2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum M5 Diffuser - The Proper Way
      03-07-2013, 11:13 AM   #1
AndyT
Drives: 2014 M5 CP UP
There are quite a few of M5 diffusers around, but I think not many have the proper adaptor to house all the sensor and modules and not many threads really making it clear to show the work needed to get it done.
Here is some of my work done.
When the stock diffuser is off, the first thing you will know is the M5 diffuser simply does not fit. The M Sport diffuser is too "square" to house the M5 Diffuser. You need this:
This little guy fits the M5 diffuser perfectly and save you the trouble to cut or saw your M Sport adaptor off. It has the holes, space to house the wiring but not quite the module.
You don't need to take the full bumper off to replace the adaptor. Only one side gives you enough space to take off the oem adaptor and put the M5 one on.
The problem is the M5 adaptor has the module places on the left instead on the right like the M Sport one.
But there is enough space to place the module on the right behind the adaptor and diffuser. I have wrapped the wires with protector because the housing is on the left. Yet, the sensor and wiring still fits nicely into the M5 adaptor.
The infamous sensor for Comfort Trunk
Now, I gotta schedule another day to put on the exhaust and M Sport Decal for the side skirt.
Hope this helps for any other looking for doing the M5 diffuser properly. It sure took me alot of time to get it right as there was partcular no pics regarding this installation and it is veyr hard to tell the detail of this installation with simple wording.
14 ///M5 Competition Frozen White
Ultimate Pkg - Dinan D-Tronic S2/M Performance Ti Exhaust/3D Design Lip/AC-S Roof Spoiler
12 535i xDrive MSport AW/CB/HUD/TECH/APP/EXE/JB4S2/20"356/H&R//VorsteinerLip/M5Diffuser/GT-C
04 745i Sport
      03-07-2013, 01:19 PM   #2
///M ARMY
Drives: F90
thanks for the details. MY diffuser fit perfectly, but need to address the comfort access.
what front lip do you have?
      03-07-2013, 01:38 PM   #3
Alan l.
Alan l.'s Avatar
5437
Drives: 2020 F95 X5M Competition
Do you have the price and part number for that piece?
      03-08-2013, 09:25 AM   #4
AndyT
Thanks.
That's the purpose of the adaptor.
The adaptor will house the sensor in the proper location and keeps the feature working properly.
It is just a vorsteiner lip.
04 745i Sport
      03-08-2013, 09:27 AM   #5
AndyT
I think it is around $5x to $60 at the dealer.
The P/N is 51128053585.
04 745i Sport
      03-08-2013, 04:32 PM   #6
550XiBlueMSport
Drives: 2012 550XI Msport
Andy Nice job well done, Nice ride,
      03-08-2013, 11:39 PM   #7
AWF10
Drives: 2011 535i
Is this piece also required if going from a non msport rear to a msport rear with oem 550 diffuser? Thanks.
      03-09-2013, 12:34 AM   #8
AndyT
Thank you!!! I should have some proper shots after all is done.
04 745i Sport
      03-09-2013, 12:37 AM   #9
AndyT
I believe so. The adaptor is a completly seperated peice to the bumper. The purpose of the adaptor is to place the sensor in the correct location and house the module.
You would need the M Sport bumper to fit the diffuser which you would need the adaptor to house the sensors and modules or there is simply no place to fit the above parts.
04 745i Sport
      03-09-2013, 12:59 AM   #10
gre8tw8LL
Drives: 2012 F10 535i
Very valuable information. Thanks! Getbwmparts.com got the adaptor for $29
2012 535i Alpine White | Oyster Black Dakota Interior | Hamann Front Lip | LiteSpeed Catback Exhaust | M5 Diffuser| Painted Calipers & Reflectors | Black Gloss Grill | LED interior lights | Piaa Plasma Yellow Foglights | Born on 1/30/12
      03-10-2013, 03:05 AM   #11
AWF10
Drives: 2011 535i
Okay. So this is only required if needed to house module for comfort access? So I probably won't need it since I don't have that option.
      03-10-2013, 05:50 PM   #12
///M ARMY
Drives: F90
Correct you won't need it unless you have the comfort access on your car
2022 RAM TRX
2021 Ford Bronco
2022 BMW M3
      03-10-2013, 07:17 PM   #13
Andy H.
Andy H.'s Avatar
44
Drives: 2012 535i M Sport
I'm having an M-tech rear bumper installed on my non msport 535i. In the process of this install I'm having an Eisenmann quad race exhaust and hamann style cf diffuser installed with it. My 535i is equipped with the comfort access.
Do you guys know if I'll need this piece to maintain the rear trunk comfort access sensor too?
LIVE FREE OR DIE
      03-12-2013, 09:20 AM   #14
AndyT
You may be able to get away without the adaptor.
But you gotta to be really creative and lucky to place the sensor in the correct location?
On top of that, I am not 100% sure if the module is for comfort trunk only or other feature. If it is for features other than the comfort trunk, it may be mandatory.
I recall seeing it somewhere say the module is for the rear PDC?
04 745i Sport
      04-10-2013, 07:40 PM   #15
Andy H.
Andy H.'s Avatar
44
Andy, what part are you talking about when you say,"module"?
Are you referring to the comfort strip itself? Or are you talking about the "adaptor" you referred to in your original post that allows you to make the trunk sensor work when using the M5 diffuser? Or what?
Thanks.
LIVE FREE OR DIE
      08-19-2014, 12:11 PM   #16
joejones81
Drives: 2014 silver 535xi
I followed these instructions and it worked for my 2014 535xi m-sport. By the way if you want a set of nice quad tips that you can install over your exhaust check out below links. I installed these on my m-performance exhaust but it should also fit on the stock exhaust. I've had them on for a few months and seem to have pretty good build quality. I really like the rolled tips, it gives it a more OEM look. I went with the 89mm (3.5"), since I felt the stock M5 tips were slightly small (I think they are 3"). These are $89 each so $180 for both however there is no welding necessary which makes it worth it.
By the way you will have to trim the exhaust exit pipe a few inches to stop the tips from sticking beyond the rear bumper, but you can use the exhaust cutters for that.
http://www.quality-tuning.com/audi-a...-l190-200-in60
      08-19-2014, 02:44 PM   #17
Antique-ace
Antique-ace's Avatar
Drives: 2022 M240i xDrive
Can you please post some more info and photos as to how you adapted these exhaust tips to your 535xi m sport? I would like to see if I could use these tips on my '11 550xi.
2022 M240i xDrive | Thundernight, Black Vernasca w/Blue Stitching | Premium Package, Driving Assistance, ZTK, Remote Start, Drive Recorder, Shadowline | Dinan CAI | AA Downpipe |
Turner Skid Plate |
SOLD: 2011 550i xDrive, 1995 M3.
      08-29-2018, 05:23 PM   #18
Jamrockbwoy
Drives: 2015 550i xDrive
Thanks for this.
Instagram @_gr8dane
2015 550xi - current
2015 428xi - retired
2010 328xi LCI retired
      08-30-2018, 10:34 AM   #19
EL Jeffe 5
EL Jeffe 5's Avatar
Drives: CBR1000RR
Thanks for taking time to post
      08-30-2020, 08:56 PM   #20
Christoefur
Drives: 2014 BMW 535d
Thanks for the walkthrough, it really helped guide me through the process. I just have one issue, my comfort access doesn't work anymore. Is comfort access the strip tacked down by those push in pins? If its somewhat loose (some of the push in pins broke), could that be the culprit?
