2010 2011 BMW 5 Series Forum F10 F10 Technical Topics DIY Guides & Discussions DIY: 8HP Transmission Fluid Service
      05-09-2021, 01:19 AM   #67
Encendido3
Encendido3's Avatar
Drives: 2016 535i M Sport
Originally Posted by EL Jeffe 5 View Post
How did you get all wheels off the ground with out car falling off from one of the stands
What I did was start by driving up on some 2x4s to start from a higher position then used the central jack points. I kept the jacks under as well (under the central points)
      05-09-2021, 12:14 PM   #68
Unspec
Unspec's Avatar
1300
Drives: 2015 BMW 535xi
Originally Posted by beegeezy View Post
I completed my round of trans fluid changes today with the pan/filter and mechatronic sleeve replacements. FYI, the mechatronic sleeve was a real pain in the butt, mostly because I couldn’t figure out how to remove it. There is a metal release lever that has to be pulled down otherwise the sleeve is locked in place. You have to remove the fluid reservoir cylinder, just behind the mechatronic unit under the pan (3 bolts and one electrical plug) to gain access to the lever, which is held down with one bolt. After you do this the sleeve can be pulled out and replaced.
Were your sleeves bad? I haven't heard of any real need to replace them.
2015 BMW 535xi
ISTA VM Setup/Tutorial
      05-09-2021, 12:25 PM   #69
beegeezy
beegeezy's Avatar
70
Drives: 2013 535i M-Sport
No. I did it proactively. I wouldn’t recommend messing with it unless yours is leaking.
      05-27-2021, 02:32 PM   #70
OrcaPod
Drives: 2011 BMW F10 528i N52 engine
Thank you Unspec for such a great DIY!
Just completed auto transmission pan/filter, fluid replacement on my 2011 F10 528i RWD (N52).
My car has 160 500 km (~ 100K miles) and I don't think it was ever replaced by previous owners based on condition of the fluid/pan.
The shifting is noticeably smoother after replacement.
i got ZF 8 fluid from rockauto.com and trans pan/filter from autohausaz. That was the cheapest option for me considering shipping to Canada.
Around 4.3 L went out and around same volume went in.
Few notes to re-iterate:
- Make sure to do the "Rev to 2000 and hold it there for 30 seconds to fill the torque converter" part. I mistakenly skipped it at first and was not able to add any fluid during "required temperature" fill. After doing this step i was able to add some extra fluid, so old fluid volume OUT was equal to new fluid IN based on my estimates.
- On my model, It was a pita to remove a protective/supportive bracket on passenger side of transmission pan (to get access to fill plug). There is very little space to access 2 nuts which are holding the supportive bracket behind exhaust pipes. I had to cut my 10mm wrench in half so it can be squeezed between pipes and car's bottom.
      05-28-2021, 11:10 PM   #71
lsturbointeg
lsturbointeg's Avatar
Drives: 2011 535i Jet Black
me and Burrninja just did mine the other week! glad he knew how to do this as it was a very fun project to do as well as i got to learn more about this
      06-18-2021, 12:44 PM   #72
wmg/bmw
wmg/bmw's Avatar
Drives: BMW 550i GT Xdrive
Jersey
Hey, If I bring my wheels out to you in NJ can you help me with a Tranny Change? Im in New York
W
      06-19-2021, 10:47 PM   #73
Unspec
Unspec's Avatar
1300
W
Unfortunately, I've since moved from the time of writing the guide and no longer live in a place where I can work on my car, though I still do live in Jersey City. I work on it down in the Cherry Hill region now, at my parent's garage.
2015 BMW 535xi
      10-06-2021, 10:50 AM   #74
glemmy
Drives: BMW 520dx f11 -14
Thanks for the guide! I might give it a try in the spring, my car will be at 140.000 km by then
      10-20-2021, 06:34 PM   #75
aks9393
Drives: BMW 528i
make sure to be careful of oil temperature, it can be too hot.
      10-20-2021, 06:35 PM   #76
aks9393
Drives: BMW 528i
Detailed steps, Thanks
      10-20-2021, 06:36 PM   #77
aks9393
Drives: BMW 528i
where you bought Liqui Moly and how much you paid?
      10-20-2021, 06:38 PM   #78
Encendido3
Encendido3's Avatar
Best bet is FCPEuro. You can get the whole kit for a decent price and if you keep the car long enough (or rack up the miles) you can warranty the parts and fluid
John H.230.00
      12-26-2021, 11:22 AM   #79
OldShadeTrEE
OldShadeTrEE
Drives: 2012 BMW 535i M Sport
Originally Posted by Sylverlee View Post
Nevermind got it. Dang that was tough. For those that strip the drain bolt.. don't worry, the fluid will just drain if you leave one bolt in. Getting under the car when it was running was a lot less painful than I was expecting.
Thanks OP for that that fluid pumper video, that was super helpful.
I didn't find a video in this thread. Did I miss it or was it deleted at some point?
      12-27-2021, 12:33 AM   #80
Unspec
Unspec's Avatar
1300
This is the referenced video, it was just a text hyperlink so you might have missed it:
2015 BMW 535xi
      04-17-2022, 06:31 AM   #81
ctcarbonari
ctcarbonari's Avatar
Drives: 2015 BMW 535i M Sport
2015 BMW 535i  [0.00]
This is one of the very best threads I've read on ZF Transmission Oil Servicing.
Very nice job to the OP & the detailed technical input from others is great!
For those out there interested in seeing some empirical data for what the transmission oil looks like, I've attached a pdf of the Oil Analysis from when I had mine serviced.
2015 BMW 535i @60,245 miles.
File Type: pdf Test_Oil_Transmission_2022-03-15_Anonymous.pdf (1.99 MB, 95 views)
      04-19-2022, 06:53 AM   #82
bujokpl
bujokpl's Avatar
Poland
Drives: BMW 520d F11, BMW 318d E91
Thank you for a great tutorial.
I'm plannig to do it next week in my F11 520d.
      05-21-2022, 08:13 AM   #83
Blue Angel
Blue Angel's Avatar
Drives: 2011 323i and 2016 535d
Great thread Unspec!!!
For those who have done this without the pan removal, how much fluid can I expect to drain?
Another question; without pulling the pan, if I start with the car tilted rearward towards the drain plug instead of level, can I expect to get more fluid out? I would then level the car before filling.
This is based on Unspec's comment regarding not tilting the pan rearward during removal to keep the fluid from draining out of the filter. Or are we talking about an angle that's not practical to jack the car to?
      05-21-2022, 01:26 PM   #84
Unspec
Unspec's Avatar
1300
Any discernible angle should be fine to drain fluid out of the filter. You might run into some issues with the fluid pooling a bit behind the drain.
2015 BMW 535xi
      09-03-2022, 09:51 PM   #85
akaaceman
Drives: 2015 BMW F07 535i GT
Thanks a ton for such a well written DIY!
I did my own service on my E64 with the ZF 6HP and this seems pretty similar.
Now I have no worries about doing my 8HP!
      09-20-2022, 08:01 PM   #86
deanchen
Drives: 2011 BMW 5 Series
Thanks for writing this up. Didn't realize it was so much work, will definitely be taking mine to the dealership.
      09-21-2022, 11:28 AM   #87
Unspec
Unspec's Avatar
1300
Once you've done it once, it gets significantly easier. The hardest part is probably the filling
2015 BMW 535xi
      02-22-2024, 03:48 PM   #88
Smytty
Had this thread pinned for a while; going to tackle this sometime in March just trying to visualize the repair. This is done entirely without the wheels spinning? Can I keep the car on Jack stands while running through the ISTA procedure or will the wheels have to be on the ground?
The wheels will not move during the below procedure?
Step 4. Foot on brake, release parking brake, shift car into reverse, release brake. Wait 10 seconds. Brake, shift into drive, move shifter to the left and go into M1. Release brake, wait 10 seconds. Shift into M2, wait 10 seconds. Brake, shift into park, engage parking brake.
