2010 2011 BMW 5 Series Forum F10 DIY: 8HP Transmission Fluid Service |
07-03-2020, 05:51 PM | #45 | |
Rep 2,591
Stay tuned for a front diff, rear diff, and transfer case fluid DIY soon.
2015 BMW 535xi
BMWKing1230.00 ChiltiCoatl891769.00 |
07-10-2020, 05:05 PM | #46 |
Rep 30
11-19-2020, 03:07 PM | #47 |
Rep 2,591
Contacted ZF and they confirmed that the wheels should not spin during the filling period. Updated post to reflect that.
2015 BMW 535xi
11-21-2020, 02:46 PM | #48 | |
Rep 1,873
I have to say that was something I sat and looked at for a while before doing mine. I did end up allowing the wheels to spin for part of it. At least one of the instruction sets I had from ZF said to work through all the gears up to 8. With your foot on the brake you can only select 1 and 2. So, for mine, I allowed the wheels to spin for part of the task and then went back to being on the brakes for the final level set. |
11-21-2020, 03:51 PM | #49 | |
Rep 2,591
Looks like ZF goes for the 2k RPM fill first, then gears, and BMW does it the other way around. Probably doesn't matter as long as you do both.
2015 BMW 535xi
StradaRedlands4941.50 |
03-29-2021, 08:11 PM | #51 |
Rep 210
I did the first step of a fluid change in my 535i today. The car has ~92k miles and I think the trans fluid is original.
I drained the fluid out of the fill plug, then drain plug. I then replaced the drain plug and refilled until it trickled out. After reinstalling the fill plug, I warmed the trans to 42 degrees C. Then I topped off the trans and took it for a spin. The shifting is already improved. Next I will drive the car for a few weeks and repeat the process. Then I'll do a pan/filter change. That should replace a good percentage of the fluid. I got 11 qts of ZF lifeguard 8 and a ZF pan/filter kit from RM European. I normally like FCP Euro, but this was a much better deal. Last edited by beegeezy; 03-30-2021 at 06:38 AM.. |
John H.230.00 |
03-29-2021, 11:56 PM | #52 | |
Rep 2,591
Glad it went well. You did the whole rowing through the gears and stuff right? Just double checking
2015 BMW 535xi
03-30-2021, 06:42 AM | #53 | |
Rep 210
That’s what I get for typing without my glasses. Yeah, I went through many R, D, M1, M2, M1, D, R sequences. Overall, I’d say this was very easy. Thanks for the DIY! |
03-30-2021, 10:58 AM | #55 |
Rep 2,591
Agreed that it's fairly straightfoward. Just a bit messy when you're doing it on jack stands alone.
2015 BMW 535xi
04-19-2021, 10:42 AM | #56 |
Rep 204
@Unspec thanks for the DIY. I just got my kit in from FCP so I'll be tackling this come Friday. I just turned over 65k so i'm a little past where I wanted to be (damn work).
I'll be doing the job on jack stands. Any tips from folks that have done the job recently? |
04-19-2021, 12:03 PM | #57 | |
Rep 35
Looking back, it was very easy... just take your time. One thing I did was put a level on the pan before removing it to ensure the car was level. (My garage has floor drains... it took some fine tuning with the jack stands to get sorted). Let us know how you make out. |
04-19-2021, 04:29 PM | #58 | ||
Rep 204
04-19-2021, 05:50 PM | #59 |
Rep 2,591
Use a level to get it ballpark, but it honestly doesn't need to be that level. As long as there's no noticeable tilt to the car, you're fine. At most, if you're off level a little, you'll be ~100-200ml short or overfilled which is well within margin of error. There's overhead built in so that the transmission doesn't just immediately grenade if it leaks.
2015 BMW 535xi
04-25-2021, 10:09 PM | #60 | |
Rep 204
Thanks again for the write up! |
Unspec1301.00 |
04-26-2021, 09:46 PM | #61 |
Rep 262
Did it yesterday, thanks for the write up as it aided in my successful attempt as well. I was nervous about doing it myself, it sounds like a beast of a job but wasn't that bad at all. I will definitely do this on every new to me BMW that I purchase and at every 50k miles.
I added 4-1/2 liters (5 if you include the overfill) and only took a couple of hours. The intimidating part for me was ISTA, but that had to be the easier part of it. If you have not done this and you are thinking about doing it, DO IT!!!! It was almost as easy as an oil change. The hardest part was finding a the correct tool to remove and tighten the fill plug b/c of the actual spacing between the bolt and firewall/body of the car because I tried to find a torque setup locally, impossible and I ended up just going the Allen wrench route. Thanks again Unspec for the awesome write up, I owe you a 12 pack my friend.
2011 550i (N63)
Upgraded 51mm turbos, Heatsync Stage 3 Flash, JB4 stacked, BMS WMI, Arm Charge Pipes, Heatsync Catless DPs, X-Pipe, Res Muffler Delete, xHP Stage 3 Trans Flash, Turbosmart Diverter Valves, 3.5 TMAPs, Oil Cooler, Heatsync Front Mounted Max Cool Intakes, Walbro LPFP and e40 mix rollin on Stance SF07 9x20 w/Toyo Extensa and 10.5x20 w/Toyo R888R. |
Unspec1301.00 |
05-05-2021, 03:28 PM | #63 |
Rep 965
Honestly I just jacked up from the Right Rear jack point. This is the one closest to the fill hole. I think this means there's a risk of putting too much, but I just guesstimated based on how much I took out. Car has been running perfectly fine for 5k miles now.
EL Jeffe 5611.50 |
05-06-2021, 08:39 AM | #64 |
Rep 262
I jacked up the front to the lowest point on the stands with parking brake set, then jacked up the back to the lowest point, then just inched my way up. I have two jacks and 4 stands though. In the past I was able jack the front into position then jack the rear into position when only using one jack. But I like to keep the jack under the car when I'm under it. Even if it's in a bad spot I only apply the pressure and don't lift on the point just as a safety. I would rather the jack go through the bottom of the motor than the car accidentally fall on my face. Just my preference though.
2011 550i (N63)
EL Jeffe 5611.50 |
05-06-2021, 11:12 AM | #65 |
Rep 2,591
I jack up the front with the parking brake set and rears chocked, put the stands under the front jack pads, and then jack up the rears. It really helps if your jack can roll freely, so that instead of pulling the car to compensate for the arc, the jack just rolls with the arc, which is what the intended design is to begin with. Also, quality jack stands help even more. ESCO's jack stands have overall a really wide base and nice large contact pad.
2015 BMW 535xi
EL Jeffe 5611.50 |
05-08-2021, 09:48 PM | #66 |
Rep 210
I completed my round of trans fluid changes today with the pan/filter and mechatronic sleeve replacements. FYI, the mechatronic sleeve was a real pain in the butt, mostly because I couldn’t figure out how to remove it. There is a metal release lever that has to be pulled down otherwise the sleeve is locked in place. You have to remove the fluid reservoir cylinder, just behind the mechatronic unit under the pan (3 bolts and one electrical plug) to gain access to the lever, which is held down with one bolt. After you do this the sleeve can be pulled out and replaced.
