2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Wheels / Tires / Suspension / Brakes BMW M5 Brake booster retrofit on 550?
      03-04-2024, 10:55 AM   #1
SocomCA
Drives: BMW M6
Hey guys,
I have bmw f10 2016 550 with new m5 calipers and brake pads/rotors and the braking isnt good even after numerous brake flushes.
I was wondering, is it possible to install/retrofit a bmw m5 brake booster and m5 master brake cyclinder?
Would it be a direct fit or would there be problems with software or other parts?
      03-04-2024, 04:58 PM   #2
B-Buster
Netherlands
24
Drives: F10 535i, E63 650i
Yes you can. I did the same with my 535i when installing the G11 M-Performance calipers and F01 760i brake discs.
For the MBC you'll have to change 1 brakeline going from it to the block in the wheel well.
      03-04-2024, 05:50 PM   #3
SocomCA
Drives: BMW M6
Can you explain more? is it an oem brake line?
      03-05-2024, 11:10 AM   #4
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Yep.
34326790148
2015 BMW 535xi
ISTA VM Setup/Tutorial
      03-05-2024, 11:17 AM   #5
SocomCA
Drives: BMW M6
Originally Posted by Unspec View Post
Yep.
34326790148
Why does that have to be changed?
Also is it hard to do so?
      03-05-2024, 06:12 PM   #6
B-Buster
Netherlands
24
The line has a different position on the M5 BMC, different angle so you have to change it.
It is a short one, easy to replace.
      03-09-2024, 01:50 PM   #7
ceka
ceka's Avatar
24
Drives: 530d 11'
I swapped my calipers and rotors with 374mm ones and BMW 760i calipers
But I feel no change in brake force/distance.
So solution is to change brake booster, master brake cylinder, and brake lines?
My car is a 530d 2011, came with 348mm rotors.
      03-09-2024, 04:37 PM   #8
addy27
Drives: F10 550i
I've mentioned it in another thread, try coding the DSC correctly for the size of the rotors before switching the booster. I have felt the difference simply due to coding in a bigger or smaller caliper/rotor size. Worth a shot. The setting in DSC is called bresattle vorne, you can FDL code it using esys/launcher or other FDL coding agent
      03-09-2024, 06:04 PM   #9
SocomCA
Drives: BMW M6
Can you please share more information on the coding please?
      03-10-2024, 09:52 PM   #10
addy27
Drives: F10 550i
in Esys, if you select DSC for FDL coding, you will see a parameter for Bremsattle Vorne. Under it should be the multiple options/Sizes of the brakes. You can also see what it is currently set to. Change it to the size you have installed and FDL code the DSC. That should be all that's needed.
      03-10-2024, 11:51 PM   #11
SocomCA
Drives: BMW M6
I have the m5 oem rotors installed so what would be selected? I am just trying to get the most information possible to give to my coder
      03-11-2024, 06:57 AM   #12
Surly73
Curious - as a person who has always been underwhelmed by the way BMW chooses to make brakes on non-M 5-series cars feel (too soft, too much pedal travel despite there being a significant amount of braking power available) I'm curious - what happens if I make some changes to these coding settings without changing the brake parts? Will this screw up the F/R brake balance? Or might I get better brake feel from the brakes I already have?
I've read similar threads for the F30 where they have several different braking setups available from the factory as options. Folks install fancy new 4-pot or 6-pot caliper setups and feel no difference. Code it for those calipers and they feel amazing. What happens if you just code it for the sportier configuration? If much-improved brakes feel the same until coded, would coding make the same brakes feel better?
      03-11-2024, 12:22 PM   #13
addy27
Drives: F10 550i
MY understanding is that these parameters control the pressure/fluid movement inside the system. So coding it without changing the actual hardware may change the feel and pad life, meaning it may wear out faster possibly.
For M5 use the 398x36 which is the diameter of the M5 front rotors.
      03-12-2024, 05:05 PM   #14
Unspec
Unspec's Avatar
1300
Tried the coding today. Definitely changes how the pedal feels a bit. It gets firmer earlier in the pedal travel.
The coding actually corresponds to your caliper, not your rotor. To explain what the code means - FNR-AL 60/36/374-76:
FN: the supplier
R: frame (?)
AL: material of caliper
60: nominal piston size
36: nominal thickness
374-76: diameter
See picture below for all options available to the F10. Since this is a F10, there never was anything available with dual pistons in the 40-44 size, so I settled for the 60mm single piston coding. Closest you'll get is the M4.42 coding, which corresponds to the E70 X5M calipers. You could probably change your vehicle type temporarily to get the exact correct coding, but that will take testing by a far braver soul than I
2015 BMW 535xi
Surly73534.50
addy27388.00
      03-16-2024, 05:27 PM   #15
Unspec
Unspec's Avatar
1300
After driving a bit more, can definitely say the coding makes a pretty solid difference. The brakes feel a bit more predictable and a lot more communicative. Definitely try the coding before touching the brake booster and master.
2015 BMW 535xi
      03-17-2024, 09:15 AM   #16
f10andrii
Drives: BMW M5 - PORSCHE 911
Which values should I choose for F10 M5 Fronts and Rears ? Thanks
      03-17-2024, 10:30 AM   #17
Unspec
Unspec's Avatar
1300
Responding here for posterity.
Hinten is rear and vorne is front.
Pick the proper coding the corresponds to your calipers. For non-M5 F10's, there is no M5 coding available, so just pick the ones closest to your caliper sizes. Fronts would likely be M4.42/36/395, and rears would likely be 44/24/370.
You could potentially change your vehicle type for the F10 M5 just to code the DSC module, but again that is beyond the realm of what I am willing to dive into.
Edit: Keep in mind, I did the G series 4 pot upgrade, not the F10 M5 upgrade.
2015 BMW 535xi
      03-17-2024, 07:12 PM   #18
f10andrii
Hi - does it matter FN 44/24/370 vs CII 44/24/370 ?
      03-18-2024, 09:35 AM   #19
Unspec
Unspec's Avatar
1300
Likely no
2015 BMW 535xi
      03-28-2024, 09:39 AM   #20
9mmkungfu
Drives: 335d, 535d, 750i, X5 35d
Does anyone know if this coding is available via ProTool?
      03-28-2024, 05:58 PM   #21
B-Buster
Netherlands
24
You can set the brake disc size in Protool.
9mmkungfu198.00
      03-28-2024, 07:16 PM   #22
9mmkungfu
This section?
Hornet-01121.50
Tags
bmw m5, retrofit
