2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Paddle retrofit possible?
      10-21-2011, 09:53 PM   #1
tws_andrew
Drives: 14 AW CP M5, Turbo S, TT Ram
Is it possible to retrofit a steering wheel with paddles in a car that came without like in the 335?
      10-22-2011, 12:10 AM   #2
EV0LVE
EV0LVE's Avatar
42
Drives: F10 535i SG
Whatever you find out, please report back to us. I've asked 2 dealers for this and they cant answer my question. One even said that the transmission is different, I know that cant be true.
      10-22-2011, 09:58 AM   #3
gatoman39
gatoman39's Avatar
Drives: 2011 E92 335 M-Sport
The dealer is correct. In order to get the paddle shifters you need to have the:
2TB-Sport automatic transmission with shift paddles option. It's not just hardware, it's different software, different shifter.
      10-22-2011, 12:15 PM   #4
Needsdecaf
Needsdecaf's Avatar
6599
Drives: 2024 G80 Comp xDrive
Correct.
The electronics on this car are maddeningly complicated. I even tried to retrofit just the 2TB shifter, and was told the computer would reject it since it didn't have the right part number. This is just the shifter, it's the same damn thing!
      10-23-2011, 11:58 PM   #5
O.S.
Drives: F10 535xi Msport
I'd remove my paddles if i could actually. The get in the way all the time. Useless crap. When i need to go manual i use the shifter. But thats just me. To each their own.
      10-24-2011, 12:54 AM   #6
raleedy
Drives: 2016 228i 6-speed
Why not just get rid of the car and buy what you want?
      12-20-2012, 08:12 AM   #7
shawnsheridan
shawnsheridan's Avatar
Drives: 2018 Alpina B6 650ix GC
Originally Posted by Needsdecaf View Post
Correct.
You were lied to.
I retrofitted the 2TB SAT Gear Shift only in 30 minutes, and no coding was even necessary.
Details with pictures are here:
http://www.bimmerfest.com/forums/sho...&highlight=2tb
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      12-22-2012, 10:05 PM   #8
smashhell
Drives: 2011 535i
Correct.
You were lied to.
Can I ask you how much did everything cost?
2011 535i Alpine White, Oyster on black interior, Premium 1 & 2 Package, Magnaflow Full Cat-Back Exhaust, JB4 Stage 2
      12-25-2012, 09:21 PM   #9
528imsport
528imsport's Avatar
Drives: Msport
it works on e60 so it should be the same, just wire it up to the gear stick.
here is the DIY http://www.e90post.com/forums/showthread.php?t=600729
http://www.burgertuning.com/paddleshift.html
      12-25-2012, 10:43 PM   #10
shawnsheridan
What do you mean "everything"? I bought only the 2TB SAT Gear Shift. I did not add the Paddles.
      12-26-2012, 04:34 AM   #11
Boss330
Boss330's Avatar
One vital difference between the DIY and kit you linked to and E60LCI and F10/11 is that those kits are for the old "mechanical" shift lever with no ECU attached to the gear lever. The paddle shift is fairly easy to install on those cars as you can simply connect some wires from the retrofitted paddles to the +/- connectors on the gear lever. No coding etc. needed.
On the E60 LCI and F10/11 the gear lever is the new type that has it's own ECU and at least on the E60 needs coding to get the paddle shifters to work.
This thread has a fairly detailed discussion on this subject on the E60 LCI:
http://forums.5series.net/e60-parts-...etrofit-55056/
