to be ok on your awd system? i have a 528xi that i wanted to run a staggered setup on with the exact tire sizes you had mentioned. Not sure if it's safe and what the rolling diameter difference tolerance is. Any help would be greatly appreciated.
Thanks |
03-27-2012, 09:25 PM | #29 |
Rep 287
I just installed my summer set-up on Friday on my 550i Xdrive.
No issues yet. speedo is all good. 245/35/20 tire on a 20 x 9 35 et front 275/30/20 tire on a 20 x 10 35 et rear i went with 275 since my rear offset is 35, and normally it should be 38. So i didn't want to take a chance on it rubbing, so 275 was the safer bet.
Current, i3 Capparis White, Lodge interior
Ex- F10 550i Xdrive M sport, white Ex- trade-in 2008 E90 M3 |
03-28-2012, 12:01 AM | #30 | |
Rep 514
Drives: 745le xdrive 2020, i3 2020
03-29-2012, 11:56 AM | #32 |
Rep 645
245/275/285 is only the width of the tire. Not the thickness(40/35/30). I think the difference between thickness of the tires is what's going to make the rotation between front and rear slightly (very small) difference. So going with 275 or 285 in the back will not do anything to the X drive.
03-29-2012, 03:33 PM | #33 |
Rep 514
03-29-2012, 04:22 PM | #34 |
Rep 29,202
E60 has a bit lower offset, so you probably need spacers.
03-30-2012, 11:06 PM | #35 |
Rep 4
